Question about Cell Phones
I just got a Samsung LG CU400 and when I went to pair my BT4051 with it it does not recognize and bluetooth device even though the headset is on
  • 127 Answers
You have to make sure that you set the phone to discovery mode for the blue tooth to recognize it
Posted on Oct 17, 2009
How do I geat the pass key for my device
You see, pairing codes for bluetooth headsets are hardcoded by their manufacturers. Please, take a look at these generic tips I posted a long time ago. Hope they might suit your needs, somehow.
Anyway, please, let me know if you need further informations. In this case, please, tell me both your headset and phone (or the other device you are trying to pair your headset with) models and makers.
Regards,
Carlos
Sep 11, 2012 | Jabra BT4051 Bluetooth Headset
How do I pair a Samsung bluetooth headset model HM1000 to my Nokia C7-00 phone?
1.first on samsung bluetooth device
2.press& hold call answer button in bluetooth device now light is on ,not blinking
3.and then search your bluetooth device by your phone and pair.
Apr 11, 2012 | Samsung HM1000 Bluetooth Headset
My phone can't find the headset. HTC EVO
Make sure you have your bluetooth device in pairing mode to do this you usually hold the power button down while turning on the blue tooth device,then there should be a light that stays on ,now that u are in pairing mode you need to enter a pairing code most bluetooth manufacturers use a 4 digit pin pairing code they are as follows 0000,1234,9999,or 1111, i hope this helps.
Mar 23, 2011 | Jabra BT4051 Bluetooth Headset
How do I sink my Jabra BT4051 with my Nokia 2720a . I do not have a manual any more.
Usually the following setup is required to Pair bluetooth headset with mobile phone. Your mobile phone should support bluetooth interface. 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press the on/off/pairing button marked until the LED indicator light is solid blue. 2. Set your Bluetooth phone to ?discover? the Jabra device Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* 3. Your phone will find the Jabra device' Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
May 12, 2010 | Jabra BT4051 Bluetooth Headset
After putting the headset into pairing mode, my phone (also an LG) will not recognize and pair with headset. Also tried another (non LG device) and that would not pair either? Headset used to work with...
According to a VzWireless Tech, take the battery out for 30 seconds and then put it back in. The phone should reset itself to pair the bluetooth headset with the phone. If that does't work remove the device from the phone and start from step 1. I removed the device from the phone then I took the battery out for 30 seconds. Then I paired the bluetooth and followed the next steps to complete the sync.
Jun 05, 2009 | LG HBM 730 Bluetooth Headset Wireless...
Activating the buetooth function.
You have to "pair" your bluetooth device with your phone. This is just a fancy way of saying "sync" with each other. Check your bluetooth headset instructions on how to do this.
I am using a Motorola H700 Bluetooth Headset. To "pair" it with my phone I have to hold down the call button on the actual bluetooth headset itself while the headset is turned off. This puts the headset in "pairing" mode so its ready to detect any phone that wants to sync with it.
Then I have to go to my actual LG CU400 and enable bluetooth settings. Next, go to "Device List" settings and select "new". The phone will scan for the headset. Once the phone detects the headset it will request a numercial passcode. Your bluetooth headset instructions should list this passcode. Enter the passcode and the phone and headset are now connected! I hope this helps. Good Luck!
Jan 05, 2009 | LG CU400 Cellular Phone
I need instructions how to connect my h350 blue tooth to my lg cu400 cell phone
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Note: The blue light will flash as you press and hold the Call
button. Continue holding down the Call button until the blue
light is steadily lit.
Note: If you let go of the Call button before the blue light is
on and steady, ensure that your headset is off before trying
again.
The default PIN or passkey is 0000 (4 zeros)
You need to enable bluetooth on the phone and go into pairing mode, search for devices or similar
HIH
Jul 12, 2008 | Motorola Mobility Bluetooth Hands Free...
I know NOTHING!
The LG HBM 730 has a muti-function key on the front of the bluetooth. You can recognize it my the semi-circle (phone) symbol. When Bluetooth is on it is 'red'. It is actually a button (not obvious though). Hold it in for 8 seconds or so to turn it on. The light is a give-away when it's on.
Pairing is just the term used to indicate your phone recognizes your bluetooth. You need to set up your phone to recognize the bluetooth that you have.
May 28, 2008 | LG HBM 730 Bluetooth Headset Wireless...
I can not use my blue tooth
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset
boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator
light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The
indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Ensure that your phones blue tooth is active and looking for a new device
Jan 13, 2008 | Motorola Mobility H700 Headset
Cell Phones Logo
163 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
