Question about Philips cBright XG2 Multimedia Projector
HOW TO CONNECT MY PROJECTOR TO MY LAPTOP?
HI... I HAVE A CBRIGHT XG2 LC4441 MULTIMEDIA PHILIPS PROJETOR. WHAT ACCESSORIES DO I NEED TO CONNECT MY PROJECTOR WITH MY LAPTOP? ANY SOFTWARE? WHAT OTHER CABLES DO I NEED?
I have hp laptop with hdmi & vga, sharper image projector with rca connector what do I need to connect these two
Posted on Jun 23, 2010
Set resolution on laptop to 1024 x 768, then connect with HD15 Male to HD15 Male UXGA cable. Basically a monitor cable.
Posted on Nov 10, 2008
My laptop is just searching and cannot find multimedia
Posted on Apr 02, 2009
Lc4441 projector repair
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. Check to see if your TV is still under warranty first though.
Nov 29, 2014 | Philips Lamp for Philips CBRIGHT LC4441 -...
Hi i have a Philips 4331 LCD projector its giving me double image which is not well colour mixed i have tryed to clean all the LCD pannel and all the lance but problem is still the same, if you have any...
If you are having "shadowing", this indicates a convergence problem in the LCD optical engine. Convergence is the correct alignment of all panels so there is no shadowing, or at worst limited to a one pixel shift. Some models can be adjusted, others cannot depending on the optical engine.
Aug 14, 2010 | Philips cBright XG1 Multimedia Projector
Bulb of LG LP XG2 Multimedia Projector is too dark. We need one with at least 2500 Lumin to work together with a newer beamer
This projector is only capable of handling a 150w lamp and it only is rated at 1500ansi lumens. There is no way you can do what you are asking. other than buying a 2500ansi lumen projector
Jun 04, 2010 | LG LP XG2 Multimedia Projector
EzPro 585 Multimedia Projector: Hello. I have a problem with my Projetor .. It is ...
check if your projector is capable of the same screen resolution as the laptop.
May 07, 2010 | CTX EzPro 585 Multimedia Projector
What cable to i need to connect my InFocus projector to my lenova laptop?
Most laptops and projectors have VGA ports. So a monitor cable (not an extension cable) is needed; this is a cable with two male HD15 ends. The projector above has the following input available: Mini D-Sub 15 (Analog) (VGA), Component, and S-Video. If your laptop has DVI or HDMI you will need an adapter to go to the VGA.
I hope this helps.
Feb 25, 2010 | Philips cBright XG2 Multimedia Projector
VGA Cable max Length from Laptop to Projector
Your on the edge, possible that the image will be unstable (wiggly). Considered a VGA amp from Gefen to up the drive. 50ft is about max. You can try dumbing down the res if it is unstable. Less horizonal frequency to travel long distance. good luck
Jun 03, 2009 | Philips cBright XG2 Multimedia Projector
Philips sv2 lc4431
Hi there
Did you reset the lamp timer ?
Apr 16, 2008 | Philips cBright SV2 Multimedia Projector
Colour Misalignment?
Looks like the LCD or the lens is out of alighnment. You may be able to see if you open the unit. the display may have bcome loose or the lamp sheild or flector could be out of place too contact here for more info as I dont find that model in my data.. Good luck http://www.usasupport.philips.com/caseSu...
May 06, 2006 | Philips cBright SV2 Multimedia Projector
Philips cBright XG2 Multimedia Projector Logo
3,563 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
