Question about RCA DRC200N
Fuse T1.6L250V I have a blown fuse. I replaced it with 250V, 5A and they bursted. I looked up the specs for the original fuse and looks like they are 16Amps. Is that correct ? I have a 15A fuse 250V rating. Would that work ?
  • pwr2005cfg Dec 04, 2008
    I also have the same fuse blown, but from a Kustom PA system.
    T1.6L250V
    1.6 250V from Radio Shack won't work because it isn't a Slow - Blow fuse which is what the T indicates.
    Even in today's world I cannot find the replacement fuse anywhere.
    The Digi-Key link I saw elsewhere was not for the correct fuse type. I need a glass tube with metal ends.
No that wont work
Posted on Sep 05, 2008
    Problem Solver:
  • 10 Answers
The fuse which you have used is of correct rating 250v/5A, the switching regulator of the SMPS primary section is faulty, so the fuse blows of continously
Posted on Dec 22, 2007
Where can i get a power supply for intex saltwater system model 8110?
There is a 5A/250V fuse in xformer epoxy filing inside plastic case.
Lot of work to get access but xformer is OK and I had replace fuse to get unit back ON. Fuse is placed between AC line and xformer connections inside epoxy. Take a look on photos!7_26_2012_2_47_37_am.jpg7_26_2012_2_47_54_am.jpg7_26_2012_2_48_04_am.jpg
May 24, 2012 | Intex Automatic Salt Water System for ...
Electrolux oxygen 3 fuse
The fuse on my ELECTROLUX Oxygen3's sumo board did have clear markings: F5AL250V - this is a 5A/250V 20mm fuse made by BEL FUSE, however, any other such fuse should work. The fuse on my board was blown (luckily, what caused it seems to be a glitch as replacing the fuse was all that I had to do). I got 5A/250V 20mm fuse from RadioShack and, expecting that this could happen again, I also installed a simple (5A/250V-rated) automotive fuse holder (also from RadioShack) (the only fuse holder that was available at a local store) and it works wonderfully now. Should the fuse blow on me again, I should be able to replace it in less than 3 minutes.
Feb 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Fuse
Its actually a 7A 250V fuse. Unfortunately, I have not had any luck finding it. Also, 7A 250V fuse come in two sizes, a large and a small. So you will need the small
Aug 03, 2008 | Belkin TuneBase FM (F8Z049-BLK) Car...
Durabrand rb-22j1a wine cooler----no power to unit at all after being plugged in, all fuses are good.
I had this problem, no power, no light. It was the power supply output fuse. It appears to not be blown, but a continuity check across the fuse shows an open. Unsolder and replace the 5A, 250V fuse with some locally available Radio Shack parts (holder - 270-739, fuse 270-1071). Access to the power supply board is on the rear, remove the screws on the plastic plate, including the one hidden under the QC sticker. While you are in there, clean the fan and the aluminium fins on the heat sink (cools the Peltier device).
If your fuses are not blown, look at the electrolytic capacitors (the black or blue round metal cans with the aluminium X on the top) to see if they are bulging. Replace any that are bad (a common problem in switching power supplies).
Hope this helps,
Andy B
May 05, 2008 | Heating & Cooling
Philips 60PP9202/17F Fuses are gone
I can't believe he pulled them all, but here's a list of all the fuses and their ratings from the service manual:
S 1000 Fuse, T 5A IEC
S 1300 Fuse/Clip, 5 Amp, 250V
S 1801 Fuse, 2 A, 250V IEC
S 1804 Fuse, LT 1A, 250V, IEC
S 1805 Fuse, LT 1A, 250V, IEC
S 1700 Fuse, 2 A, 250V IEC
S 1701 Fuse, 2 A, 250V IEC
1003 Fuse, 500MA, 50V, UL
Jan 12, 2008 | Philips 60PP9202 60" Rear Projection...
PT-40LC12 fuse problem
I went here for a tech manual for the Panasonic tv.
http://www.ManualsParadise.com
then ordered
Manufacturer: Panasonic
Part Description: FUSE
Part Number: LSJA0411-1
from PartStore.com
it was mounted to the case that holds the lamp. had to remove the back panel, etc. Also think I had to splice in the fuse or something. was a while ago.
mine is broken again. this is getting old between lamps and repairs.
Oct 24, 2007 | Panasonic PT-40LC12 40" Rear Projection...
HAier HVT12ABS wont turn on
I had the same problem. My 18-month old Haier HVT 12A wine cooler stopped working. I unplugged the unit, opened the back, and saw the circuit board and the two fuses soldered to the circuit board. The top fuse was OK. The bottom fuse, labelled FUSE2 5A/250V on the circuit board, was blown.
I went to Radio Shack and purchased a spring-loaded push and twist fuse holder ($3) and a bag of fuses (another $3). I soldered the leads from the fuse holder to the top and bottom of the dead fuse 2, inserted a new fuse, plugged it in, and it has been working fine ever since (1 month). If the new fuse fails, it is easy to replace. Total cost $6.
Oct 10, 2007 | Haier HVT12ABS Compact Wine Cooler
Thermal fuse
i purchased a NTE8115 from my electronics supplier, closest I could find.  Radio shack also has them.
Sep 25, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
May 15, 2007 | Samsung TXR3079 TV
NO POWER, Yes blown fuse.
Was this the 220 ohm in the power supply??? and if the 5 amp blew right away then it probably took out the bridge rectifyer with the power surge that comes alog with hurricane damage to the power lines as I used to live in florida and repaired lots of sets damaged from storms!! After you check the bridge rectifyers I would start looking to find any other shorts. First measure across the ac line with the fuse replaced but not plugedf in . If its shorted check what I mentioned before if its good after you replace the shorted parts you maybe in luck. need more assistance go to sams photo facts download a schematic and we will trouble shoot this together if you post it here so i can look at it. good luck
May 02, 2006 | RCA P52929 52" Rear Projection Television
RCA DRC200N Logo
2,795 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
