Question about RCA CC4393 VHS Analog Camcorder
How do I get the RCA video camera CC4393 to go out of the demo mode? The camera has been working fine for years, but now it started to go into demo mode every 25 min, lately, it goes into the mode every 5 min. The only way to get rid of it is to shut off the camera and turn it back on again.
techman
  • 3130 Answers
SOURCE: RCA 20f510td
Sounds like a thermal breakdown of a componet. it could be in the main power supply regulaor supply or even a bad capacitor in the power or sweep supply. In some cases Zener diodes can break down and change values after warm up. In some cases also bad solder connections in the highvoltage section, or the power supply can cause this problem. It is a hard call without being able to look at the set. Just a few leads on where to go first. most likly a combo unit, such as this one , would cost you more then a new one these days. Good Luck PS Please dont forget to rate this thread.
Posted on Dec 10, 2006
  • 308 Answers
SOURCE: rca 52 inch rear projection
This is a problem common with some RCA/GE TV's. The fix in the past was to install a capacitor between ground and pin 15 of the microprocessor which keeps a data signal riding on the video stream from muting the sound on most stations. By installing this capacitor, you would be disabling the closed caption feature so that feature would no longer work. An authorized RCA TV repair shop may be able to give you more information.
Posted on Apr 12, 2007
  • 899 Answers
SOURCE: rca 32v432t tv plays,turnsoff,turnson, and stays in autochannel search mode
your going to need to do a resolder of dry looking solder jobs and or poor solder jobs
this could also be your front control board , try disconnecting it and see if the tv stays on
it is possible that the sensor has gone bad or the crystal needs to be replace or worse the EEPROM
my rca 27 in was doing the same thing , i resoldered the board and it worked great for 7 months
so do a resolder of all suspicious solder and heated components
then let me know what happens
also what is your model # for your rca tv ?
also one of rca's kits for repair is some solder and paste , so that should tell you something in its self about rca repairs ( the solder with the paste is supposed to make it handel heat better )
please give a fixya rating so that if you need more help in your tv , I can continue to help you further , thanks
electech
Posted on Nov 08, 2008
SOURCE: RCA Scenium: l5000yx1 - turns on and off by itself.
Mines did the same thing. I had to get a new bulb $200 on line and pay someone $200 more to fix some wires that had pulled apart when we changed out the light. But now it works great!
Posted on Nov 22, 2008
romsky79
  • 822 Answers
SOURCE: I have a RCA L32HD32D, will be on for 1 to 5 min. later goes off
check secondary power supply. check capacitors and apply fresh solder.
Posted on Jun 01, 2009
Demo mode d3100
Despite what Rajdeep says, the demo mode on the D3100 allows you to take a picture without a memory card and review it. This is primarily intended to let you see how the camera works --- a demonstration. If you want to get out of the demo mode, you must insert a memory card. Without a memory card, the camera has only enough memory to hold one picture, and this picture will disappear when you turn the camera off.
The demo mode is discussed (briefly) in the "Slot Empty Release Lock" section of the manual (page 147 in my copy).
Aug 06, 2012 | Nikon D3100 Digital Camera
No video on the camera viewfinder or miniscreen
At seventeen years old, it is well beyond the expected lifespan of any domestic camcorder. Replace it.
May 23, 2017 | RCA CC4393 VHS Analog Camcorder
RCA RS2663 not working at all
rca typically have a demo display series of event or information that lights up on the display have you tried disabling the demo mode?
Feb 17, 2009 | RCA RS2663 Shelf System
No power is supplied
More to the point, why was your little child using 'shears' unsupervised ?
Mar 08, 2017 | RCA CC4393 VHS Analog Camcorder
CCD-TRV68-Sony HI8 HandyCam
Hi: Try going into the menu section,check to see if camera is in the DEMO MODE. Hope this is the problem,good luck. zeffy57
May 28, 2007 | Sony Handycam CCD-TRV68 Camcorder
Where can I get a new power supply for my RCA CC4393?
Type your model into Google, add "AC adapter", then click "More>>" and choose Froogle for shopping choices. Accessoriegenie.com is one good source.
Sep 21, 2006 | RCA CC4393 VHS Analog Camcorder
Can't playback
For Models: CC4362, CC4393, CC4352 Check to make sure the CAMERA/OFF/VCR switch is set to VCR.
Sep 06, 2005 | RCA CC-432 Camcorder
Black bars in the picture
For Models: CC4352, CC4362, CC4393. Your camcorder has a wide format recording mode that lets you make recordings compatible with the 16x9 format. When 16x9 is activated, the camcorder records black bars at the top and bottom of the picture to produce the wide-screen (movie) effect. This is also known as "letterbox" recording. Do not use this mode unless you have a compatible 16x9 TV. When played on a regular TV, black bars appear on the screen. If the 16x9 feature is activated on your camcorder and you want to turn it off, press REC/PAUSE to pause recording, and repeatedly press DIGITAL EFFECTS until no digital effects display appears.
My camcorder is turning off by itself.
For Models: CC4252, CC4352, CC4362, CC4392, CC4393 If your camcorder is left in Record-Pause or Play-Pause for several minutes, it turns off automatically to prevent wear on your tape. Set the CAMERA/OFF/VCR switch to OFF and then to CAMERA or VCR to turn it back on.
My camcorder doesn't work
For Models: CC4252, CC4352, CC4362, CC4392, CC4393 You need to reset your camcorder. Follow these steps: * Remove the power source. * After one minute, gently press the RESET button with a nonmetallic pointed item until you feel a "click." This resets the camcorder to the factory settings and erases the date, time, and custom settings. * Wait for at least one minute after resetting the camcorder to attach a power supply.
RCA CC4393 VHS Analog Camcorder Logo
Top RCA Video Cameras Experts
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
ray gallant
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
