Question about SMC Barricade SMC7401BRA (SMC7401BRA-ADSL) Bridge/Router
Installer for SMC7401BRA. - SMC Barricade SMC7401BRA (SMC7401BRA-ADSL) Bridge/Router
    Novelist:
  • 171 Answers
You can get the driver here with some additional notes - the download option is near the bottom on the right hands side of the page - near the catchya image
Please vote kindly if this helped you
Posted on Oct 08, 2009
Testimonial: "thanks any way. but i cant still get an installer for SMC7401BRA"
How do u set timing on it? 1.8 engine
Installation
Install crankshaft sprocket on crankshaft.
Make sure mating marks on crankshaft sprocket face front of engine.
Position crankshaft so that No. 1 piston is at TDC and crankshaft key is at 12 o'clock.
Install slack side timing chain guide and timing chain tension guide.
Install timing chain on crankshaft sprocket.
Set timing chain by aligning its mating mark with that on the crankshaft sprocket.
Make sure sprocket's mating mark faces engine front.
Install camshaft sprockets.
Set timing chain by aligning mating marks with those of camshaft sprockets.
Install camshaft sprocket bolts to correct torque.
Apply new engine oil to bolt threads and seat surface.
Install chain tensioner.
Before installing chain tensioner, insert a suitable pin into pin hole of chain tensioner.
After installing chain tensioner, remove the pin.
Install timing chain guide.
Install O-rings to cylinder block.
Before installing front cover, remove all traces of RTV silicone sealant from mating surface using a scraper.
Also remove traces of RTV silicone sealant from mating surface of cylinder block.
Apply a continuous bead of Genuine RTV Silicone Sealant or equivalent to mating surface of front cover. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Check alignment of mating marks on chain and crankshaft sprocket.
Align oil drive spacer with oil pump.
Place timing chain to the side of chain guide. This prevents the chain from making contact with water seal area of front cover.
Install front cover.
Make sure two O-rings are present.
Be careful not to damage oil seal when installing front cover.
Install cylinder head bolts at engine front side as shown in Fig. 55.
Tightening procedure:
Tighten bolts (1 - 4): 6.3-8.3 N.m (0.64-0.85 kg.m, 55.8-73.5 in.lb).
Install oil pump drive spacer.
Install water pump and water pump pulley. Refer to REMOVAL AND INSTALLATION .
Install idler pulley and bracket.
Install RH engine mounting bracket
Install RH engine mounting.
Install oil pan. Refer to INSTALLATION.
Install crankshaft pulley.
Remove ring gear stopper.
Install starter motor.
Install cylinder head front cover.
Apply RTV silicone sealant to cylinder head front cover.
Use Genuine RTV Silicone Sealant or equivalent. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Install Camshaft Position Sensor (PHASE).
Before installing rocker cover, apply a bead of Genuine RTV Silicone Sealant or equivalent, to mating surface of cylinder head as shown in .
Install rocker cover gasket into rocker cover.
Install rocker cover and tighten in numerical order as shown in
Install spark plugs.
Install ignition coils.
Install front exhaust tube.
Install front/right-side splash undercover.
Install front RH wheel.
Install drive belts.
Adjusting drive belt deflection..
Nov 29, 2010 | 2002 Nissan Sentra
I have a belkin vision N1 modem router connected to the Internet by ADSL and I wish to connect to it a SMC Barricade N with a 20Meter cat 6 cable to improve wireless reception on the other side of the...
Can you clarify the problem?
Consdier first that both devices are NAT firewalls and your ISP probably only allows one address. So you would need to put one behind the other. This may not work like you plan. PCs behind the second will not be seen on the LAN by PCs on the first.
The N1 is a very good router. Consider relocting it to a more central location.
Another trick is to locate it near a central wall if it is block. By adding 1 remote antenna and drilling through that wall witha short antenna cable you can get much better coverage on the other side.
