Question about Nikon D90 Digital Camera with 18-200mm lens
Shutter release often will not function at some focal lengths, and that doesn't seem to be consistent in any given light. BUT remote shutter release works every time!
SOURCE: nikon d40
I had exactly the same problem, i tried everything,battery out, sd card out , lens off etc...nothing worked.Completely by chance and irritation i repeatedly pressed the shutter butten over and over
( without the lens attached ) till it didn't react at all.On my LCD i got a normal menu so i put the lens on and bingo it was fixed, still works fine.I think maybe the shutter was out of alignment.
Hope this works for you.
Olly
Posted on Jun 01, 2008
SOURCE: nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
SOURCE: Error. Press shuter release button again
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
Posted on Oct 23, 2008
dbarchitect
  • 150 Answers
SOURCE: Nikon d40x shutter stuck
The manual (pg 112) simply, and unfortunately, states this message "Press shutter release button again. If error persists, consult with Nikon-authorized service representative".
Some questions that might help: have you had the camera in some extreme conditions, damp, sand, etc. Clean the shutter button really well. Maybe use a small air blower and clean in the shutter release creases.
In the end, if the error continues, it will need to be serviced.
Posted on Jan 21, 2009
SOURCE: Nikon d60 shutter release error
press shuter release button again
Posted on Aug 11, 2009
What is T Mount Telephoto Zoom Lens with 2x Teleconverter
The T-mount is a universal thread developed by Tamron which allows various adapters to couple a lens to a wide variety of camera brands. If a lens is listed as having a T-mount, it means that the lens can be coupled to your camera if you have a T-mount adapter for your camera.
A 2X teleconverter (often called a doubler) enables a lens of a specific to be doubled. For example, the lens referenced above actually is a 650-1300 lens but with the 2X teleconverter the focal length can be doubled to a maximum focal length of 2600.
I have an Opteka 600-1200 telephoto lens which I consider to be a decent lens for its very low price. I also have a doubler which came with my camera kit. That means I can increase the focal length of my lens to 2400 but I cannot imagine any reason to do so. At it's full zoom 1200mm focal length, this lens is very difficult to handle and must be used on a tripod with a remote shutter release.
It is extremely time consuming to focus and must be focused very accurately because it has almost no depth of field. At 1200 mm, the slightest breeze or vibration will cause the picture to go fuzzy from movement.
The lens is also large and does not fit conveniently in a camera bag so it rarely goes with me unless I know for sure that I will need it. It is not particularly good for sports action shots because the action will be over before you are ready to shoot the picture. With very bright light (such as the mid-day sun) and pre-planning and pre-focusing you might be able to get some interesting sports action shots. Say you're at an automobile race and you know a car will be coming into view at a certain spot, you can set up for that spot then trip the shutter when the car pops into view.
All that being said, I think this is a good lens to have in my bag without spending $10,000 plus for a really good lens of this size.
Feb 08, 2013 | Opteka 650-2600mm High Definition...
Nikon D3100 shutter "problem"?
Are your pictures properly exposed and are they sharp or are your pictures degraded? Is that 1/3-second you describe a delay between the time you push the shutter release and the time the picture is taken or somthing else? Check to make sure you're in the proper shutter release mode (slider switch to right of the mode dial). Also, your self-timer may be turned on. Your camera allows you to set a 2 or 10 second delay from the menus. If it is set to 2 seconds and turned on, it might seem like a 1/3-second delay. If that doesn't help, you camera is covered by Nikon's warranty. Contact Nikon Service at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday.
Aug 27, 2012 | Nikon D3100 Digital Camera
My photo shot button fell out that takes photos
Avoid camera shake. Watch your shutter speed. As a general rule, you should not allow this to fall to a speed slower than the reciprocal of your 35mm equivalent focal length. However, if you're using digital (or are willing to use your film up a bit quicker), you can try taking several shots in succession and hopefully one will have a satisfying level of sharpness. Turn on vibration reduction (also called "image stabilization", depending on the manufacturer), if you have it. When VR/IS is on, the lens element(s) or image sensor move so that the image stays in place when projected onto the sensor. As a result, camera motion is less likely to affect the sharpness of your photographs. Turn it on whenever the lighting conditions makes getting a sharp picture difficult. Keep it off when you're shooting on a tripod; it isn't needed and actually makes your photographs less sharp.
Use a shorter lens (or zoom out) and get closer. Remember that, according to the reciprocal rule of photography, reducing your focal length will give you less camera shake at any given shutter speed. Additionally, when you're using a variable-aperture zoom, you can often use a larger aperture with shorter focal lengths. Furthermore, getting closer might force you to be more creative when framing the picture.Use a tripod or a monopod If you're using an SLR and find yourself with so little light that you have no choice but to use long exposures, you might want to invest in a remote release cable. If your camera has a mirror lock-up (also called exposure delay mode), use it; this will stop the vibration from the mirror from affecting your images. Check your camera's manual to see what it's called. Mirror lock-up has two definitions; the other definition refers to when the mirrors and shutters move out of the way after you click the shutter button so that you can clean the image sensor without the sensor being active. If your camera doesn't have mirror lock-up, you can use the self timer.
