Question about Car Audio & Video
My stereo and display is not working in my seat ibiza 1.9 sdi w reg 2000 the display also shows you the heat and speed you select and the clock, the heater controls still work.
Check the fuses first off,
Frayed wire connections or rats nest's cause quite a few problems,
Check your positive terminal post for bad corrosion or faulty connections. If you are running after market subs or amps try dissconecting temporarily because your bettery may not be able to crank out enought power, and your alternator most likely can't keep up, check your ground cable for any damage,
If you have ever boosted the car OR removed the battery with internal display on you may have overloaded the system and in that case your screwed.
Im not too familiar with seat
but I hope this helps you figure it out. good luck
Posted on Oct 07, 2009
What is spring sign showing on dash of seat Ibiza sport 1.6
hi Marc
SEAT Ibiza glow plugs heating warning light - your SEAT Ibiza is equipped with an automatic glow plug system. The indicator lamp lights up while the glow plugs are preheating. If the engine fails to start immediately, the glow plugs have not finished preheating. In this case, keep the clutch pedal depressed (or keep your foot on the brake if your vehicle has an automatic gearbox) until the engine starts. (applies to diesel cars only)
Ibiza Mk4 dash lights
Apr 23, 2017 | Seat Cars & Trucks
Ibiza cluster failure
must check the wiring for any lose connection or melting.
Nov 20, 2013 | Cars & Trucks
Hi my alana stereo is stuck in safe mode as i entered code from my old seat ibiza thinkin it was this one now safe mode on all the time and will not let me put code in
My Seat Ibiza has been in storage with battery disconnected. On connection of the battery the Alana radio now shows '1000' (not 'SAFE', then '1000' as it has done previously. This does not allow me to enter the radio's code. Can you help me?
Oct 20, 2010 | Car Audio & Video
Problem with seat ibiza stereo not working
find a kit on e-bay that plugs into our factory wiring so you dont have to cut any wires. then ge the dash mounting kit to install the radio into the dashboard
Feb 17, 2010 | Car Audio & Video
Need to set clock
1) Press the center of the multi-control button (big round knob) once to display the settings mode which appears on the digital display of the stereo unit.
2) Turn the multi-control to until the display shows clock settings.
3) Press the control ONCE to enter this menu.
4) The display wish show the 'Hours' flashing - turn the control to adjust this setting to the correct hour and press the control once to select.
5) The "Minutes" will not be flashing - turn the control to adjust this setting to the correct minute (time) and press the control once to select.
6) Locate the "band/esc" button on the bottom left corner of the stereo face and press once to select and exit the settings.
The clock should now be set. NOTE: There are a LOT of different models of Pioneer car stereos and they will not all have the same menus. The above steps should work on the newer systems.
Sep 05, 2009 | Pioneer Car Audio & Video
Ive got a seat ibiza tdi r reg,the problem is my clock have stopped working speedo,temp,oil,rev,ect,ect can anyone help all the fuses seem too be ok.
lost track of R reg on uk plates remember having a E plate and it was a 1967 ford zodiac but if this is one of the newer models then firstly check the connection socket in the back of the unit if it appears ok then its dealer only ,you could have faulty earth to the unit or another problem and as this vehicle if its a newer model then its using encrypted software which is dealer only type job
Jun 16, 2009 | Volkswagen Golf Cars & Trucks
Is there a Haynes Manual for the 1.0L Seat Ibiza, 2000 version?
There is a haynes manual for 2000 on. All Fiat/ Seal have minor differences. I think that yours is probably the one that you have to remove the hub nut to take off the hub.
Jun 09, 2009 | 2000 Volkswagen Golf
Jvc kds641 changing time display
Here ya go,
1.
Press and hold SEL (select) for more
than 2 seconds.
“CLOCK H,” “CLOCK M,” “SCM LINK,” or
“LEVEL” appears on the display.
2.
Set the hour.
1 Using the << / >> button, select “CLOCK H” (hour) or "CLOCK M"
Use the + / - button to adjust the hour/minute
3.
Press SEL to finish.
4.
To check the current clock time or change the
display mode
Press DISP (display)
repeatedly
During tuner operation it will show the frequency or time.
During CD playback it will show elapsed time or time.
Follow this link to download the manual for your unit in .PDF form.
Mar 30, 2009 | JVC AM FM CD DET FACE CAR STEREO
Put the clock
1.
than 2 seconds.
2.
Set the hour.
3.
4.
display mode
repeatedly
Setting the time on car stereo/cd player
Changing the general settings
(PSM)
You can change the items listed on the next page
by using the PSM (Preferred Setting Mode) control.
• The PSM items are grouped into five
categories—“Disp (display),” “Clock,” “Tuner,”
“Color,” and “Audio.”
Basic Procedure
1 Press and hold SEL (select) for more
than 2 seconds so that one of the PSM
items appears on the display.
(See page 23.)
The currently selected
category is shown on the
left side of the display.
2 Press 5 (up) or ∞ (down) repeatedly
until your desired PSM category
appears on the left side of the
display.
3 Select the PSM item you want to
adjust.
4 Adjust the PSM item selected.
5 Repeat steps 2 to 4 to adjust the other
PSM items if necessary.
6 Finish the setting.
To set clock—Clock Hr, Clock Min
You can set the clock using the PSM control.
1 Press and hold SEL (select) for more than 2
seconds so that one of the PSM items appears
on the display.
2 Press 5 or ∞ repeatedly until “Clock” is selected
as the PSM category (it is shown on the left side
of the display).
3 Press ¢ or 4 to select “Clock Hr
(hour).”
4 Turn the control dial to adjust the hour.
5 Press ¢ or 4 to select “Clock Min
(minute).”
6 Turn the control dial to adjust the minute.
Nov 04, 2008 | JVC KD-G720 CD Player
Car Audio & Video Logo
234 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
