Question about Plumbing
I have a brassCraft drain cleaner BC400... The cable is stuck in drain..pvc pipe...Does it have to rotate out...like rotated in? Is there a special to reconnect cable.
  • 129 Answers
You can try putting it into reverse and as you give it just alittle power pull back on cable. I hope this works for you. You might also try alittle back and forth.
Posted on Oct 05, 2009
HOW TO GET STUCK CABLE OUT OF HYDROSTAR DRAIN MONSTER DRUM
There are two vent holes you have to work through to get at the kinks or twists in your cable. Pull the twisted part out of the vent in your drum and unwind it, making sure you hang on to it because it will want to snap back into a twist. Hold the unwound part in one hand and pull the rest through the front of the drum a little at a time. It can take up to 10 or 15 minutes but there are no kinks or twists in your cable that you can't get out and pulled through the front of the drum. Pull all the cable out of the drum and then rewind it in a clockwise rotation. The Harbor Freight Drain Cleaner you're referring to rewinds exactly opposite of all other drain cleaners, which is why their retrieval bit is also made opposite of other drain cleaners. The very early model Harbor Freight drain cleaners were modeled after General's Mini Rooter and parts actually interchange.
Aug 23, 2014 | Plumbing
Can you fix a broken pvc pipe
more specific please. so your saying that the actual faucet sticking outta the wall is PVC and not a Brass for plated brass pipe? Also what type of valve do you have. Is it a single knob valve that you rotate to turn on as well as adjust your water temperature, or is there 2 knobs one for hot and one for cold?
A picture would help me answer your question a lot easier
Jul 01, 2014 | Delta Faucet Delta RP17453 Pull-Down...
Dont know how to assemble brasscraft auger with T handle
www.brasscraft.com
www.brasscraft.com/products.aspx?id=730
Apr 11, 2014 | Brasscraft 1/2 in. x 50 ft. Drain Auger...
How to assemble
Without a model number, I'm going to guess that you have the standard model that ISN'T drill driven it has an actual motor. There aren't many parts and it should've come in one piece from Home Depot of where ever you purchased it. The three main pieces are the drum, cable, motor and frame. To remove/install the drum, pull out the lever on the back lower part of the frame and pull the drum off the shaft. The motor is held on by four bolts that attach it to the motor mount. If you need to install a cable on this machine, push the cable in through the cable guide and attach it to the mount on the inside of the drum. As you face the drum the cable will wind counter clockwise.
How do I replace cable on my bc260
Unscrew the cable release from the back of the drum and pull out the cable from the front, reverse procedure to install. Cable winds in a counter clockwise rotation looking at it from the front as you are installing the cable.
Oct 27, 2013 | Brasscraft 5/16 in. x 50 ft. Cable Drum...
Pepboys gave me the obd code p2004 imrc bank 1 stuck open? what does this mean and how much is it likely to cost to fix?
P2004 INTAKE AIR SYSTEM MALFUNCTION. POSSIBLE CAUSE.TEST FOR STICKING ACCELERATOR OR SPEED CONTROL CABLE TURN OFF KEY AND DISCONNECT ACCELERATOR AND SPEED CONTROL CABLE FROM THROTTLE BODY.ROTATE THE THROTTLE BODY LINKAGE TO DETERMINE.IF IT ROTATE FREELY.THE THROTTLE BODY MAY HAVE FAILED.CHECK AIR CLEANER AND AIR INLET ASSEMBLY FOR RESTRICTIONS.CHECK THE IAC MOTOR RESPONSE.IT MAY BE DAMAGED OR STICKING.CHECK PVC SYSTEM VALVE AND HOSES FOR LEAKS AND PLUGGING.CHECK FOR SIGNS OF VACUUM LEAKS IN THE ENGINE OR COMPONENTS. TEST TP SENSOR SIGNAL DUE A SWEEP TEST AT KEY ON ENGINE OFF
Mar 29, 2010 | 2000 Ford Focus
Can you sweat pvc pipe
No you cannot. It must be glued and you cannot effectively glue pvc to brass. They do make pvc drains with a brass top... that is what you need to use, then you can glue to the drain and still have the brass look that you want.
heatman101
Mar 27, 2010 | Mountain Plumbing SOLID BRASS DRAIN KIT -...
For Focus Check Engine Light P2004
CODE P2004 INTAKE AIR SYSTEM MALFUNCTION. POSSIBLE CAUSE.TEST FOR STICKING ACCELERATOR OR SPEED CONTROL CABLE TURN OFF KEY AND DISCONNECT ACCELERATOR AND SPEED CONTROL CABLE FROM THROTTLE BODY.ROTATE THE THROTTLE BODY LINKAGE TO DETERMINE.IF IT ROTATE FREELY.THE THROTTLE BODY MAY HAVE FAILED.CHECK AIR CLEANER AND AIR INLET ASSEMBLY FOR RESTRICTIONS.CHECK THE IAC MOTOR RESPONSE.IT MAY BE DAMAGED OR STICKING.CHECK PVC SYSTEM VALVE AND HOSES FOR LEAKS AND PLUGGING.CHECK FOR SIGNS OF VACUUM LEAKS IN THE ENGINE OR COMPONENTS. TEST TP SENSOR SIGNAL DUE A SWEEP TEST AT KEY ON ENGINE OFF.
Sep 19, 2009 | 2000 Ford Focus
Need location of drain pipe on horizontal attic a/c unit?
If you have a shop vac (wet vac) I suggest finding the drain outlet and sucking the restriction out. However if you don't then you need to open the air handler (coil) and pour about a cup of Bleach, not drain cleaner in to the coil drain pan. The restriction is likely in the trap ( U shaped piece of pvc). Good luck!
May 30, 2009 | Goodman CKL60AR60 Air Conditioner
Plumbing Logo
1,402 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
