Question about Mitsubishi WS-55809 55" Rear Projection Television
Need to reset v chip dont have pass word - Mitsubishi WS-55809 55" Rear Projection Television
  • SD Tech
    SD Tech May 11, 2010
    You really only have two choices here--you can telephone Mitsubishi during regular hours and see what they tell you......I suggest you do this first. SECOND: THEY will probably not tell you but this set has a hard reset---once it is done the set will return to the condition it was when new in the box----all settings including labels placed on inputs etc will be gone---it is usually a good idea to do this only as a last resort..... If you get no good ideas here or from Mitsubishi let me know and confirm the model number to me and I will tell you how to do the reset--it is done with the original Mitsubishi remote. Regards, SD TECH
Xerox Phaser 3500 - installed new toner still says it needs replaced. Is there a way to reset the message? We have powered off/on and it still says that it needs replaced.
the only way to reset the message is to replace the cartridge CHIP with new one or reset the chip with proper CHIP reseter(but i don't think that you have reseter).
This printer can write on cartridge chip and sometimes when you replace cartridges the printer writes directly the information from empty chip to new chip and that makes new chip EMPTY. This is some kind of bug. SORRY!!! CHIP is cheep so don't worry...be happy
pifonski
Mar 03, 2011 | Xerox Phaser 3500/DN Laser Printer
Do i need to reset CARTRIDGE CHIP OF my SAMSUNG ML-1915 ( MLT-D10
I just refill my toner for ml 1915 can anyone help me how to reset the chip for my ml 1915 because the price of the toner is the same as a new printer, Mr bobby from Indonesia.
Thank's alot.
May 13, 2010 | OKI C3400N Single Pass Color Printer
I have a multi pass MP 730. It stsrted to say
Take a look at my tip on cartridges it may save you a lot of time and money
http://www.fixya.com/support/r3845491-ink_cartridge
OR
Read on and see if any applies to you.
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a
chip resetter around on the INTERNET or maybe even local
OR
Even better empty cartridges that
never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
If you try to clean the contacts be VERY careful cleaning contacts and ONLY use isopropynol on a lint free bud or cloth.
Also be very gentle.
I have seen the contacts cleaned and cartridges ruined with other methods of cleaning.
Rubbing too hard can also cause a badly set chip to move making it inoprable.
I dont like full prices replacements either which is why I always provide the links
I usually reccomend that people take back any cartridge that does not work right from the get-go.
I dont know of anyone who has had a problem doing that be it a shop refill or otherwise.
No matter if I paid $1 or $100 for a cartrdige I would still expect it to work
Hope this gives you the information you need
Bob
EXMod
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Jan 14, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
I need to reset cartridge for use in R300, dont have a reset device and dont know where to get one
Try to find at ebay. Or use CISS chip, so you dont' need reset again, just fill ink tank.
Jun 28, 2009 | Epson Stylus Photo R300 InkJet Printer
I dont have v-chip password for parental control
Hello Jacqueline,
PLease try all 0000 that should clear your tv v-chip. any question please call 323-767-6030. Thank you.
Feb 11, 2009 | Astar LTV2001 Television
V-chip reset
I cannot find any way to reset it. You might contact the manufacturer.
Oct 06, 2008 | Durabrand DWT2704 TV
V-chip on Durabrand BH2004D TV
I NEED HELP WITH V-CHIP TV HAS PASSWORD AND I DONT KNOW THE PASSWORD IS THERE WAY TO RESET V-SHIP
Sep 15, 2007 | Televison & Video
Front panel locked and remote don't work
Are you sure there is not a problem with the TV set? The set will need to be on to unlock the front panel. Bypassing the V-Chip Lock on most Mitsubishi sets use a four-digit passcode that is required to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus. If you don't have the passcode, it is easy to bypass. This is neccessary if you forgot the code, purchased the set used, or if you simply don't feel like searching through your files to find it. To bypass the V-chip: You can view the locked shows by pressing the number 9 and QV buttons on the remote at the same time, whenever your passcode is requested. This process temporarily unlocks the TV. To reset the code: When you use the button combination 9 and QV while entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode. Good Luck
Mar 17, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
24 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
