Question about GE WSXH208A Front Load Washer
What is the meaning of "tap cold" and plain "cold"?
    President:
  • 1,304 Answers
Tap cold is the temp of the water right out of the tap
cold is what is used by the machine as cold
some machine will actually raise the tub temp to 60 degrees
by adding hot to a cold fill
Posted on Oct 06, 2009
Hello, I have Lg fuzzy logic 7 5. I used to run it using cold water only. It stopped working using cold water only. Now only runs on hot water. Any ideas?
the cold water solenoid has a problem and not allowing the water through
you can swap the hoses at the taps and that means when you press hot water , you will get the cold water to enter the tub
Jun 10, 2017 | LG Washing Machines
Daewoo washer DWD-F1011, WATER OVERFLOWING, HOW TO SOLVE THIS PROBLEM???
replace the water shutoff solenoid valve assembly
in the mean time when the machine is full turn the tap off
change the hot water hose over to the cold water tap and use the hot water solenoid button
Sep 05, 2016 | Daewoo Washing Machines
I have a 740003pc the cold tap wont stop running
If you mean the drain valve, the cheapest, easiest fix is to buy a hose cap at the hardware store and cap it off. If you mean the relief valve which is located on the top or upper half of the heater, you must replace the relief valve. Do Not cap the relief valve it is a safety feature. If it leaks again you may have further issues
Dec 30, 2013 | Rheem Water Heater Electric 20 Gal 120V
My whirlpool 6th sense washing machine keeps saying water tap closed half way through a cycle and displays FH what dus this mean?
That's a water filling problem.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 04, 2011 | Washing Machines
Hot cold water
Question is not 100% clear.
System is not described.
Hot water will come out of cold tap of you have recirculation system.
Without a direct return line, the cold water pipe is filled with hot water.
So hot water is available immediately, but you wait for cold water when recirculation system is on.
http://waterheatertimer.org/Water-heater-recirculation-system.html
If you install a direct return line, then cold water line is not used for recirculation, and cold water is available immediately.
Another possible solution, depending on problem, is to use timer instead of thermostat to control recirculation system. Using the timer means hot water is inside the cold pipe only when the timed operation is running. This will let you have immediate cold water.
Link above has information how to choose timer vrs thermostat.
If cold water never arrives no matter how long you run the hot tap, then check-valve on recirculation system is not working, or you have crossover on single-handled faucet, or both.
http://waterheatertimer.org/Crossover.html
Jul 22, 2011 | Grundfos Comfort System Recirculator ...
What does "PE" error message
LG's 'PE' refers to '(water) Pressure Error'
John C
Jul 18, 2011 | LG WD-16115FD Front Load Washer
Red tap warning light on what does it mean
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
John C
Jun 04, 2011 | Whirlpool Washing Machines
I need to add some water or coolant
you need to add coolant, it protect your engine from freeze up and also keep inside of your engine from rusting
Feb 28, 2010 | 2003 Volkswagen Jetta TDI
I keep getting cod E10 and have no idea what this means.
Hi
This code usually means that there is no cold fill. If the cold isolator tap has not been accidentally turned off, then most likely the clamp-on pipe has corroded over time and needs changing to a proper isolator valve TEE. The other possibility is that the cold-fill valve has failed. This is the unit that the cold inlet pipe attaches to at the rear of the machine.
OR
Water hasn’t emptied before max empting time,(drain problem)it won’t spin because of this reason.
Thanks for contacting fixya.com
Dec 14, 2009 | Frigidaire Affinity ATF7000E Front Load...
Tap sound from my engine on a cold start and when
Try changing to an heaver oil first,if your using 10-30 go to 10-40,see if this helps,before looking at the valves.
Jun 26, 2009 | 2004 Nissan Maxima
GE WSXH208A Front Load Washer Logo
87 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
