Question about Desa International Reddy Heater R40 40,000 BTU Kerosene Heater
No start i cant see ignitor get brite red dont seem like im getting fuel
    Problem Solver:
  • 10 Answers
If the ignitor isn't glowing it isn't a fuel problem. It may be a pressure switch or bad ignitor.
Posted on Oct 05, 2009
My Ruud achhiever 90 starts to fire but as soon as the blower fires the burner goew out. I also noticed that the "igniter" on the end isnt firing. Could that cause the burner to not stay lit when the
There is an ignitor and a flame sensor. If the ignitor does not ignite the gas after a time, it goes out. If the flame sensor does not detect ignition the gas valve closes. When you start it you should see the ignitor come on like a light bulb and glow, then the gas valve opens and you get ignition. Then the flame detector turns on when the ignitor goes out. Flame detectors are like a chrome wire that has one connection to it and it sits part of the way in a burner. They get dirty and corroded. When that happens it shuts down. You can clean the flame detector with steel wool of scotch brite pads. Dont get too carried away doing that though.
Dec 25, 2012 | Heating & Cooling
I have a Magic Chef stove Model # 31001SAW. It is made by Maytag.I need to replace the ignitor switch in the oven. The light(flame) comes on but the gas does not ignite. I am assuming that the ignitor...
if the ignitor is not a brite red than it is not putting out the 3.5 amp's neaded to open valve.you can check the valve with a continueaty meter.remove the two wire's from the valve and check valve with meter,if valve check's good than ignitor is bad.
Nov 18, 2009 | Ovens
1987 nissan 300zx intermitent no spark no start
I have a 90z an there was a statement about the Ignitor Coupling.. Crank Angle Sensor is the problem sounds like.When it is heating up/Electric current doesn't flow as good. Change plug wires also because when they get heated it allows the fire to jump outa the wires. My Z before it thru a rod an blew a big hole in the oil pan would never start when it was cold. Never did really figure that one out.lol
Jul 07, 2009 | 1988 Nissan 300ZX
Jeep won start
check main fuse
year and kind of jeep ?
good luck
Apr 08, 2009 | 1999 Jeep Grand Cherokee
The fuel injectors
the first thing you should check if your car doesnt start is compression, then ignition, then fuel, in that order, even if you got spark and fuel without compression your going no where
Mar 24, 2009 | 1992 GMC Jimmy
Having problem with Frigidair PLGF389CCB oven will not lite.
you may need a new gas valve....but i think you should replace the ignitor first. the gasvalve won't open unless the ignitor pulls a certain amp draw to keep it open, since yours is just opening when you hit it, and closing when you hit it again, i believe it is the ignitor
Jan 03, 2009 | Frigidaire PLCF489AC Dual Fuel (Electric...
No start
do you have fuel pressure if not check the inertia switch in the trunk i dont know if it stops spark but it does stop the fuel pump from running good luck
Nov 30, 2008 | 1987 Lincoln Town Car
Frigidaire gas range FGF337
The ignitor should be almost a white hot color very bright . If it is orange or kinda reddish, the ignitor probably isn't getting hot enough to open the saftey valve. you could check the amp draw on ignitor , but most of the time if the ignitor isn't glowing bright almost white , that is probably the problem, besides that if and only if ignitor was good then i would look at the saftey valve. My money is on the ignitor.:)
May 19, 2008 | GE JGBP28 Gas Kitchen Range
Heating & Cooling Logo
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
