Question about Vivitar ViviCam 3710 Digital Camera
Put a 2GB card into the camera. It says error and It asks me if I want to format. I say yes. But then next time I turn the camera on the same thing happens! Can the camera take 2G?
Keep getting ( check sd card ) prompt no matter what I do.
Are all three cards 2GB and smaller? Cards larger than 2GB are actually SDHC cards and will not work in the D53.
Mar 08, 2012 | Samsung Digimax D53 Digital Camera
In my Nokia 5130c-2 mobile I've a 8GB Micro SD memory card. When I try to enter into Memory Card it tells Unknown File Format in Memory Card. Format Memory Card Yes/No? Every thing was going fine...
Put the SD card in a stand alone card reader, and copy the data off it to your computer. Next, format the SD card, and put it back in your phone.
May 06, 2011 | SanDisk 2GB microSD Memory Card
Samsung digimax 4010 camera has error message.
tis logical that sumsung digimax 401 cannot procees a 2gb memory card, use 1 gb will format ok.
May 11, 2010 | Samsung Digimax 4010 Digital Camera
What is the sd card compacity limit for the DX6490. I have a 8 gigbite sd card and it just keeps asking me to format it. After formating it i put it in a card reader and it still has the pictures i put on...
The DX6490 accepts SD cards, which top out at 2GB. Cards bigger than that are technically SDHC cards. While SDHC cards will fit into SD slots, they will not work. SD cards will work in SDHC devices, though. So, you're limited to 2GB.
It's a hardware thing, which no amount of firmware updating can change.
Feb 24, 2010 | Kodak EasyShare DX6490 Digital Camera
On screen it says memory card error please check the card. i have put 2 cards in with same result photos go to internal memory and wont take photos with card in slot
Make sure the cards are 2GB or less, 2GB is the largest the camera can support. If they are, you may need to format the cards to use with the camera. Press Menu/Set to display the PLAY mode menu and select the item to set. Select Format and confirm by select Yes. The owner's manual says to perform this procedure when you get MEMORY CARD ERROR.
Feb 12, 2010 | Panasonic Lumix DMC-LZ5 Digital Camera
I removed the memory card from my casio exilim ex-z75 while it was still on, and now get "card error" when I turn it on (if it even goes on). I've tried a PNY 2GB SD card, and both a 64MB and a...
Hey! I did this today in my camera, trying to solve another problem (it asks for me to set up date, language and time every time I turn the cam on)... and I got the same error as yours. If you can still turn it on, push MENU while it is on, before the error message appears. And then go to SET UP and choose format card. Then it should work. Good luck!
Jul 30, 2009 | Casio Exilim EX-Z57 Digital Camera
Was OK, but now memory card requires formatting? Kodak Easy Share C-530. I tried several times to put in new memory card, but it always says it needs reformatting and when i try "continue" it then goes to:...
She is not arguing with the camera. Sheesh. When she says she hits "continue" she is talking about continue for the camera to format the card. But instead of formating the card it says filesystem error e00100. The camera will NOT format the card. I have the same problem. I can format the card on the computer, but again the camera says it can not read the card and needs to format. You choose to format, and it says filesystem error e00100. My card is brand new. So I used cards I have owned for while and used in other cameras. Same thing happens. I tried 4 different cards. A 4gb SDHC, thought that format was not compatible so switched to a regular SD 2gb. Same thing happened. Also tried Standard SD 16mb & 128 mb. All do the same thing.
Jul 21, 2009 | Kodak EasyShare C315 Digital Camera
Reformat of XD card - comes up with card error
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb or 2gb cards are not compatible. The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
As far as the 128mb card is concerned if it gets a card error message try cleaning off the gold contacts on the back of the card and reinserting it to the camera. If it still gives an error it may be a problem with the internal card reader in the camera.
Mar 23, 2009 | Olympus Camedia C-750 Ultra Zoom Digital...
Samsung D600 memory card format
i think its the memory card. im sure d600 takes 2GB. I think its the card. Hope it helps
Jul 11, 2008 | Samsung SGH-D900 Cellular Phone
Vivitar ViviCam 3710 Digital Camera Logo
46 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
