Question about Sony KDS-R60XBR1 60" Projection HDTV
Plays a while, turns off, green power light blinks red 4 times
Sony sxrd projection tv
VtToolMan
  • 704 Answers
SOURCE: my sony sxrd 60 inch
"Will Not Work"
"Bad Move Buddy"
"I'm All Done"
"That's All Folks"
Any of these will do, in reality, the set isn't going to power on as you likely have done some serious damage to the main board or tuner, etc.
Posted on Dec 20, 2008
SOURCE: sony sxrd 60 in, won't power up--blinking red light 5 times
You need to replace your bulb. Order a replacement online---it's easy to swap and the instructions are in your manual. If you purchase one from a local dealer you will pay over $150 more!!!
Posted on Mar 01, 2009
  • 239 Answers
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
Posted on Mar 04, 2009
rustym62
  • 201 Answers
SOURCE: I have a similar problem with the Sony 60
I believe 4 blinks is fan error. You can take back off and watch fans in particular the fan for the lamp (this one goes out the most) The TV has a sensor so it knows if the fan turns.You can take a pencil and use it to spin fan sometimes that will jump start it (not a permanent fix just a test). You can try cleaning dust off fan and replugging the connector on the wires coming from fan.Might fix it if not fan will need replacement.
Posted on Apr 28, 2009
  • 6 Answers
SOURCE: Sony SXRD (KDS-R50XBR1) fan question
there are 2 more fans, 1 is in the middle of the base housing, 2 screws, should be clean. the other is on the left behind the circuit board in a black housing. This fan when i removed it was CAKED with dust and there is no way it could have had any effect on air circulation. the fan is inclosed and you have to take out the whole circuit board to get to it.
Posted on Jun 06, 2009
Sony sxrd 60 is not comming on the green light in power button turns red and flashes 4 times repeatedly. Does that mean it's a bad projection bulb? Model # KIDS R60XBR2
You have a bad fan. 4 blinks is a stuck or non responding fan. Check the one on the back near the lamp to see if its moving or not.
Aug 15, 2016 | Sony Televison & Video
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
What do i do if my sony sxrd power light starts blinking red
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly
Jun 17, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Sony SXRD KDS-50A2000 Will not power on. Green
I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
Mar 09, 2010 | Sony KDS-50A2000 50" HDTV
I have a similar problem with the Sony 60" wega SXRD rear projection TV. The green light blinks on the power/display LED and the picture comes on for a few seconds and then the screen goes black . Then the...
Apr 27, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony sxrd 60 in, won't power up--blinking red light 5 times
Feb 25, 2009 | Sony KDS-R50XBR1 50" HDTV
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
KDS-R60XBR1 60" SXRD HDTV
I had the same problem if it is blinking 4 times like I think it is... it is a problem with one of the fans (there are 4) in your TV.. It is a simple fix... try using an air canister to clean them. It will require some disassembly though.
Sep 12, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDS-R60XBR1 60" Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
