Question about Compaq 7500 17" CRT Monitor
Out of frequency set resolution or see monitor
Out of frequency set resolution or see monitor user guide .
error in monitor what ihave to do
  • 3,940 Answers
If you are getting a splash screen (COMPAQ) then video goes black, you can try this. Boot system in Enable VGA mode from the F8 menu and see if you get to the desktop. If you do, you can then go to display properties and adjust the resolution to the Optimal for the monitor.
If you do not get a splash screen, check you cable connections and ensure the Video cable is properly seated and no bent pins. If issue is occurring after the system was moved, also ensure that the correct video adapter connection is being used on the tower, as there may be 2
Posted on Oct 04, 2009
My computer monitor is out of frequency please solve this problem
Posted on Nov 17, 2009
  • 51 Answers
You might have set resolution too high.
There are 2 solution.
1) Connect your computer with higher resolution monitor decrese the resolution and it will work fine.
2nd solution
start your computer in safe mode disable its graphics device reboot your computer and it should work fine this time.
If you find problem let me know
regards
What dose it mean when screen says out of frequency
This error indicates that your video card resolution is set igher than the monitor can display. Try booting into safemode and changing the resolution.
Here is a link to the Gateway site spec page for that monitor.
http://support.gateway.com/s/MONITOR/7003943/700394318.shtml
The maximum resolution it will display is 1024 X 768 which is very low for current video cards, your card may not go that low. Check it if it does not go then you will need to get a new monitor that supports the resolution that your computer can put out.
Feb 19, 2012 | Gateway FPD 1520 15" Flat Panel LCD...
My hp monitor S5500 when boot on it desplay out of frequency range and set resolution lower or see monitor users guide. What can i do to clear this information.
It means that the resolution set in the pc is higher than what your monitor can handle. Boot in Safe Mode, go to Control Panel > Display and in the Settings put a lower resolution - 800x600.
Jul 15, 2011 | HP Computers & Internet
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
Frequency out of range
the monitors resolution range is only to 1280X740 or 780
and your video card may also need an upgrade.
The game may require a higher resolution that is not compatible with the the devices mentioned.
Jul 08, 2010 | E-Machines eMachines Monitor E15T4
Have blank screen with box in middle Analog out of range 62.9kHz / 120Hz
whatever you are trying to attach to the tv is set to the wrong frequency. If it is a computer you need to change the video settings by attaching a known working monitor and selecting another resolution. You will have to keep trying if the new resolution doesnt work. trial and error is your only option here. it will work when you have a system that displays within that frequency and in a supported resolution.
GOOD LUCK AND PLS RATE THIS POST!!
Feb 21, 2010 | LG L1780U (Black, Silver) 17" LCD Monitor
Monitor displays Msg. frequency out of range, screen is black
Start your computer and press the F8 when the manufacturer's logo screen is showing. This will bring you to the Windows startup menu. Pick "start in VGA mode" and windows will start up with video settings you monitor can handle. Then you can change your video settings so Windows will start normally with your monitor.
Mar 31, 2009 | Compaq Computers & Internet
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
Feb 06, 2009 | Compaq Computers & Internet
Monitor can not open
usual cause is defective 5 volts 3 pin regulator..
Jan 01, 2009 | Compaq V700 17" CRT Monitor
Problem with WYSE Winterm 3235LE
Tsaukpaetra is correct it's a resolution mis-match with the monitor you are using. If you have Rshadow loaded on the winterm you can VNC into it and change the resolution. If not you can hold down the letter "G" on the keyboard to perform a factory reset.
Aug 29, 2008 | WYSE Winterm 3235LE Network Terminal
Moniter says out of frequency set resolution lower or see user guide
The settings you need to change are actually on the computer's video hardware. Assuming you are using a Windows machine, right click anywhere on the desktop. Select Properties, then the Settings tab. You should see a resolution slider that you can adjust. There should be an Advanced button that will give you access to other settings that are possible with your hardware. This is where you can adjust the frequency.
If you are unable to see anything because of this problem then you may need to boot into Safe Mode to correct this. Let me know.
Good luck.
Dec 22, 2007 | HP Compaq FS7600 17" CRT Monitor
Computers & Internet Logo
336 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
