Question about Garmin Etrex Vista
I have an Etrex Vista in which it does power up with the proper date and time. The problem is that I can't get it to go to any other page.
    President:
  • 1,462 Answers
The date problems can be fixed only by doing master reset.
Specifically, a normal "master rest" on the eTrex Vista is accomplished by holding down the "Page" button and "Enter" (i.e. the click stick) while powering up. You are prompted that a full reset will occur, and after confirming, the machine is reset. But my opinion is this is not full reset, this sometimes doesnt fix the date issue
However, the undocumented "super master reset" on the eTrex Vista is achieved by simultaneously holding down the "Page, "Enter" and "Find" buttons while powering up. You have to hold all buttons in for about 5 to 7 seconds, and you DON'T get the warning message, but when the machine finally restarts, it is fully reset. After acquiring a satellite fix (it may take several minutes) - the time AND date both should be correct!
Oddly, neither Garmin tech support nor the local reseller seemed to know about this method of REALLY resetting the machine .
The link which documents the "super master reset" procedure is here: http://www.gpsinformation.org/dale/secret.htm#reset
Please leave me comment, if you need further assistance
RNJ VINODKUMAR
Hope this might also help other eTrex Vista owners who are experiencing the same date problem
Posted on Oct 04, 2009
Vista etrex cx will not acquire satellites . It worked okay the last time I used it.It then says poor reception .Use with GPs off. Its a clear day and was yesteday when i tried to use it. There seems no...
My Etrex Legend would not aquire satellites and after several call to tech support, I finally reset the whole unit. First I saved the waypoints on Mapsource. Then with the unit off press and hold the page button (upper right) then push the rocker button in and then push the power button. Once it starts you can then release all the buttons and set the unit outside for about 20 minutes.
May 22, 2010 | Garmin eTrex Vista Cx GPS Receiver
I am having trouble getting location. Even when I get good satelite coverage (many showing on the screen) No location shows. It also seems to be slow in acquiring upon power up. How do a restore the units...
Hi!
i checked out the Garmin owner's manual for your GPS:
http://www8.garmin.com/manuals/eTrexVista_OwnersManual.pdf
On page 6 it explains that from the satellite page there are four options from which you can choose;
1) Use with GPS off
2) New location
3) Restart search
4) Continue acquiring
If the date displayed on your unit is NOT today's date, select "Restart Search"
Since the GPS does NOT lose memory when the batteries are removed, the problem is unlikely to be that the GPS doesn't know where it was used last.
If the displayed time for your area is not correct, use the main menu to access the setup pages and follow the instructions for setting the time found on page 49. This SHOULD get you on your way.
May 02, 2010 | Garmin eTrex Vista GPS Receiver
No change time
You will need to backup all of your tracks, waypoints and routes to your PC. With the unit off, hold down the page, enter (joystick), and find buttons for 5 to 7 seconds while power up at the same time. Then go outside and let the unit get a fix on the satellites. This will fix the date problem. Once done go to the main menu and select setup and the system. Make sure WAAS is disabled. If you enable this option the date will get messed up again and you will have to do this all over. There was supposed to be a firmware upgrade that fixed this problem, however I found after flashing the firmware update, the date problem still occurs if WAAS is enabled.span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
Apr 22, 2009 | Garmin eTrex Vista GPS Receiver
Garmin eTrex Vista Cx won't turn on
Call Garmin customer service, they are wonderful. My rubber thing around the outside became loose,and they sent me a new unit, even though it was almost 2 years old.
Apr 11, 2009 | Garmin eTrex Vista Cx GPS Receiver
Etrex vista will not display any map
I had the same problem for months. i don't know what part of this worked or if it was a fluke that it finally worked. I downloaded the newer firmware for the garmin and installed it ( http://www8.garmin.com/products/webupdater/ ) then tried adding maps, that didn't work, then tried 3-4 times resetting the garmin, and each time tried adding maps and it didn't work - turns out I wasn't really resetting it (I think) it appeared that the successful reset was holding down the clicker key and the pages key while starting up, and keeping them held down for a long time (15 seconds?) - there was no sign that it was resetting except a faint illumination, then when I let go of those 2 keys it went through the setup sequence. the only way I knew it had finally reset was when the page came my pointer was in the middle of the united states. I had repeatedly tried resetting before and the pointer/map page came up to where I was last at, so it hadn't really been resetting. I'm very displeased that it took 5-10 tries to get this to work and this happened on 2 units.
