Question about Waring Pro WC1000 Coffee Maker
We have had our WC1000 coffeemaker for 6yrs and have had no problems with it until recently when the blue light does not go out and the green light does not come on at all. It still heats up the water and we are able to make coffee. Can this problem be fixed?
  • 34 Answers
Try bringing it to the specialist or the store where you bought it.
try this link if you need to replace it.
http://www.coffeemakerwizard.com/
Posted on Feb 02, 2010
WC 1000 Coffe Maker doesn't heat the water
Posted on Dec 08, 2009
  • 10,865 Answers
Chances are your pot is a bit clogged with coffee oils. I would run a couple of cups of vinegar through it followed by three pots of water to attempt to remove those oils.
Posted on Oct 04, 2009
Why doesn't it turn on?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Apr 20, 2016 | Televison & Video
Connection problem to phone light turns green instead of blue
Try resetting your headset by pressing power key and volume up key, until the LED flickers in different seqence. after a while try connecting with your device. it should work.
May 24, 2010 | Jabra BT350 Bluetooth Headset Headset
Keurig won't turn on, power light just blinks green
Try picking up the handle where you put the coffee and kinda slam (not too hard) back down. I found that resets the coffeemaker. Also when you make coffee I also noticed that you when the water is hot you have to pick up the handle again and put it back down then the two blue lights start to blink and you decide what size cup you want.
Apr 12, 2010 | Keurig Elite B40 Coffee Maker
Saeco Vienna Coffeemaker won't heat/reach 'ready' state
May be time for a new machine.
Its either the electronics or the boiler, or worse. Both.
Vienna's have a typical life expectancy of about 4 to 7 years. 10 years is very commendable.
If the electronics and boiler are both bad it will end up costing almost as much as purchasing a new machine.
Aug 08, 2009 | Saeco Vienna De Luxe Espresso Machine
The ''clean'' light is on my cusinart coffee maker
Let a half caraffe worth of distilled white vinegar sit in the water reservoir for about an hour. After the hour, turn the coffeemaker on and let it brew the vinegar until a small amount of vinegar appears in the caraffe. turn the coffeemaker off and let it sit for an additional 20 minutes. Then turn the coffeemaker back on and let it brew the rest of the vinegar. Then run a full caraffe of plain water to flush the vinegar out. If the self-clean light remians on - unplug the coffeemaker for 20 minutes or longer - if you unplug it for any less than 15 minutes, the coffeemaker will not reset itself. You should be good after that - as long as you do some sort of vinegar/water cleaning once a month henceforth.
-Tha Mp3 Doctor
Mar 13, 2009 | Cuisinart Coffeemakers
Braun Coffeemaker Programming
to prgram the automatic operation, press the automatic buton until the green pilot light begins to flash. The time "12:00" or the previously programmed time appears on the display. When the green pilot light begins to flash, release the button and press the hour and minute buttons until the correct shows; ensure the hours are am or pm. After programming is completed, the green pilot light will go off after 5 seconds.
Dec 08, 2008 | Braun FlavorSelect KF 180 Coffee Maker
Waring pro wc1000
Try plugging it into another GFI outlet. If it still trips, it's a problem with the coffee maker wiring and is cheaper to replace it than fit it.
Aug 25, 2008 | Waring Pro WC1000 Coffee Maker
WC1000 GFI
You're not alone.  Same problem here.  Breakaway power cord on my Waring deep frier burnt to a crisp.  Don't known about you, but I'll never buy Waring products again.
Oct 03, 2007 | Waring Pro WC1000 Coffee Maker
Waring Pro WC1000 Coffee Maker Logo
331 people viewed this question
Top Waring Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Waring Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
