Question about Panasonic Strada CN-NVD905U GPS Receiver
Anyone disable the Parking Brake?
I have the 905U coming in the mail and I want to disable the parking brake thing. I have checked around and everyone says to just put the parking brake sense cable to ground. Has anyone done this for the Strada? Have any luck or issues? Thanks.
  • 1 more comment
  • fusionmeat Dec 26, 2007
    What about the speed sense cable and reverse cable? Are these necessary? I think reverse would only be for the camera, but what about the speedo cable?
  • fusionmeat Dec 30, 2007
    Thanks for the comments. I just finished hooking everything up, but had one questionable wire, the "illumination" and "dimmer". I hooked the stereo illumination to the illumination on my vehicle, but when I turn the lights on it doesn't go into night mode (the lights box in info doesn't come on either). I guess the stereo "illumination" needs to be hooked to my vehicles "dimmer"? Anyone have any feedback on this? Haven't swapped them since the unit is completely installed...
  • kevin mcintyre Jan 22, 2009
    Hey I have the same problem with the parking brake wire also. And it is a panasonic also!!!!! The main problem I believe that I have is that I do not have a maual and Im not sure which one is the parking brake wire!!!!! I do know what Im doing!!! But it is a guessing game and just decided to see what everyone had to say!!!!! When I play a dvd I hear sound but then the screen says " please enjoy the music" Any help would be great!!!!! I also get a loud popping sound when I start the car!!! Its a 2005 dodge magum rt!!!!! And the sound is through the highs!! lol.... Please help!!! I have 2 kicker l7 12's a 2400 watt orion on one sub and 2400 watt orion on the other!!! And a 800 watt orion on my highs, mtx crossover. cap alpine type r 6x9 all the way through and oh mb quart tweets in the dash!!!!!! Thanks....
Hey thanks guys for all that info...very helpful
Posted on Feb 24, 2008
Well it is nice to have the Speed sensor. Just find the appropriate wire on the ECU or other guys have spliced it into the speedo wire coming out of their speedometer/gauge area. The unit will actually give you your speed when in the install status screen. Yes you can just ground the parking break wire on a screw in a metal area and it will read it as being on all the time. As for the illumination I hooked it directly into the illumination wire that went into my stock radio and it works fine. The reverse I found on the passenger side under the door sill. Just found the right wire and tested it with a voltmeter to double check and it's perfect. I honestly don't suggest grounding the parking break wire because it's bad enough fiddling with the GPS or iPod controls while your driving. If you really want your passengers to enjoy movies install a visor monitor (although the significant other will not like the lack of mirror) or in the headrest. This stuff isn't all that hard.
Posted on Feb 13, 2008
Hey Guys
The panasonic strada is one of the easiest double din navi units to bypass. just ground the parking brake sensor and your done! it doest matter if your speed sense or reverse wire is hook up.
Posted on Jan 18, 2008
I didn't hook up the speed sensor or reverse wire and just grounded the parking brake wire to the system ground.
Posted on Dec 30, 2007
  • 3 Answers
Yes, I did it to mine, Just ground it and it will always be *Parking Brake mode* and you can .... You know. :)
Posted on Dec 26, 2007
Parking brake light is on
You may have play in the park brake pedal due to park brake cables needing servive/repair. If you pull up on the park brake pedal when the light is on... will it go out? Another reason for this light to come on is low brake fluid. Have the level checked
Apr 05, 2015 | Cars & Trucks
The back brake locked up and released what is wrong with it how do I fix it
It could be the springs inside the drum, could be rusted and stuck or broke, take your tire off and pull your brake drums
Nov 25, 2014 | 2003 Subaru Forester
01 toyota avalon vsc, vsc off, and parking brake light on
The VSC uses the brake system to function. So if the regular brake system is not working correctly the VSC will be disabled.
The brake warning light is for the parking brake as well as the hydraulic brake system. So it could be low on brake fluid or something else.
Feb 09, 2014 | Cars & Trucks
2000 Dodge Durango, Canadian specs, P with a circle around it and exclamation point with a circle around it, lights come on simultaneously.
Usually the P with a circle is for the parking brake. Its possible the sensor for the parking brake is faulty and telling the computer the parking brake is on when it is not.
Jan 21, 2014 | 2002 Dodge Durango
Adjusting the parking brake on a MiTSubichi ENDEAVOUR 2005
If your parking brake is too loose or is not properly adjusted, you may encounter problems while parking, positioning and driving your car. Most of the time, car owners would send their car to a mechanic in order to fix and tighten the parking brake. However, you can actually skip this step and adjust your parking brake yourself. When your car starts to slip on a hill in its park position, you need to start tightening the parking brake.1 Remove the car's center console cover placed around your parking brake level inside your car. This is found between the seat of the driver and the front passenger.2 Use your wrench to turn its adjuster nut found at the end of your parking brake's cable rod. Loosen the adjuster nut with your wrench, while making sure that it does not come off at your parking brake cable rod's end.3 Raise your car rear wheels using your jack, and use your jack stands to support both its rear wheels.4 Pull up your parking brake handle up to two clicks or notches. Tighten your adjuster nut until you feel a slight resistance on your rear wheels whenever you spin them.5 Release your parking brake lever. Check and make sure that your rear wheels are still able to spin freely and without any resistance.6 Pull up on your parking brake lever up to three to five clicks or notches, while making sure that your car's rear wheels are not turning at all.7 Lower the car by adjusting your jack, and remove your jack stands from your car's rear wheels.
Oct 03, 2011 | 2005 Mitsubishi Endeavor
Why does the parking break light stay on in my 97 Olds Cutlas Supreme. I have checked the level of the break fluid and it is full. I did have new break lines put in last year. I did have to slam on my...
Apply the parking brake with the vehicle parked, engine turned off and transmission in Park. Release the parking brake completely, then apply it again, and ensure that it is fully released. Turn the ignition on, check to see if the Parking brake warning light is on. If it is NOT on, apply the parking brake and check to see if the warning light comes on. If the light come ON wihen the Parking brake is applied,.....fully release the parking brake and check if the warning light goes OFF. If it does NOT go off, then an adjustment is needed at the parking brake switch.
Jan 09, 2011 | 1992 Oldsmobile Cutlass Supreme
Parking Brake Light on constant without parking brake engaged
Check your brake fluid. The same light is used for the brake fluid level as well as the parking brake.
May 02, 2010 | 1997 Saturn SL
Rear passenger side brake keeps hoping when brakes applied
hi make sure the hub flanges are clean and no rust
May 25, 2009 | 2003 Chevrolet Malibu
Tightening parking brake for 2001 GMC Jimmy
Hi... to adjust rear brakes providing the shoes are good... just drive vehicle in reverse and pump brakes... rear shoes are self adjusting so they should "adjust" themselves... after doing this test by putting on park brake, put vehicle in drive and see if vehicle moves forward, repeat procedure if necessary. Hope this helps... please rate suggestion.... ty
Mar 03, 2009 | 2001 GMC Jimmy
Vr3 installation
it's supposed to go to the wire of the parking brake that is grounded with the parking brake on. This wire disables the dvd video so it can only be watched with the parking brake set. On mine, I just connected it to the black wire so it is able to play video all the time. Or you could run it directly to ground, same thing as connecting it to the black wire.
Jan 31, 2009 | Virtual Reality Sound VR3 CD Player w/ USB...
Panasonic Strada CN-NVD905U GPS Receiver Logo
621 people viewed this question
Top Panasonic GPS Experts
Richard Foster
Richard Foster
Will Halftowaite
Are you a Panasonic GPS Expert? Answer questions, earn points and help others
