Question about Iomega HDD External Desktop (32660) 80 GB Hard Drive
My external hard drive is not showing up on the desktop
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 04, 2009
  • 51 Answers
Go to computer managment and enable drive there and thn it will work fine
5 Suggested Answers
JLPicard
  • 14 Answers
SOURCE: Storage and Media - Hard Drive External
Here is a link to Seagate's website Download area. All manuals should be available for download from there: MANUAL
Posted on Nov 17, 2007
SOURCE: power supply for Maxtoe Basics External Hard Drive 500GB
Is 12VDC 2,0A the inner pin is + and the outer pin is -
Posted on Dec 04, 2008
  • 1043 Answers
SOURCE: computer doesnt read the external hard drive anymore
It sounds like the hard drive head crashed when you pulled the power plug. Unfortunately if you can't get drive to be recognized, you won't even be able to run any diagnostics. You will have to take the drive to an authorized repair shop who will have to check the electronics to see if the head will respond. Unless you have data on your drive that you absolutely need, you will probably save a lot of money by replacing rather than repairing the drive.
Posted on Jul 10, 2009
  • 28 Answers
SOURCE: seagate external hard drive green light blinking
that problem means that it is acsessing the files on it. it is not a worry for you.
Posted on Sep 14, 2009
Toshiba 1TB external hard drive does not show on menu
Open the file and cick save as. In the window that opens, select the external drive in the list.
or, right click the file and click copy. Open the external drive in my computer and click paste.
Mar 16, 2014 | Toshiba Computers & Internet
How do i fix an I/O Device Error on External Hard Drive?? or is it need to be taken in?
You can disassemble the drive and connect it internally to a desktop computer. The hard drives inside of these external enclosures are identical to ones found in desktops or laptops. The drive should show up as another hard drive on your machine where you can get all of the data back.
The circuit board inside these drives that handles the data transfer through USB can get worn out and sometimes do go bad.
Disassembling the drive will destroy the enclosure usually.
Jan 25, 2011 | Western Digital 250GB MyBook External USB...
I have a minimax 1TB external hard drive. All of a sudden it doesn't show up on my desktop any more. Any suggestions?
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 24, 2010 | Iomega MiniMax Desktop - Hard drive - 500...
External hard drive has been working fine but now doesn't appear
Have had issues with an external Toshiba hard disk not showing up as well.
Found a solution here:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Hope that can help you too.
Apr 02, 2010 | Buffalo Technology 1TB DRIVESTATION COMBO...
Acomdata 250 external (SATA) hard drive not showing up on desktop
be safe
go on line to acomdata web site and down load the driver from there
Oct 11, 2017 | Acomdata (HD250SE5-72-PCI) (HD250SE572PCI)...
Simpletech 250GB STORAGE S
try plugging your HD into another desktop/laptop to see if your HD is functioning well on a different computer. Could be the USB cable problem.
Feb 01, 2009 | SimpleTech SimpleDrive 160 GB External USB...
External hard drive not appearing on desktop
try start computer into windows now connect drive
now restart coputer leave drive connected when back in windows it should read it
Dec 21, 2008 | Mad Dog Multimedia Dominator (MDED1F)...
Hard Drive problem
Have a simpletech 96300-40001-001 external hard drive from couple years ago I bougt at Sam's. I have lost the installation software. It will now work on my laptop, the computer I bought it for because I installed it there when i bought it, but it will not work on the others (not recognized) and I cant seem to find a download of drivers that will make it work on this desktop and my other laptop. Do you know where I can get a copy of the original installation CD that came wih the hard drive. I am running XP Home on all three computers.
wayne williams
waynepat1@cox.net
850-865-7026
Jul 21, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Iomega HDD External Desktop (32660) 80 GB Hard Drive Logo
424 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
