Question about Amana ABB2527DES Stainless Steel Bottom Freezer Refrigerator
I need to replace one of the glass shelves. ANy
I need to replace one of the glass shelves. ANy suggestions
  • milten1
    milten1 May 11, 2010
    do you want to replacde just the glass or the whole shelf and do you need the part number what shelf
  • 302 Answers
Personally I would check with one of the many places where people drop off thier old appliances first.(cheapest solution)
Then I would try an appliance repair shop. (second cheapest)
If they don't have the right size of glass you could try contacting the manufacturer.(probably the most expensive solution)
Hope this helps.
www.partselect.com/Amana-Refrigerator-Parts.htm
www.apwagner.com/index.php?main_page=page&id=67
Posted on Oct 04, 2009
New home with wine frig but I want to turn it into a beverage frig. Where can I buy glass shelves to replace the wine racks in my U-line?
there must be a glazier business in the town to repair windows etc so go there with the length and width measurements and the thickness should be no less than 1/4 " or 6 mm to carry the shelf load
as the shop for a recommended glass thickness but I would not go under 6 mm and make sure that the edges are sander to get rid of sharp edges
Nov 18, 2015 | U-Line Refrigerators
RF197ACRS Samsung fridge How to remove glass from the shelves to clean
Well, I don't know about the individual shelves, but for the long glass shelf above the crisper drawers, there are two white clips located at the back edges of the glass that need to be pried out with a knife blade, or something similar. Place your blade in between one of the grooves of where the clip meets the plastic frame (and, NOT between the clip and glass! ) and pry the clip with a bit of a sideways motion. It's a little stubborn, but if you break a clip, don't worry, you really don't need it for the shelf to function.
Anyway, after you pry up the two corner clips, lift and slide the glass toward the back to get it out of the front groove, and voila!, the glass comes right out.
Aug 14, 2015 | Samsung / RF197ACRS
Where can I find a glass shelf 79cm width?
Call a glass shop and they should be able to steer you in thhe wright direction
May 04, 2014 | Furniture
Turned it off,Took out glass shelves to clean, now shelves won't slide back in!!
sounds like liner has expanded because it warmed up try turning it back on let it run overnight and try again
Nov 03, 2012 | U-Line 1175BEV Beverage Cooler
How to get glass out of shelves for cleaning
most shelves have the glass attached to the side brackets,, empty the shelf, and at the back of the fridge,, you'll see slotted rails that go top to bottom,, tap the shelf bracket upwards and it should come right out,, be careful,, once off the glass may come out too,,
Jun 13, 2011 | Refrigerators
Samsung Cooltech spare shelves available in b'lore??
it is possibly cheaper to go to a glass firm and get glass cut and edges polished to fit than it would be to buy replacement shelves.the mark up is horrendous on any spare parts......
Apr 20, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Glass shelves stuck together when shipped. can't separate new glass shelves for installation in medicine cabinet. there wasn't any paper between the glass shelving when it was shipped. it is impossible to...
You could try soaking them in hot water and see if the warming of the glass will allow some water to seep between the shelves, thus separating them.
Please rate this answer for me. Thank you
Mar 22, 2010 | Home
Glass shelve on bottom over grisper is broken Sanyo SR-9510W
You didn't say what size or model Sanyo you have, but the solution is easy. I have a Sanyo under the counter refrigerator in which the glass over the crisper is 1/8" thick frosted glass, 16" by 6 3/4" with the two back corners cut off diagonally. The frosting is simply to prevent you seeing through into the crisper below. It is maybe fifteen minutes work with a piece of window glass and a glass cutter to make a replacement. My full size refrigerator uses 1/4" glass since it is much larger and I have replaced it myself this way. If you don't have a glass cutter -- they are cheap and available in all harware stores -- you should be able to get any hardware store to make the cuts for you. They are accustomed to making custom cuts for people replacing their own windows. The have, and I use, what is known as an oil cutter which is a lot easier to use than the little hardened steel wheel cutters you will get if you buy a cheap one. Those work fine for straight cuts. Oil cutters make curver cuts equally easy to do.
Dec 07, 2008 | Sanyo SR-9510W Refrigerator
Cleaning Glass shelves mold.
the shelves can be removed not taken apart. sorry they're glued together, just use a bristle brush and some bleach. no problem.
Mar 30, 2008 | Refrigerators
Amana ABB2527DES Stainless Steel Bottom Freezer Refrigerator Logo
98 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
