Question about Sony KDF46E2000 46" Projection HDTV
Just replaced the lamp for my KFK46e3000. It worked for 2 days and the lamp replacement light is on again. It is only 2years old What is up?
Slinteriors
  • 8617 Answers
SOURCE: RCA SCENIUM TV (HD50LPW175) NO PICTURE.SOUND FINE.
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
SOURCE: Mitsubishi DLP - model #WD62725
fixityrsel is wrong.
1 The "Airflow message"is just a bad connection and very easily solved.Mitsubishi has a service bulletin out and will cover the repair for free. Your set may not even have the defective connectors.
Your set was manufactured in 2004..Call any authorized Mitsubishi
servicer.
Capacitors are very easy to find! Any (105 degree) PC mount 3300uf@ 16VDC will work fine..and not bulge again..Higher Working voltage than the stock 10 VDC is what caused the problem with the caps.
Mouser electronic is one of hundreds of suppliers for those caps
Order online if you know for sure they are bad in your set.
Dan
Posted on Aug 14, 2008
  • 184 Answers
SOURCE: Sony KDS-R50xbr1 50" Problems
Here's the best way to get Sony's and/or the extended warranty company's attention and possible help.
Send an old fashioned letter to Sony and your extended warranty provider outlining the problems and your concerns regarding your TV. Make sure to prominently indicate that a copy of the letter is being sent to the complaint division at the attorney general's office in your state. After having to settle claims surrounding their optical block (light engine) issues Sony now understands that failure to address their customer's complaints may result in another judgement against them.
Good luck and give 'em hell!
michtech
Posted on Feb 16, 2009
maatmartin7
  • 1210 Answers
SOURCE: I replaced to lamp on
I have not repaired this particular model. Some of the problems for refusing to stay on are....Your color wheel may have lost its RPMs and or the cooling fan may be running slow. It is essential the fan is running at high speed. Without proper cooling your set may shut down. The power supply to the fan may also need a capacitor and resistor replaced to sustain speed in addition to replacing this fan! And when you replace the lamp be sure you do not use your bear hands to install this. Use a pair of plastic gloves or a clean pair of cotton ones. The oils on your hand to the bulb will shorten its life. I offer food for thought.....Hope this will clue you in a repair. Thanks for asking!
Posted on Aug 01, 2010
  • 90 Answers
SOURCE: I replaced my sony kds60a3000 lamp 2 1/2 weeks
If you touched the glass lens part in the front of the lamp will you were installing it, it will burn the lamp and screw up. If you did do this you may need a new lamp. Sorry but thats about all you can do.
Posted on Jan 03, 2011
Had check fan no 2 on tv. I replaced. The bulb is about 6 months old as well. I power on both fans are working the bulb comes on but the tv shuts off after a few seconds before the picture even comes on....
U recheck the tv projection lamp connections,the door latch and the lamp door closed properly and tightly.Yes,if the tv projection lamp LED light indication "LAMP" word it is still flashing or staying on the tv projection lamp some how dying again.The tv projection lamp should be replacing it again.
Sep 02, 2011 | Samsung HL-S6188W 61" HDTV
Hello. I have a Mustek PowerMust USB 800 device. Few times a day (2-3 times) it shuts down my computer. It appears the red light instantly and it starts to make a sound. Even after i press the button and...
Did you read the manual for your UPS ?
I read it - there was something about lamp ledding - different ledding of lamps and different frequncy of noisy sound can mean different problems - try read manual.
I think, your description means that you need to change battery.
Battery work 2years +- .
Jul 05, 2011 | Mustek PowerMust 800 (POWERMUST800USB) UPS...
HLR 5067W 6yrs old. I replaced the lamp and color wheel about 3 years ago. Last week the TV would not turn on. Fans run hard, no light from the lamp. Tries for 3 cycles, then shuts down and front...
Tv is on every day and watches 4 to 5 hours every day?Yes,3 years now the projection lamp require replacement again and the board that call the Ballast board might require replacement too,this Ballast board only job is it to ignite the projection lamp only..
Jun 04, 2011 | Samsung HLR5067WX 50" Rear Projection HDTV
Sony model#kdf50e2000.turned it on a few days ag0 heard a few clicks, green light come on a few times then it gives me three red blinks stops then three red blinks again and again.no sound no picture.i...
Your lamp door switch or lamp switch (there are 2) may not be fully engaged or one may have failed. Try seating the lamp again, you may not have it fully installed.
Mar 17, 2010 | Televison & Video
Had Blinking RED blinking lights. FIXED
CHECK LAMP COVER, CLOSE IT AGAIN THE RIGHT WAY
Feb 21, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
MY PANASONIC LIFI TV STARTS FLASHING GREEN THEN THE LAMP LIGHT FLASHES RED TWICE
Try replacing the lamp, if its been more then 2years since purchasing the television
Oct 18, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
52HM95 Lamp Issue
The Tv will shut off and sho error if the ballast is bad. Replace the ballast and you should be fine.
Mar 22, 2009 | Toshiba 52HM95 52" HDTV Projection...
RX-V1500- front panel lights not working
The display on an amp has two components.
A small Lamp (light bulb)
A LCD display with a color filter.
Normally when the display goes out the problem is with the lamp
The lamp on my RXV 870 died after about 9 years of use.
I called Yamaha and was able to by a replacement.
The lamp is an odd voltage 14.5 if I recall.
Looking at the receipt i should have bought 3 for the cost of shipping. It cost about 10.00 cnd,
Apr 02, 2007 | Yamaha RX-V1500 Receiver
Sony KDF46E2000 46" Projection HDTV Logo
44 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
