Question about iRobot Roomba 560 Robotic Vacuum
My Roomba 560 has started to run in small steps as if it constantly meets an obstacle and turns around in a very small circle. It advances slightly, backs slightly and turns and then does this again and again.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
Sounds like your Roomba has the Circle Dance Error. Here is the fix for the Circle Dance.
Posted on Dec 16, 2012
    Scholar:
  • 58 Answers
It probably does think its met an obstacle. It could be the bump sensor switch remains pressed, one of the 4 cliff sensors on the front is dirty, or one of the 3 wheel drop sensors (left right and caster) is alarmed. Clean the sensors and your problem may resolve.
Posted on Dec 13, 2009
Roomba just turns in circles what could be wrong
What to do when the Roomba just goes in circles ' All about Roomba ...
https://roombafan.wordpress.com/2015/05/17/roomba-just-goes-in-circles/
May 17, 2015 - Single beep - Roomba is stuck or wheel is hanging down; you need to move your Rhoomba to a new location or check the wheels. Two beeps - this happens when the main brushes become immovable, so you need to check the brushes. Six beeps - the likely cause is a dirty cliff sensor or the robot is stuck on a cliff.
Roomba is backing up and circling. - Find Answers ' iRobot Customer ...
https://homesupport.irobot.com/app/answers/.../roomba-is-backing-up-and-circling. If Roomba backs up or spins in circles, run Roomba in an open area with no obstacles present for 2 minutes to determine if the robot will stop with an error ...
SOLVED: The Roomba just goes in circles, how do I fix this ...
https://www.ifixit.com/.../The+Roomba+just+goes+in+circles%2C+how+do+I+fix+this Oct 23, 2016 - Dirt and debris can cover the sensors and make the roomba believe it is ... When my Roomba turns on, it will only spin around in circles and ... Won't go straight; not circle of *****
May 30, 2016
Vacuum will not go straight
May 7, 2013
SOLVED: roomba 560 got wet and now it doesnt go forward ...
May 15, 2012
SOLVED: When I turn my Roomba on, it doesn't go forward ...
Apr. 25, 2011
More results from www.ifixit.com
iRobot Roomba circle dance - "fix" - YouTube
? 5:37
https://www.youtube.com/watch?v=sN03AWr1VAk Jan 21, 2008 - Uploaded by Scubaholic
Didn't feel like open my roomba at 10pm, so I just sprayed it with some canned air around the wheels and ...
Help! My Roomba goes in circles! - Robotic Vacs
https://robotic-vacs.com/2016/03/03/help-my-roomba-goes-in-circles/ Mar 3, 2016 - What to do if your Roomba just goes in circles. Roomba goes in circles. No, your Roomba doesn't have a mind of it's own, nor is it tipsy from ...
May 20, 2018 | Roomba Vacuums
My roomba makes a banging noise and goes around in circles
hi.
a roomba going round in circles is so common that it is known as the "circle dance" problem and there are videos on you tube showing you how to fix it, step by step. search for "roomba circle dance" on youtube.
i would not normally redirect you to another site, but these videos are clearer than any written instructions i can give here. watch a few of the videos as there are some slight differences to the basic problem and follow th eone that matches your symptons most closely.
hope this helps
Apr 17, 2011 | Vacuums
Roomba starts out in a circle goes wider and wider then all at once goes in circles.
when it starts doing that hit the start button again then wait a few sec.
Jul 19, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba 560 goes in circles. appears lost
You have a locked wheel switch that needs to be cleared. You will need to remove the top of your roomba and find which wheel switch is clogged and clear it.
Mar 14, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba 560 goes in circles then stops and blinks power indicator
Actually, this is the Circle Dance Error. You can find a fix for it here or if you want more information about the Roomba Circle Dance Error.
Dec 21, 2009 | iRobot Roomba 560 Robotic Vacuum
560 backs out of charging base then only turns in right circles
Yes, this is known issue and if your bumper moves freely, you might be facing a sensor fault caused by poor quality of components.
Here is a guide to fix it
http://www.schneordesign.com/Avi/irobot/roomba_mod2.htm
Have fun
Avi
Dec 05, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba 560 goes in small circles like it is in "spot mode". Wheels are clean and push up and down and turn easily.
Its likely to be a sensor problem, Either the cliff sensors or one of the 3 wheel drop sensors are the most likely problem.
Oct 08, 2009 | iRobot Roomba 560 Robotic Vacuum
The Roomba goes around in circles. If it
Are you sure it is 10 beeps ?
look in your user's manual, the beeps code is there with some
suggestions how to solve it
Have fun
Avi
Sep 02, 2009 | Roomba Robotic Floor Bagless Vacuum
Roomba 560, the small red light above the schedule button will not reset and the roomba will not run. The problem started when I the roomba sat dead for 12 hours. I tried the spot dock reset trick with no...
You should start by removing the "belly plate" of the Roomba and simply removing the battery to cycle power to the unit. If that does not solve the problem, it sounds like you need a replacement circuit board for the 560. That's alot trickier since iRobot doesn't like to sell those...they want you to send to them for service.
Your options would be to send to a reputable Roomba repair center like www.protechrobotics.com or you can buy a replacement PCA from places like www.RoboticVacParts.com and replace yourself.
May 07, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba 560 just goes in a small circle, will not go forward or backwards, then a red alert lights up ststing to clean it, which a throughly good cleaning has been done, gave this as a gift to someone and...
you cleaned the wrong thing there are small ir lights on the under side of the Roomba they look lke small red buttons clean the lenses with a q-tip and, alcohol. these infrared leds are the roomba's eyes you'd go in circles too if you couldn't see obstacles.
Jan 11, 2018 | iRobot Roomba 560 Robotic Vacuum
iRobot Roomba 560 Robotic Vacuum Logo
304 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
