Question about Keurig B50 Coffee Maker
My machine won't let me choose the brew size even though it shows "brewing ready" and after 4 minutes or more it may work.
I have a Keurig today it sounded loud when priming and than wouldn't let me pick a size just large so I clean it with vinegar and water but it did same thing than I cleaned the screen on the bottom of resavoir I use a filter so I cleaned the screen on it that worked the same thing stopped it from working a couple of months ago the screen gets clogged scrub it with dish soap and soft tooth brush
Posted on Dec 14, 2016
  • 186 Answers
SOURCE: Coffee Maker only brews 1 cup at a time
Hello. I just talked to Cuisinart and they recomended running a solution of 1 part vinegar and 3 parts water through the brew cycle,then a full pot of plain water to rinse, to remove hard water deposits. The phone # to Cuisinart is 1-800-726-0190. I hope all works out for you.
builderdale
Posted on Jan 12, 2010
  • 7 Answers
SOURCE: My Keurig platinum B70 will not pump water through
Please get a hold of the company at the number in the manual, they will send you a new one if they cannot fix it. Magic words, I got it as a gift three months ago, it worked fine until now. Worked on mine. Sending out a new one today. This company works with you until you are happy. and I am getting 4 boxes of coffee! Free!
Posted on Mar 29, 2010
  • 10865 Answers
SOURCE: My Keurig coffee maker is not brewing the size cup
Hello. I recommend that you descale your machine. Here is how to do it: http://www.keurig.com/help/De-scaling_instructions.pdf?mscsid=27SCSLLH993M9P2RCE7EGD5S1AK660A1
Please reate my answer as very helpful. Thank you. Joe
Posted on Apr 23, 2010
SOURCE: Platinum B70 sometimes won't brew
Not that this is ANY help, but the same thing is happening to me right now as well with the B60. I am also awaiting my hopefully helpful reply. Sigh
Posted on Jun 11, 2010
tbreeze47
  • 3083 Answers
SOURCE: My brewer will not brew
There isn't much you can do with the machines other than descale them. They are very difficult to take apart and work on, since they are manufactured with locking plastic tabs that have to be broken to get them apart, unless one has special tools, which I haven't been able to find. If you can get it apart, you may see the clogged water hose, and be able to replace it, but it's sure not easy.
If the machine is still under warranty, enforce it.
Wish I had better news, but these machines are not made to be easily serviced.
Posted on May 25, 2011
Keurig troubleshooting
had the same issue as you do, unplug the unit. I let it sit unplugged for about a minute and then plugged it back in. Suddenly, it appeared to be functioning normally again. The screen indicated the full range of brewing size selections and when I selected my size and hit the brew button, it actually drew water from the reservoir, then it brewed a nice hot cup of water. It's been working fine ever since
Aug 13, 2014 | Keurig Elite B40 Coffee Maker
Keuring says "ready to brew" but won't!
Clogged exit port from heater section. Clean as per manual page 18.
Aug 16, 2012 | Keurig Platinum B70 Coffee Maker
I'm unable to push the brew unit all the way in. This started when the brew unit was not properly inserted when the machine was turned on causing it to jam. I found the instructions that said remove a...
Hi
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door with the drip tray and dredge drawer inserted and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, and dredge drawer, now replace the tray and insert the brew group. If it still won't go in check the cog in the back of the machine. There are 2 wide teeth that should be at the 10:00 and 12:00 position. If they are at a different position you have a broken drive gear.
Apr 14, 2011 | Gaggia Syncrony Logic 74884 Espresso...
How do we insert the coffee pods
Open the brew mechanism. Opening the brew
mechanism will initiate the heating of the water and the
HEATING light will flash.
2 Place a clean cup on the cup stand, adjusting the height of the
stand up or down so that the rim of the cup is close to the
brew mechanism.
• To adjust the cup stand, insert your finger in the center
of the stand, lift and turn.
• To avoid spilling over, please choose the right sized cup for
the drink you are making.
3 Position your choice of T-DISC on the T-DISC holder, label facing
down. Firmly close the brew mechanism by pressing the clamp
down until it shuts. The HEATING light may flash again as the
machine heats the water to the required temperature for
your drink.
4 When the AUTO light illuminates, press and release the start/stop
button. Brewing will start automatically. There may be a short pause
during brewing; this is normal and is designed to draw out the full flavor
of your drink. The AUTO light flashes throughout the brew cycle. When
the machine has finished brewing, the indicator light will move from
AUTO to MANUAL and then, after a delay of 30 seconds, to HEATING.
5 Open the brew mechanism, remove the T-DISC and discard.
Your drink is now ready to be enjoyed.
You can prepare the next beverage right away by repeating
steps 2 - 5.
Jan 14, 2011 | Braun Tassimo Coffee Maker
My Keurig B66 will no longer pump water up to brew, I have had this less than 6 mos, what should I do?
it seems that it does not pump water in, after switching it to ON, it stays running for a few minutes then shuts OFF without even showing "READY TO BREW"..
Jan 02, 2010 | Keurig B100 Coffee Maker
Keurig B50 Coffee Maker Logo
776 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