Jul 28, 2012 | Canon PowerShot A510 Digital Camera
I have my Olympus FE-160,the problem is whan I take pics,it came out all blurry and the color changes...am not sure whats going on?is there any way that can be fix?
HERE'S THE ANSWER TO YOUR PROBLEM:
The three possible culprits of your camera are the following:
1. Long Focal Length
2. Slow Shutter Speed
3. Wide Apertures
Here's what you've got to do:
1. Increase your shutter speed so that it is greater or equal to 1 over the focal length.
2. Attach the camera to a tripod to avoid camera shakes.
3. Keep your shutter speed to 1 / 60 - 1 / 125 when holding the camera in your hands.
4. Keep your aperture around f8.0, especially with along focal length.
5. In case, you buy another camera model, see to it that the camera is featured with image stabilization (IS) technology.
Thank you. Your problem is solved...
Jul 10, 2011 | Olympus FE-160 Digital Camera
Picture from camera not clear
There could be any number of issues, unfortunately, your problem description doesn't give enough information, but here are some ideas.
Likely, the culprit is either a problem with focus or a problem with camera shake. In either case, brighter light and/or using a flash should help as auto focus works better in bright light and the shutter speed is faster in bright light. (With a faster shutter speed, there is less time for the camera to move while the image is recorded).
If using auto focus, be sure that the focus point illuminates on your main subject.
Many point & shoot cameras have an indicator if the shutter speed is too slow for a hand-held shot (typically occurs with low light). If this is indicated, then use a tripod (or brace your arms/elbows to make a human tripod) or increase the ISO of the camera (may have to go to manual mode) to avoid camera shake. Holding the camera at arm's length to look at the display while taking the picture is a recipe for camera shake & blurry pictures. You can rest the camera on a shelf and use the timer so that your hand motion pressing the shutter button isn't an issue. If using an SLR, ensure that the shutter speed is faster than the reciprocal of the focal length. That is, for a 100 mm lens, the shutter speed should be faster than 1/100th of a second.
Feb 25, 2011 | Cameras
Len shaking when snapping
Presumably your images are blurred because of camera shake? What shutter speeds are you using? As a rule of thumb, don't use less than the focal length you are using so if shooting at 60mm, have a shutter speed faster than 1/60th of a second, if shooting at 200mm, make sure shutter speed is more than 1/200 of a second
Mar 05, 2010 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
My pictures are blurry
It could be several things.
  1. What is the ISO and shutter set on? Low ISO and moderate light will force the shutter to go slower. Any shutter speed less than 60 will be blurry, getting blurrier and blurrier as the number goes down. You could try raising the ISO to get he shutter above 125 and see if that helps.
  2. It could be that the lens is too strong for the shutter speed being used. Generally make sure the shutter speed is at least the same or higher than the largest focal length of the lens. Example: A 70-300 lens should be used with a shutter speed of at least 300, but higher like 500 or 1000 would be better.
  3. Make sure you are holding the camera correctly, with both hands supporting the camera, you elbows tucked close you your body, your left hand supporting the full weight of the cameras, your right hand working the controls. Make sure you are squeezing the shutter button lightly and slowly, no punching ig or stabbing at it. This fast jerky movement can cause blur up to very high shutter speeds if you are not careful.
  4. Make sure the lens is functioning properly, that the m/a switch on the slide of the camera/and or lens is set to A for auto focus.
  5. Make sure the Auto focus sensor is set fo the broadest largest setting or that the focus sensor is set for where you want it not off the the side.
Nov 27, 2009 | Nikon D60 Digital Camera
Tamron teleconverter 2x AFs compatibility.
When using a TC, as the perceived focal length increases and the aperture falls off, AF struggles to work except in very bright light.
Jun 09, 2017 | Tamron Autofocus 2x Teleconverter Lens for...
Lower half of photos dadrk when printed
Set camera to B , open back door and release the shutter and keep it open while you inspect focal plain area. Is the shutter fully opened ? If you release again is the shutter opening completely and closing completely ? While the shutter is fully opened on B look through the shutter/ mirror box area is anything obstracting your view ? Seems like one of the shutter curtains is not opening properly and shutter will need servicing. Please note that it may not be economical to repair : $ 150-200 if the shutter block does not have to be replaced completely.
Apr 22, 2007 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Nikon D90 Digital Camera with 18-200mm lens Logo
19 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
