Question about Yamaha RX-V1000 Receiver
Yamaha RX-V1000 Buzzing
Normal 0 OK, I have a Yamaha RX-V1000 that has started to buzz intermittently through the speakers……sometimes its loud, sometimes its quiet, and other times the receiver just simply shuts down as if it were unplugged. It’s not a hum, it is defiantly a buzz sound. Sometimes if I place my hand on top of the receiver it gets quiet, other times it causes the receiver to shut off, I have opened it up and blown it out with the air compressor, it looks clean with no burnt components on the PCB’s….I do se the power supply board behind the transformer, it does have Two large capacitors on it I assume those are the filter capacitors, I am OK with a soldering iron and could attempt to replace them, just not sure if this is the problem or not. What do you guys think ?????
3 Suggested Answers
  • 1153 Answers
SOURCE: YAMAHA R-V701 MAKES BUZZING SOUND & WONT TURN ON
This could be the indication of an open resistor, or bad Capacitor in power supply. May not be visible to eye, but if you look in PS. there should be atleast one big sized cap and every PS has a bridge rectifier, this is usually 4 diodes in series, check them and see if any open, shorted
Posted on Sep 06, 2007
  • 313 Answers
SOURCE: very loud buzzing from speakers
check all connections to and from the amp. have you got animals in the house. They can accidenty pull plugs while exploring behind your units.
Posted on Jul 26, 2010
I have a Yamaha Rx-a730 receiver for surround sound for our tv. Sound keeps cutting out started recentlyOnce in a while it buzzes very loud and then if you turn off and back on it's ok. Any ideas?
Check your grounds. A bad one with components will cause buzzing and/or unusual sounds. If this does not the care of the issue you then have an intermittent condition in power amps or power supply that will in the future become permanent. U just do not know when.
Sep 01, 2017 | Yamaha Audio Players & Recorders
I have a Yamaha av receiver RX-V1000 and want to hook up Peavey PV– 115 speakers to it an don't know how
They are 8 ohms which is fine but that receiver doesn't have enough watts to push them. They are 400 watt min 800 watt max
Nov 04, 2016 | Yamaha RX-V1000 Receiver
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
I have a RX-V1000 Yamaha Receiver. I recently added on speakers for my back yard, but would like to run them independent of the receiver. Meaning I don't want to have to have speakers in the house on...
Any Tape Out (REC) is flat Line Level output for any analog source selected by the RX-V1000.
Or you could just set up Zone 2 as on Page 61 in the manual - with or without the remote capability.
Sep 13, 2011 | Yamaha RX-V1000 Receiver
My RX-V1000 shuts down periodically while playing a Blu Ray. Seems to at peak volume spots, like explosions. I can immediatly turn it back on an continue. Shuts down about 4 times during Batman Dark...
In other words, large demands on the amp. You don't say if it was actually LOUD in the room - or straining. Movie soundtracks, unlike non-classical music, are VERY dynamic.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
Jun 24, 2011 | Yamaha RX-V1000 Receiver
Very loud buzzing from speakers. it is a yamaha rx-v563. one day everything was fine, the next started the loud buzzing.
Jul 26, 2010 | Yamaha RX-V563 Receiver
Alot of loud feedback through speakers, a loud buzzing noise
What sources make it happen or which do not? All buzzing = something in the amplifier end. is it from all speakers or just one?
One external source= RCA cables not grounded. Reconnect them tightly with a twisting motion to wipe off oxidation.
Apr 10, 2009 | Onkyo TX-SR606 Receiver
Buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Mar 15, 2008 | Proview PA-32JK1A 32 in. LCD Television
Yamaha rv1000
ok yu problem has to be with the protection system before you burn it up it collapses to protect the whole system.....go direc to the thermal cut off devices on the main output and then to the power system......
Dec 27, 2007 | Yamaha RX-V1000 Receiver
Yamaha RX-V1000 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
