Question about Archos 605 WiFi Digital Media Player
Frozen blue screen
I have a frozen blue screen on my archos 605...it won't turn off. Is there a way to restart or hard reset?
  • lil insane Dec 26, 2007
    my archos 605 wifi says would you like to recover your system? i clik on everything but it just comes back and back what should i do?
  • clairebaire Jan 03, 2008
    i just got my archos 605 today and i turned it on immediately b4 i charged it and it froze .. it wont turn off!! wat can i do??? pls helP!!
Hold down the power button for around 13 seconds and it will power down. Alternativly there is a small hole on the bottom of the unit where the connectors are for the USB cable, insert a coctail stick or paper clip into the hole and the unit will factory reset. I would suggest downloading the user manual from the Archos web site where these items are listed. I have had one for a week and no matter what I do or how many times I update the device it still is not stable, good luck
Posted on Jan 07, 2008
RETURN IT ... I BOUGHT ONE AND TO RETURN TWICE . GOING FOR THE LUCKY #3 IF IT FAILS AGIAN IT OFFICALLY GARBAGE
Posted on Dec 29, 2007
Archos 605 wifi frozen/bricked
there's a possible error on the disk or the archos storage, - a certain corrupt file could possibly the one making the unit into freeze..
POst back here again
Thank you
May 21, 2008 | Archos 605 WiFi Digital Media Player
Coe 102
Your post/description indicates a possible problem with the firmware. It would seem that the Archos 6052_bing.gif would load but fail to finish and there restarts itself. This could only be possible if somehow the firmware has been corrupted or you tried a firmware upgrade but failed halfway.
There are several versions of the 605, you need to determine which one you have.
Things you can try:
1. Do a soft reset. Press on the power button for about 15 seconds;
2. Do a full/hard reset by removing the batteries and pressing the master reset button;
3. Try again the Systems Recovery. You may need also to format the internal HD but that would mean you loose whatever data is inside.
Alternately, you may need to update/re-install the firmware. A more complete and better explained firmware update procedures are here. Briefly, you have to download and save in your PC the ???????.aos file (there are several versions of the firmware. You need to determine which one is appropriate to your model), connect your 605 to the PC, copy/paste (drag & drop) the said file to the Archos device listed in "My Computer" (you may have to overwrite the older copy), disconnect 605, proceed to System Settings, tap on "Update Firmware". Follow on screen instructions.
If the above is not corrective, am afraid that your unit has been partially bricked. Some have reported serious hardware or firmware problems with the 605 that would require replacement by the manufacturer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 12, 2010 | Archos 405 Digital Media Player
My archos 605 wifi is stuck in recovery
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving wait until it is all done and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
Jul 29, 2009 | Archos 605 WiFi Digital Media Player
My archos 605 won't do anything but to show recovery code 102.
recovery code 102 screen - this error message means the the hard disk has failed - I am guessing that the unit has been dropped at some point - Sorry but it back to Archos - The UK number is 0207 949 0115
Jan 20, 2009 | Archos 605 WiFi Digital Media Player
Touch screen not working
after reseting my archos 605 my touch screen has stoped functioning properly i youch 1 part of the screen and it keep going to my menu bar i hit video it will open the menu bar or any part of the screen i touch it opens the menu bar
Oct 16, 2008 | Archos 605 WiFi Digital Media Player
Recovery code 102
Your post/description indicates a possible problem with the firmware. It would seem that the Archos 605 would load but fail to finish and there restarts itself. This could only be possible if somehow the firmware has been corrupted or you tried a firmware upgrade but failed halfway.
Things you can try:
Feb 24, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 copying films from DVD to the player
If change the setting of the 605 to "hard disk" then a PC sees the 605 as a hard disc when connected using the usb lead. You can then copy and paste files directly to the 605..
Feb 19, 2008 | Archos 605 WiFi Digital Media Player
MY ARCHOS PLAYER WONT WORK
Just watching a movie and my archos just froze in mid play , did a switch off to rest it and guess what it wont restart , ses ARCHOS in green at the start but wont reeboot have tried the reset button inside but no joy what so ever , any tips or advice 'or shall i just ship it back to Archos ....
Jan 05, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 in demo mode
We called tech support and you fix it by doing a reset on the base of the device. We used a paperclip to push the button. Hope this helps!
Oct 28, 2007 | Archos 605 Digital Media Player
Archos 605 WiFi Digital Media Player Logo
1,015 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
