The breaker in my rheem air handler has gone bad. The part number on it is QOU2603300. I have searched the web and found a QOU260. Are they the same parts?
  • 80 Answers
Yes, but the following numbers refer to it's mounting. This is a common breaker for rheem/ruud. You can easily pick these up at any rheem or ruud dealer in your area. This is best to ensure the same mounting options for your application.
Posted on Oct 04, 2009
Why is my heat pump tripping circuit breaker continuously?
Probably a weak breaker. I would change it and see if it happens again. If the problem continues call a hvac guy out
Jan 10, 2016 | Rheem 2.5 Ton 13 Seer Heat Pump -...
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Mar 30, 2014 | Rheem 4 Ton Air Handler - RHLLHM4821JA
Hi, I have a Rheem RHSA HM4221JA air handler with
Sounds like a relay inside the air handler is stuck 'closed'...
Oct 17, 2013 | Rheem Paloma PTG-74PVN / RTG-74PVN...
What number amp breaker do I need for a 5 ton rheem AC not the air handler
Hello, you will need a 2 pole 40 amp breaker for a 5 ton unit.
May 10, 2012 | Heating & Cooling
I had an Air Conditioner installed and the company has since gone out of business, now with an upcoming energy audit, i need to find my ARI and Evaporator Coil # from my RHEEM A/C. Any suggestions?
The number should be on your furnace or air handler (The thing that's inside your house) It should have a m# on the inside of the door. Make sure unit is off when you remove door. As far as the ARI hopefully once you take down that number you can go online and find the rest of the info about your unit.
Feb 08, 2011 | Heating & Cooling
I just installed strip heat Rheem RXBH-1724A10J 10KW 208/240/1/60 into Rheem 14AJM36A01, RHPNHM3624JC, 3 Ton 16 SEER Air Conditioner Split System W/ GE's Variable Speed thermostat Pro 701 and it ran up...
This will help you.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Jan 20, 2011 | Heating & Cooling
4 ton rheem 3yrs old thermostat
It is possible that the relay in the thermostat for "cooling" has gone bad. The relay that runs the blower is different than the condenser relay. Check that you have 24v AC coming from the t-stat to the "y" terminal at the air handler. That same "y" wire should go out to the condenser, make sure then that you have 24v out there. If you have 24v at the condenser then see if the contactor is pulling in. If not then you may have a loss of charge switch that is stopping the current to the contactor. See if you have 24v to the coil of the contactor. If the contactor is pulling in and power is going to the compressor then the compressor has failed. If this is the case the condenser fan will be running but the compressor is not. If neither the condenser fan or the compressor is running then you have a problem in the 24v circuit, which could be a bad wire or a safety switch.
As you can see there are a number of possibilities for your problem. You will need to methodically go through everything to eliminate the possiblities till you isolate the problem,
I hope that this will help you to solve your problem and get you cooling again!
Thanks for using Fixya!
Heatman101
Nov 23, 2009 | Air Purifiers
Is there a rest button for rheem 3 ton air handler
Must be a bad capacitor or a bad contactor.
I have some repair pictures:
OUTSIDE CONDENSER BLUES
Aug 23, 2009 | Ruud UAKA037 Air Conditioner
Heating & Cooling Logo
399 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
