Question about Samsung Digimax D53 Digital Camera
NEED TO KNOW HOW
AND HOW DO I CHANGE TIME, DAT, AND ALSO OPERATE THE TIMER.
Go to http://www.saemsungcamera.com/customer/download/cus_down_main.asp?key=d53 for the complete manual on this camera. Push the Menu button (middle button on the lower part of the camera) and go over to settings and change the time and date. To operatee the timer, while in camera mode, push the right button on the lower portion of the camera and this lets you use the timer mode (again you can look in the manuel for further instructions.)
Posted on Dec 26, 2007
How to turn off timer
I wouls unplug the TV overnight and see it it resets the timer feature. To pair the remote, you need to know the code and the pairing procedure - most remotes come with a manual or you will need to spend some time on Google.
May 25, 2015 | Televison & Video
Dx4500 ge dryer
Maybe the knob is broken and slipping on timer shaft. If not, replace timer.
Sep 10, 2017 | Dryers
Wire a time switch to a pool pump motor
Yes.
240Volt can be turned ON-OFF by cutting power to one of the two 120Volt wires in the 240Volt circuit. You need Neutral wire for 120V, while 240V does not require neutral wire.
http://waterheatertimer.org/See-inside-main-breaker-box.html#120-240
http://waterheatertimer.org/images/T-101-wired-to-control-240-800.jpg
If you have Intermatic 120Volt box timer such as T101 or T103, then 120Volt WH1570 clock motor on back of timer can be changed to 240Volt WG1573.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Other brands timer, it might be possible to change clock motor.
Add comment with brand and model of timer.
If the timer turns OFF power to salt computer, the computer will not operate until power resumes.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 24, 2013 | Hardware & Accessories
Glow plug burn
It sounds like the timer is not turning off the glow plugs as is should. At least not consistantly. You may want to cycle them several times and verify they do turn off every time.
Jan 17, 2012 | 2007 Dodge Sprinter
Find manual for woods 59028 programmable timer switch
1) Set current time:
Press reset button to clear all programs , display should flash 12:00 AM Monday
Press and hold CLOCK button.
Press Hour, minute and day buttons until current hour minute and day display.
Release Clock button.
Next step is to program the timer
Example shows how to turn on at 5PM each day and turn off at 11 PM each day.
2) Programming review: Each program requires ON time to be set, and then OFF time to be set For example you set Program1 ON 5:00PM for ALL days. And then you set Program1 OFF 11PM for ALL days. Minimum on-off set time is 1 minute.
3) Programming steps: Press PROG button until Timer 1 ON appears on display Use Hour button to set 5 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 ON 4) Now for Program1 OFF 5) To set Program1 Off Press PROG button until Timer 1 OFF shows in display. Use Hour button to set 11 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 OFF 6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time. If you want to set another program, press PROG button until Timer 2 ON displays 7) After setting programs, press Clock button so current time shows. 8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
Nov 21, 2011 | Woods 59028 Programmable Timer Switch...
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
I have 3 lights and want 1 light to come on for 15 sec and then off and another 1 to come on for 15 sec and then off and then the last light to come on for 15 sec and then off and start the process all...
Intermatic 70815CR
30 amp max, selectable voltage 120V 240V etc.
You want to control 3 separate circuits.
So you need a timer with minimum of 3 independent relays.
Each circuit has a different program.
So you need a 3-channel timer. Each channel is programmed separately to operate a different relay.
You want timer to operate in 15 second intervals. Most electronic timers have minimum 1 minute on-off, so you need electronic timer with pulse capability.
May 11, 2010 | Amperite Dayton Solid State Timer On Delay...
Why my acer laptops 2303 nlc date changes every
Go into your BIOS and change the date there and the save changes and exit. Hopefully on the reboot when you get into windows the dtae will read prroperly If it does then turn off the laptop and then turn it back on and see if the date is still reading properly. If it does then you know it was a BIOS issue.
If the date still doesn't read properly then you know that the BIOS battery is weak and not holding memory and so the battery would need to be replaced.
Aug 06, 2009 | Acer Computers & Internet
I don't know how to use the self timer.
Press the self-timer button repeatedly to select the time, 2 seconds/10 seconds/ Off. Press the shutter button ,the self-timer lamp will flash, the shutter will operate after 2 or 10 seconds.
May 22, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Samsung Digimax D53 Digital Camera Logo
56 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