I reloaded the maps after it had properly reset and they actually display and are on the map list!
this is the second etrex unit ive had this problem with, and the first one was just as flaky - taking many reset events (see master and super master reset on other etrex threads at this site)
Mar 15, 2009 | Garmin eTrex Vista GPS Receiver
Garmin Etrex display problem
Have you updated your Garmin unit software recently?
Mar 21, 2008 | Garmin eTrex GPS Receiver
Wrong elevation showing garmin etrex vista
Found a fix, by resetting all user data my problem was fixed.
Garmin Edge 305 Power off device and hold 'mode + power'
eTrex Vista Power off device and then hold 'page + enter + power'
Hope this helps!
Dec 16, 2007 | GPS
ETrex Vista shows incorrect date
Thanks for the great advice. My problem is fixed!! Yay!
Nov 18, 2007 | Garmin ETREXVISTA GPS Receiver
Garmin Etrex Vista Date problem
Thanks to a hint from a user on another web forum, I have found a fix, at least for now.
Specifically, a normal "master rest" on the eTrex Vista is accomplished by holding down the "Page" button and "Enter" (i.e. the click stick) while powering up. You are prompted that a full reset will occur, and after confirming, the machine is reset. However, in my case, this achieved a full reset, but did not fix the date problem.
However, the undocumented "super master reset" on the eTrex Vista is achieved by simultaneously holding down the "Page, "Enter" and "Find" buttons while powering up. You have to hold all buttons in for about 5 to 7 seconds, and you DON'T get the warning message, but when the machine finally restarts, it is fully reset. After acquiring a satellite fix (took several minutes) - lo and behold - my time AND date both seem to be correct!
Oddly, neither Garmin tech support nor the local reseller seemed to know about this method of REALLY resetting the machine - I will pass on the information to them, for future reference.
Hope this might also help other eTrex Vista owners who are experiencing the same date problem.
Nov 17, 2007 | Garmin eTrex Vista GPS Receiver
Garmin eTrex Legend
Do the following: 1 - Make sure you have fresh batteries in the unit and turn the unit on. 2 - Check the GPS date and Time. On the Main Menu at the bottom of the screen, you can see a date and time. If the date and time are not current, then the clock is your problem. You will have to wait for the almanac information to be updated. Details are below in a later section. 3 - Make sure your GPS is in the Normal Mode and not a demo mode. Verify other systems settings. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. Verify the following settings: GPS: normal WAAS: Enabled Language: English or your choice. Battery: Set according to your battery types. 4 - Check your GPSs Version Software. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. From the System screen, access the sub-menu icon in the upper right bar. Select "Software Version" from the list. Verify the actual software version for me. The latest version available for the eTrex Legend is version 3.90 dated March 2008. http://www8.garmin.com/support/download_details.jsp?id=711 Update the unit using this latest software and using Garmin's Webupdater. http://www8.garmin.com/products/webupdater/howtoinstall.jsp If that won't work, use the following download page to access the latest software updates per units. http://www8.garmin.com/support/blosp.jsp 5 - Resetting your GPS clock and almanac information Next you may need to acclimate your unit to a new date and time (almanac information). If you had your unit off and without batteries for over a month since you last accessed satellites, then your clock and almanac information may be incorrect. Even Garmin acknowledges this problem after software updates and the problem with accessing satellites. They state: "unit data including alamanac information may be incorrect or cleared. Back up all user data before upgrading. After installation is complete, place unit with a clear view of the sky for 15-30 minutes to re-acquire almanac data. " I know of no way to reset the clock using the GPS menus. All I can suggest is that you do the following: A - turn the unit on and wait 5 minutes or so for the "Poor Satellite Reception" screen to appear. See page 7 of the owner's manual. B - Set the "new location" to your area using the map when the "poor satellite reception screen" appears. Be sure to use the "map" option and not the "automatic". C - Set the GPS outside with a clear view of the sky. Check on it every 10 minutes. When the "Poor Satellite Reception" screen appears again, then click on "Restart Search". The "Restart Search" option is used when the date provided in the GPS is not today's date. (See page 7 of the Owner's manual for an example) Legend Owners Manual: http://www8.garmin.com/manuals/eTrexLegend_OwnersManual.pdf D - Once the GPS can track 4 satellites, then the clock should reset and you should be fine. This process could take up to an hour. I have had this problem with my eTrex Vista and eTrex Legend (both backup GPSs) and resolved it by having the clock reset. In fact, I just tried my eTrex Legend today after not using it for many months and storing it without batteries and it had this same problem. I followed the steps above to fix the problem. This took about 35 minutes.
Mar 28, 2007 | Garmin eTrex Legend GPS Receiver
Garmin Etrex Vista Logo
Top Garmin Boating Experts
TO Lady
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