It could also be an ethernet problm 1. Power down SMC, plug WAN of SMC to LAN of router and power up SMC. If both devices show link lights and activity the hardware is OK. If not you need a "crossover" cable.
Hope that helps.
Oct 07, 2010 | SMC Barricade SMC7401BRA (SMC7401BRA-ADSL)...
I want to install printer hp deskjet d2460
How to install Printer
Follow these steps to install the downloaded software.
  1. When the download is complete and you are ready to install the files, click Open Folder , and then click the downloaded file. The file name ends in .exe . NOTE: If you closed the Download Complete screen, browse to the folder where you saved the .exe file, and then click it.
  2. You can accept the default place to save the files. Click Next , and then wait while the installer extracts the files to prepare for installation.
  3. When the Install Wizard starts, follow the on-screen instructions to install the software. NOTE: If you have previously installed the software and are changing the connection type from USB to Ethernet, click Add a device when the Uninstall the software or Add a device window opens. For a Full Feature installation, you choose what type of installation you want. The following information might help you decide which installation type to use. Typical (Recommended) Minimum For full use of all your product features : HP includes valuable software to help you get the most out of your product.
    HP designed this installation type to work for most users. A custom type of installation might be available for your product. This installation allows you to install the minimum software required or the preferred software. Use this type of installation only if you have one of the following reasons:
    • The computer is low on hard disk space.
    • You attempted a recommended type of installation and received errors. (If errors occur during the recommended installation, fix them before trying a custom installation.)
Apr 10, 2010 | HP Deskjet 2460 Printer
I clicked the release button on my status page, and now my internet isnt working and i cant click anything, whats wrong??
It should have reconnected automatically, but in any case that it hasn't reconnected just restart your Barricade by pressing power button OFF then ON.
It should have a new IP address provided by your ISP.
Hope it helps. Thank you for using FixYa.
Jan 16, 2010 | SMC Barricade SMC7401BRA (SMC7401BRA-ADSL)...
Is this router ADSL2+ compatible and is there any free firmware I can download?
No it is not ADSL 2+ compatible sorry! only ADSL but there is a lot of cheap ADSL2+ routers that work really well.
You can get firmware from HERE
Jun 30, 2009 | SMC Barricade SMC7401BRA (SMC7401BRA-ADSL)...
Master_egypt85@yahoo.com
Username :admin
Password :barricade
OR
Username :smc
Password :smcadmin
Aug 14, 2008 | SMC Barricade SMC7401BRA (SMC7401BRA-ADSL)...
Install A4 tech PK635 M web cam without cd installer
help me solve my problem give me installer
May 19, 2008 | A4tech PK5
WANT TO RESET TO FACTORY SETTINGS
Hello, Not knowing the manufacture or model of router makes it hard to answer your question. You should be able to go to manufacture web site and do a search for your problem. You can also google the model # and maybe get an answer. Give me a model # and I'll try to help. Normally there is a reset hole on back. Thanks..
Mar 07, 2008 | SMC Barricade SMC7401BRA (SMC7401BRA-ADSL)...
I need to connect a real router with more ports to it 4-2 pcs
Connect the LAN port on the Barricade to the WAN port on your wireless router. The Barricade should be "plug-and-play",
i.e., no need to configure it. Similarly, the WAN port on the wireless-router is plug-and-play, so it should automatically get an IP-address from the Barricade.
Use an Ethernet cable to connect the network-port on your computer to one of the LAN ports on the router.
Then, start Internet Explorer, and connect to the web-server "inside" the router. Run the "Wired Network Setup Wizard", and then the "Wireless Network Setup Wizard". When you're done, then your "wireless" device(s) (iPod Touch, laptop, XBox360) should be able to make a wireless connection.
Note: no need for any CDs to "install" anything.
Sep 23, 2007 | SMC Barricade SMC7401BRA (SMC7401BRA-ADSL)...
SMC Barricade SMC7401BRA (SMC7401BRA-ADSL) Bridge/Router Logo
141 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
