Question about Candy Washing Machines
Washing Machine CN120
Cant open the door on my CN120
  • 414 Answers
SOURCE: asko washing machine w6342 showing f3 and cant open door or operate?
Make sure the programme selector switch is at an end of wash position as these door locks are interlocked to prevent accidental opening during operation. There is also a 2-3 minute time delay after the was finishes so disconnect for say 5 minutes and try again.
If it still doesn't open you will need to get access to the mechanism dependent on what type of relrase mechanism you have;
if it is a push button release with a cable to the lock sometimes you can remove the top panel of the machine and pull on the cable or linkage to open.
If it is a lever type release mechanism this is more difficult to open but you can sometimes reach and release it by the same method.
Always disconnect the machine from the electricity supply before working on it.
Posted on Oct 13, 2008
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
SOURCE: Cant open door of washing machine
I plugged it out. Left it for 15 minutes. When I went back the door could be opened and it also started to wash.
Posted on Jan 21, 2009
  • 1294 Answers
SOURCE: cant open the door on
Posted on Mar 30, 2009
  • 3230 Answers
SOURCE: Washing machine door wont open
well, Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Posted on May 19, 2009
  • 3600 Answers
Call the manufacture it will be under warranty if it's only 6 months old as the machine will have to be torn down to get to the defective switch, just the top will have to come off if your lucky.
Posted on Jun 17, 2009
0 characters
1 Points
Why cat I open door at end of wash cycle
Mar 14, 2016 | Hotpoint Washing Machines
Door locked,cant open
just get an old door from any ariston..hotpoint or indersit machine make sure it is the same size
Jan 12, 2014 | Ariston Technologies Ariston AWD12 Front...
Front load duet washer wont start because the door cant lock and we cant open the door.
You need to replace the door lock/switch. It is quite an easy job but is a tight fit behind the front so a bit tricky to get the old one out and the new one in.
Mar 06, 2012 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
The door wont open red light on door what s it means?
it means that the washer thinks that it is still running and you need to by pass the safty switch that is on the door to get it open the switch is there so you cant open the door while it is in spin cycle. most washers you can see the switch under the lid and just push down on it and it should open the door for you
Feb 21, 2012 | Whirlpool Washing Machines
You could try to force the door open by inserting a screwdriver or similar at the point where then door latches in at the front of the washer, failing that, you will have to remove the top cover, and force the door open from the inside.
You are probably going to have fit a new door lock.
Hope this helps.
Dec 04, 2009 | Washing Machines
I put some washing in my samsung J845 front loader the door will not lock before the washing can be done. my husband brought a new door latch due to the other one been burnt out and he put it back on the...
Just bang the door again until the error goes away. The door is not lined up and won't latch properly. At least that is what ours does. I usually slam the door on my machine.
Sep 29, 2009 | Samsung Washing Machines
Door locked , i cant open, tried soo much, Frigidaire WL 5892
this is almost always caused by a defective ccu, central control unit. Try unplugging the washer for 5 minutes.
Aug 31, 2009 | Washing Machines
Cant get the door open...
In the dispenser there should be a emergency pull strap to release the door in case of power failure.Try unplugging and plugging back in first.
Jun 26, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Cant open door
Dear all, I have a problem with washing machine model wd-8013c, then you wash white laundry receives water and immediately released, and it does not happen with colorful Vesa. Best regards.
Apr 25, 2009 | LG Washing Machines
Washing Machines Logo
46 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
