Question about Stoves 720EF Electric Double Oven
Oven stopped working halfway through cooking. grill still works but top oven also stopped working
  • Malcolm Parsons May 11, 2010
    Don't really know the answer but have you actually lost power to the bottom oven? i.e. do the lights come on and does the fan still turn and the same for the top one, do the lights come on when the oven is set? As a thought, did you suffer a power failure which didn't reset the clock properly when the power came back on?
  • 250 Answers
Sounds like to overheat device(s) kicked in. Is the background cooling fan still operating? i.e. that is the fan that continues to run for about 10 mins once everything on the device is switched off.
As well as hearing it, you should be able to feel a gentle draft of air coming out of the gap between the top and bottom doors.
Posted on Feb 04, 2010
Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
main control board,take it back,its expensive,1 year warranty
Jul 26, 2015 | Ovens
Why does the fan not work in main oven while cooking, book says fan assisted oven, only see it working on rapid preheating to heat oven first. is it meant to work while cooking in main oven
A lot of ovens have a convection option, and the fan will only work in this position. Otherwise, just rotate your pan halfway through, like we always did.
Dec 27, 2014 | Ovens
Creda oven manual
The heat control knob needs to be replaced. This controls the amount of electricity that foes to the burner. Sometimes the burner itself has too much resistance and will only work when full current is applied. Hope this helps, please post a comment that this is solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info.
May 10, 2014 | Ovens
Hotpoint SD97PI oven self cleaning funtion and grill not working
The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. The most common complaint I have had with built in ovens besides the element burning out, is the oven door locked shut. When I get to the house and I ask to tell me a little bit of whats going on the story always starts " well, I was using the self clean option" or some variation of the sort.
Jun 22, 2012 | Hotpoint Ovens
Hi Guys I have a Stoves 720EF Double Oven and Grill. Whilst halfway through cooking some sausages on the grill this evening, the grill suddenly stopped working (plus the LED for the grill knob showing...
If the element and the indicator light both stopped working this suggests a problem with the power supply for the grill control. Either the grill control has no power going to it or it is faulty and requires replacement. If you are not sure what you are doing you'd better get a tech. to look at it, it can be fairly complicated for the untrained person.
Feb 24, 2011 | Stoves 720EF Electric Double Oven
Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
Sep 03, 2009 | Ovens
Bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Jan 14, 2009 | Baumatic B904SS Stainless Steel Electric...
Stoves 720ef grill not working
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
Oct 04, 2008 | Stoves 720EF Electric Double Oven
Stoves 720EF Electric Double Oven Logo
142 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
