Some of the reasons why sim card getting failed to register in your mobile
1.If your mobile was not unlocked you had get a message asking you to enter a PIN. Get the pin from an online vendor like http://www.theunlockarena.com/supported-phones/rs13wp7/ or http://www.unbblock.com/blackberry/rs18wp8/ .
2.With a warning that you have 10 attempts to enter the correct PIN code or it could be locked forever ,if you do not get that message it's "mostly likely" unlocked.BUT find a phone with a known working SIM and see if it will work and connect to the network.
3.This has to be a problem with the SIM card slot, which is soldered down to the logic board. It's possible that it's a mechanical problem , you might be able to open it up and discover that the card-detect switch is failing to detect SIM card insertion
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
The message you are receiving 'Insert SIM' is due to the SIM card not being registered. (ie., it was registered at one time but is not now.) As such, it cannot receive network information. And, your phone sees this SIM as nothing more than a piece of paper stuck in the SIM card slot.
A single SIM card is not used to activate - and then reactivate - an account. To get service on the phone, a new SIM card will need to be purchased.
If you're in doubt as to whether your phone will recognize a SIM, take your phone to one of your cellular provider's stores and let them test it.
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Hi, How to correct sim card error / insert sim card
Procedure to follow
Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it Step 2: If the sim seater/tray is not broken, clean the entire terminal. Step
3: If the sim seater/tray is not directly on the board, trace the
broken led and solder it, or you replace the broken led with another
sim tray. Step 4: If it is still not working, change the battery and
put a new battery, because a virus infected battery will always give
such problem. Step 5: Finally, if the problem still persist, then
check the sim card and replace with another sim card if the former is
bad because a bad sim card will always display such message as insert
sim card or sim card error.
1. If it is a new sim card wait till the service provider registers the sim. 2. If it was already working previously insert another known working sim card. If same message comes clean the contact points on the cell phone. 3. If above 2 dont work your phone IC is corrupted and you need expert help.
