Question about Xerox WorkCentre XD155DF Laser Printer
Xerox WorkCentre XD155DF front panel error code "L 6" What does that mean and what is te repair? It occurs during power on and will not continue to power up after the code is encountered.
    Sergeant:
    Novelist:
  • 183 Answers
Hello there breinhart.
Here's your geek-steer ...
Per manufacturer's support page, your device "Xerox WorkCentre XD155DF" is no longer made or sold by Xerox, therefore I'm presuming it's maybe getting a little long in the tooth.
Unable to locate error code "L 6"/"L6" for this device. However, per the "XD Series" user's guide, errors L1 thru L5 provides suggested solution of what's quoted following. Logic dictates L6 would have been paired up right alongside if not for this being an earlier published parent document to your later ...155DF suffix'd device.
[QUOTE]
Switch OFF the Main Power.
Wait approximately 5 seconds.
Switch ON the Main Power.
If the status code continues, call for service.
[END QUOTE]
... which in tech parlance is an age-old, fundamental-as-they-come procedure known as a "reset/reinitialization". Which actually, right up to present day, is a surprisingly often successful remedy.
== SUGGESTION ==
If I were you, I'd first try a quick reset/reinitialization as guide instructs. If/when that doesn't remedy, start from scratch:
  1. Check for/download latest driver(s) from support website
  2. Uninstall device's software.
  3. Turn off device.
  4. Unplug device.
  5. Wait 10 minutes.
  6. Disconnect all remaining cables/cords (both ends).
  7. Inspect for damage/wear and clean each cables' end fittings.
  8. Reconnect all cables/cords.
  9. Reboot.
  10. Perform a registry cleanup.
  11. Reinstall device using latest version software/driver(s), carefully following manufacturer's installation checklist.
That's just about as anal-retentive and thorough a reset as you can accomplish. Many would think it's too anal, but not me. I've discovered over a long period of time, from long-ago up to this very day ... printer type devices are THE most persnickety of them all. They're the house-cat of the PC/IT world ... vay'we, vay'we scay'we!
If still problem-ed, I'm sorry to say there's nothing much else I can offer as a solution, other than what the manufacturer's guidance is: "call for service".
Good luck to you, and please post back ...
  • to let me (and interested others) know how things worked out,
  • if you have any further questions,
  • to provide clarification or feedback.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig) Puget Sound, WA USA
Posted on Oct 04, 2009
  • Craig The Geekinator
    Craig The Geekinator Oct 04, 2009
    @ breinhart
    I forgot to mention, I normally have been shying away from printer/scanner questions as I've eventually grown weary of them. However, the only reason I responded to yours was for this reason:
    You wrote a definitively text-book standard trouble-report:
    • Included the entire nonmencalture of the device (make+model+full series).
    • Concise decription of problem (what's encountered)
    • Included an error code (yum, yum!)
    • Stating what precipitates (i.e., is being done/occuring prior to ... prompts) the problem.
    Kudos breinhart ... doesn't get much better than that.
    @ Anyone else reading this.
    Take note, and try as best you can to duplicate, and you too will almost guarantee yourself a gleefully given tech reponse every time.
    Cheers!
  • Antal O. Juhasz Mar 29, 2013
    Unfortunately none of the software suggestions work because the printer wont power up. It shuts down maybe 30 sec after it is turned on and it displays "L" and than a "6". How do you recommend reloading the software ? I assume you mean into the printer. I may have to call a repairman.
Sln for Xerox wc 5330 error code 092-315
092-315 ATC Fail RAP
BSD-ON: BSD 9.3 - Development and Toner Dispense Control
The frequency at which the ATC Average Fail or the ATC Amplitude Fail has been occurring
has exceeded the threshold value.
NOTE: •
Although this Fault can be cleared by turning the power OFF and ON and it will be possible to output a few sheets of printouts, when this Fault has occurred a certain number of
times, it will no longer be clearable by turning the power OFF and ON. To clear it, clear the
value of NVM location [752-022] (ATC Average Fail) or NVM location [752-023] (ATC
Amplitude Fail) to "0" (
NVM Read/Write). If the machine is not repaired back to normal
status, this Fault will occur again during the operation.
• When turning the power OFF, turn OFF the power switch first and then the main power
switch.
Procedure
Check the following:
• The connection between the MCU PWB
P/J413 and the Xero/Developer Cartridge P/
J615
for open circuit, short circuit, and poor contact
• The Toner Dispense Motor for revolution failure:
Component Control [093-002] (PL 8.2)
• The Toner Cartridge for internal toner blockage
If no problems are found, replace the following parts in sequence:
• Drum Cartridge (
PL 8.1)
• MCU PWB (
PL 18.2)
See Service Manual page 827 (2-831):
https://docviewer.yandex.ru/?url=ya-disk-public%3A%2F%2FEXv3f5bJ9f7WprcvyqxuiVsXMlmyrp4nx2LzJa50u6s%3D&name=Xerox_WC_5335F_SD.pdf&page=827&c=55716712dd0d
Xerox WorkCentre 5335 Family 5325 5330 5335 Service Manual
Jun 05, 2015 | Xerox WorkCentre 5325 5330 5335 Black...
Whats mean by fault code 116-330 ?
116-330 RAP Error during HDD check. Disconnect power for several minutes and restart. If error persists, contact manufacturer.
Jan 08, 2015 | Xerox WorkCentre 5330/C Copier
My Xerox Workcentre copier gives an error message E2 paper jam and I have cleared every possible jam. The copier still thinks its jammed and won't start up now.
I just had this same issue with my phaser3300MFP. Initially I thought this was a software issue but after careful inspection, there indeed was still a jam. I would check the fuser area of the machine. There is most likely a page jammed in that area and they can be hard to see.
Nov 10, 2010 | Xerox WorkCentre XD155DF Laser Printer
WorkCentre XD155DF Laser Printer: I have one printer XEROS Workcentre XD155df, but i...
This printer will only work for Win XP and 2000. NOT Win 7. The drivers are available from the support page at xerox.com.
May 18, 2010 | Xerox WorkCentre XD155DF Laser Printer
Error 016-311 xerox workcentre M128
This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
Nov 08, 2009 | Xerox WorkCentre M128 Copier
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
I have error code h 3
this problem can be cause by three things abadheat lamp/thermalfuse/thirmister make sure the sensor is clean first the thermal fuse is self resetting when it cools down.
Apr 09, 2009 | Xerox WorkCentre XD155DF Laser Printer
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox workcentre xd120f laser b/w printer
You can download the manual on the following link. How to clear the flashing "P" is on page 14. http://download.support.xerox.com/pub/docs/XD155df/userdocs/any-os/en/newxd.pdf
Aug 04, 2007 | Xerox WorkCentre XD120F Laser Printer
Xerox WorkCentre XD155DF Laser Printer Logo
508 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
