Question about Sport & Outdoor - Others
I know this is the parts email but I'm really not sure of the problem> Could you foreword this to someone who might help steer me in the right direction. I have a 1350 Merc. with 3 side bowl carbs. With the motor upright I can pressurize the fuel system and there are no leaks. With my experience with cars this tells me that the needle and seat are working properly. Though I could be wrong. If I tilt the engine more than a few degrees all three carbs start to leak fro the main air intake. I removed the fuel filter and needle and seat assembly with the carb just under half full. As soon as the engine was tilted with no pressure from the pump the carb started to leak. Can you tell me what I'm missing so I can order the right part? Thank You.
    Top Expert:
  • 76,649 Answers
We are not a parts service, u need to get in touch with the manufacturer of the engine, we have no manual for parts, we are strictly a technical service soprry
Posted on Oct 04, 2009
I have a new power steering pump. should i also replace the filter?
There is no filter for the power steering. That car has Variable Assist Power Steering (VAPS). Make sure the pump is really the part you need before installing. There are a lot more components to that steering system that could cause problems. Could be pressure switch or control valve. I don't know what your symptoms are but, you should have someone look at it that is familiar with that system and able to properly diagnose the problem before you start changing parts.
Oct 02, 2014 | 1998 Ford Taurus
I need to scan a signed letter and send it through email to someone......put the signed copy into the printer and hit scan which it did but now what............how do I get it to be part of an email?? ...
1 Turn on your computer and printer, and make sure they are connected.
2 Load your original document.
3 Click Start >> All Programs >> Dell Printers >> Dell Photo AIO Printer 964 >> Dell All-In-One Center.
4 Click Preview
You should now see a preview of your scanned document.
Adjust the dotted lines if they are not completely around your document.
There is a 'Send scanned image to:' option -
You can save the document to your desktop.
Now go into your mail program and when in the body of the email, use your programs features to attach the scanned file document to your email (you did not specify the email program you use, so this is just a general mention of attaching the file to your email).
May 04, 2011 | Dell Photo 964 All-In-One InkJet Printer
Hi...I just bought the Logitech Driving Force GT steering wheel and pedals...the pedals work fine, the buttons ON the steering wheel work fine...but the actual steering part DOES NOT work..so I can...
-Check if the connections are plugged in properly -Does the wheel calibrate (turn left and right and then centres) when you turn on the wheel. -Doe the game support the wheel? - Plug the DFGT into the USB port 1 of the console AFTER you turn on the console. So turn on the console and then plug in the DFGT into the USB port 1 and turn it on.
ALSO if you are using the DFGT for pc, make sure you install the "Logitech Gaming Software" from the logitech website =
Sep 25, 2010 | Logitech Driving Force GT Wheel for...
Someone else knows my log in password facebook and yahoo i want to change it
Steps to change the yahoo email password:
1st loggin to the yahoo email page right side corner option tab will be there click -->Options -->mail options-->account information then it will ask your password give the your account password.
After loggin to that page in the 3rd option called change your password click that option and then you can change your password what ever you want.
Steps to change the facebook password:
1st loggin to facebook site
Then right side corner Account tab will be there drop down that tab click-->Account settings
Then in that account setting page click--->setting -->password.
You can change the password.
Sep 15, 2010 | Computers & Internet
I want to know what is the name of the part that is connected to the steering rack and runs up and connects to my steering wheel. It looks like it has a yoke and universal joints on both ends.When I turn...
some parts stores and dealerships just call it the steering shaft,and some call it a sector shaft even though it really isn't,if there is a clicking noise it maybe the bearing assembly in the end of the steering column where the steering column exits the firewall & just after the auto transmission shift linkage connects to the arm on the column there is a bearing in there and it can get a build up of grime in it sometimes you can spray it with wd-40 while someone rotates the steering wheel back and fourth and after that spray a little bit of chain lube in it.If that is not it have the air bag "Clock Spring"and components checked out hope this helps point you in the right direction
Jun 19, 2010 | 2002 Dodge Durango
Sloppy steering 96 Ford Bronco
You need to check all of you front steering components have someone turn the steering wheel back and forth. While you lay on the ground check all joints and components for play then check your steering shaft under the hood see how far steering wheel moves to each directions to when your tires start to move your gearbox has an adjustment on it that can be adjusted it looks like a screw with a nut at the bottom loosen nut a few turns and hold it with a wrench then take screwdriver and turn screw about 1/4 keep checking wheel for play you can tighten to much so keep checking that wheel turns back when you let go if you have any loose joints undernieth replace that part
Jun 22, 2009 | 1996 Ford Bronco
Power steering fluid leak (1999 grand am gt)
sounds like a high pressure hose or rack and pinion would have to get underneath and take a good look at it while someone starts it and turns the whell all the way to tyhe left or right and hold it there till you see the leak
Mar 09, 2009 | 1999 Pontiac Grand Am GT
Power steering problem
it is called cavitation something imploded or one of your check valves are bad
Jun 19, 2008 | 1997 Pontiac Grand Prix
Replacing Capacitor on LCD Monitor
That is good advice. Always replace with same or higher voltage rating. Also make sure it is put in the right way around.
Sep 21, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sport & Outdoor - Others Logo
27 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
