How to put the cartridges in the printer - Office Equipment & Supplies
  • Mike May 11, 2010
    What brand of printer?
Tip
The green light is blinking constantly and the printer won't print
When the green lamp constantly blinking this mean one or both print head are defective.Here we can find which cartridge is defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
This printer can work with only one cartridge.If you don't use color printing just remove the color cartridge.
on Oct 26, 2009 | HP Deskjet 3845 InkJet Printer
Tip
Often happens HP cartridges to overheat.In that case the printer not recognize it and the green lamp blinking constantly.In most case only one of both cartridges defective and need to be replaced.But how to know which one?
Here's how: Open cover, put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
on Oct 21, 2009 | HP DeskJet 3745 Printer
I put new printer cartridges in;left catridges lexmark x6570
maybe the cartridges you put are nt compatible to the printer or not properly place
Nov 29, 2009 | Lexmark X6570 InkJet Printer
Hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Nov 04, 2009 | HP DeskJet 5550 InkJet Printer
Green light blinks continuously, printer will not print. Has always worked well until now. Cartridges are in place, printer has paper, is connected to power and to computer. Is there a reset?
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.If this not help your printer need service.
Oct 29, 2009 | HP DeskJet 3650 InkJet Printer
Sep 29, 2009 | HP DeskJet 3650 InkJet Printer
I have a hp desk jet 5440 i put i a new tricolor
Make sure that your buying a new Tricolor as the same and Geniune too.
Only solution to this is put it properly inside your printer.
At first sometimes New Cartridge are being initial & calibrate by your printer before it works.
Power Off first your printer and put the cartridge inside. If the problem still exist then put back again your old cartridge and identify what is the problem occur before you put a new cartridge on it.
Sep 23, 2009 | HP OfficeJet J4580 All-In-One Laser...
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Can't load ink cartridges for PIXMA MP780 printer
Are you using OEM cartridges or refills?
If you still have the old cartridges, put them in and see if the PC gives you status for the empty cartridges. If the system correctly statuses the old cartridges, check that the new cartridges the correct ones for your printer.
May 02, 2009 | Canon PIXMA MP780 All-In-One InkJet...
12 people viewed this question
jasbo
jasbo
