Question about Samsung CLP 300 Laser Printer
CLP 300N blue streak on prints
I am getting a blue toner streak on the right hand side of my colour prints can any one tell me what to do to get rid of them please?
SOURCE: colour print smears
Please remove imaging unit and transfer belt and make sure no paper is lodged above the transfer belt (ITB)
Posted on Dec 04, 2007
SOURCE: STREAKS WHEN PRINTING
IN MY CASE THE PROBLEM WAS A FAULTY DRUM. I HAD ORDERED A NEW ONE AND THOUGHT IT SHOULD FIX THE PROBLEM. IT DID NOT. I CALLED THE COMPANY AND THEY SENT ME A REPLACEMENT. WHA-LAA!! PERFECT PRINITING AGAIN...
Posted on Mar 16, 2008
  • 32 Answers
SOURCE: Samsung Lazer Printer CLP-300N will not print
Take it back if its under warranty..?
Posted on Apr 06, 2008
SOURCE: Samsung CLP-300 Printer
This is a manufacturing defect. Call Samsung at 1-866-726-4249 and explain the problem. They will replace your imaging unit free although you will most likely need to provide a credit card for them to hold until they receive the defective unit back from you.
Posted on Oct 28, 2008
  • 6 Answers
SOURCE: I get this blue stripe down the right side of the page
Open the doors to locate and wipe off the green shiny roller really well. Spin it and wipe it off all the way, especially on that right side. Pull out the cyan toner and wipe it around where the toner comes out. Check other rollers for blue marks and wipes those off as well. Lit free cloths work best but I just use a damp paper towel and then a dry one.
Posted on Apr 27, 2009
My HP Color LaserJet 8550 is printing very distinct streaks. It seems to be in areas that have a lot of magenta. Any idea how to get rid of the streaks??
If the streaks are limited to a single colour, the problem is likely to be THAT colour TONER CARTRIDGE.
A problem with the DRUM UNIT (only a single drum in this printer) or the TRASNSFER DRUM , or BELT (this printer has both a transfer drum and a belt), would affect ALL colours.
Apr 23, 2012 | HP Color LaserJet 8550 Printer
I have a Lexmark E250DN printer. The photoconductor kit was full of excess toner. It was easy enough to unscrew the holding tank and to clean out the old toner. Everything seems to work fine now except for...
Probably you need to purchase new one - Lexmark E250X22G photoconductor. Every 60000 prints you need to change it or
If it is OPC drum (green roller) damaged.
May 29, 2017 | Lexmark E250dn Laser Printer
I have cleaned the developer blades of the colour cartridges in my samsung clp-300 laser printer as per instructions on this site. The vertical white lines have now gone BUT i now have a 3 mm wide blue...
Check to make sure the blade is UNDER the foam along the side where the streak is. If it isn't, then more toner is getting out than should be and that is the cause of your streak.
May 09, 2011 | Office Equipment & Supplies
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
HP Laserjet 2820 Streaks on Page
There are 3 parts to the imaging process that could cause your issue. You have the toner (x4), the imaging drum unit (Q3964A) and the fuser unit. If you are getting streaks from all colors, one or more these parts are the issue.
Let's start with the easy stuff:
Open the cover as if you were replacing toner where you can "visually" inspect the toner and imaging drum. Pull the drum out and pull back the "plastic shutter" on the top, this will expose a green drum CAUTION! Too much exposure to light and touching it can cause damage. Just take a quick look trying to see if any of the lines on your page match any marks on the drum. Check the bottom half of the unit as well there should be a white section across the bottom, expect that as well.
Next look at the toner, if you can look at any other color but black it will help you look for the streak marks a lot easeier. If you couldn't see any streaks on the drum on toner cartridges, it's time to look at the fuser unit. Power the machine down and turn it around, unplug it then fold down the blue clips and CAUTION! the fuser heats the toner to the page so if it's been used recently it may be hot. once the clips are down, just pull straight back and look for the streak marks.
Sorry for the book, but I hope it helps.
Jul 30, 2009 | HP LaserJet 2820 Printer
11 blue dots print out down the left hand side of documents
it sounds like the CYAN toner cartridge is leaking.
Jan 22, 2009 | Office Equipment & Supplies
DELL 3000cn Printing Problems
switch off the printer then switch on again whilst holding the UP and DOWN menu scroll buttons simultaneously.
Then you can go to a TEST PRINT area and print off pages of idividual colour.
If the streaks appear on ALL prints its likely to be the laser unit. If the streaks only print on the COLOUR sheets ( not BLACK) then the problem lies with the drum or the transfer belt.
Remove the drum and turn it manually with the gog at the side and give it a clean with a soft LINT FREE cloth, do the same for the transfer belt and then you may have to run a few test prints to get it all reprimed but you should be OK.
Oct 18, 2007 | Dell 3000cn Color Laser Printer
Vertical streaks
The toner forms small lumps and get stuck on the doctor blade of the cartridge. Where there are the lumps it blocks the toner from getting on the roller. Removing the doctor blade and cleaning it with a soft cloth and alcohol can solve your problem.
Send me a mail at ecoworld@myt.mu if you need further help in doing it.
Sep 11, 2007 | Lexmark C500n Laser Printer
Samsung CLP 300 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
