Question about Kenmore Elite Oasis 27052 Top Load Washer
Washer starts to fill and then stops. beeps and F1 appears on panel. What does this mean?
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!
Posted on Sep 18, 2010
What foes Error code f1 mean?
Error Code Definition
  • According to Appliance Parts Quick, the error code is defined as a "Primary Control Failure." This means that the small computer installed in the washer has failed to send, receive or communicate with any other part of the washer.
Reset the Code
  • To stop the flashing and beeps on the washer, hold down the "Start" and " Stop" buttons for 60 seconds. If this does not work, unplug the washer for 30 seconds and plug it back it or leave it unplugged since it is inoperable.
Parts
  • The main problem is with the machine control assembly. This whole part needs to be replaced. Depending on your model, prices range from $150 to $260, as of 2011.
Process
  • The installation of the new machine control assembly, requires manual installation and opening the washer itself. If you have never taken apart or repaired a washer, a professional should provide the service and care. Contact Whirlpool support for more information on repairs and warranty.
Read more : http://www.ehow.com/info_7936847_whirlpool-washers-error-code-f1.html
F1 means the central electrical control unit, i.e. the onboard computer, has fatally failed. Unless you have both the skill and tools to test the guts of this computer, you're stuck replacing it. Good news, three screws at the rear to expose the control panel, then unplug one unit; plug in the new one. Just to be on the safe side, color code all the plugs and receptacles. At wholesale, the part is $175.00. CODE 083009 part W10189966 CNTRL-ELEC
Read more: http://forum.appliancepartspros.com/washer-repair/10337-whirlpool-f1-code.html#ixzz3dvEIxJdx
http://forum.appliancepartspros.com http://forum.appliancepartspros.com/washer-repair/10337-whirlpool-f1-code.html#ixzz3dvEIxJdx
Jun 19, 2015 | Kenmore Washing Machines
It has an F1 error code. It will start the water flow for about 2 seconds. Stops and beeps f1 on the screen. I hit the stop button and start again and have to repeat this 3 times before the wash machine...
The manufacturer has issued a remedy for the F-1. What you do is empty the machine of water and unplug it. Open the control panel and remove the pressure hose. Blow out the hose to remove sediment . Re secure it to the control and retry. No parts needed. F-1 Error infothemobilian_1223.jpg
Feb 01, 2011 | Kenmore Oasis HE 27082 Top Load Washer
My washer beeps and says "F1", I press STOP and START. "F1" appears again and I press STOP and START and then works. WHat does this mean?
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Aug 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer starts to fill then stops /now warsher wont wash
I too was having the same problem and I almost paid to have it repaired, which would have cost a few hundred dollars, thanfully I called the recall line after reading some of the other post on here and my machine was elgible for a upgraded on the control panel so didn' t cost anything for us. Sears told us that the F1 code is a miscommunication in the control panel, basically the machine is confused and don't know what to do so it stops and gives that code. Hope it helps!
Jun 19, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Code F1
Hi. this is a serious control fault that incorporates many situations. This (F) code calls for a service call. there may be a combination of control and motor faults here. if you own a multimeter(ohm), i would start by testing the control panel connections. if you are uncomfortable with disassembling this machine, i suggest making a quick service call. If you have any questions,please feel free to ask.
Please rate and god bless.
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
What does "F1" mean? The oven is out!
I think f1 is a problem with the oven control board. Look on the back of the oven for a tech sheet and it will tell you what the codes mean and what to check.
Sep 24, 2007 | Crosley CE35111AA Electric Kitchen Range
Kenmore Elite Oasis 27052 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
