Question about Casio Exilim Zoom EX-Z700 Digital Camera
Camera won't open
I was transferring files back to the digital camera from my laptop when suddenly an error occurred. I tried closing all running applications in hopes of just re-running them again to finish the transfer; but, as I disconnected the cam from the pc & power then, reconnected it again - It won't open.
The digicam won't open regardless if its connected to the pod charger.
What happened? How can I fix this?
  • 98 Answers
Probably by reloading the software. You aren't supposed to disconnect in the middle of a transfer (although, sometimes it is inevietable).
Posted on Dec 23, 2007
CameraWindow won't open or will suddenly close before loading
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jun 03, 2012 | Canon PowerShot S90 Digital Camera
SD card not transfering raw files to computer completely
Please remove the SD card from the camera. Connect the SD card to the computer using the external memory card reader and then transfer all the images in the computer or laptop. Then try to open all the images.
Feb 20, 2012 | Nikon D80 Digital Camera
Hello, gud day! please help me fixing my problem with my camera. im using canon digital camera IXUS 87015, im trying to transfer my photos to my laptop but suddenly i cannot because the result says that my...
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jun 20, 2011 | Canon PowerShot SD880 IS / Digital IXUS...
Hi, Im having trouble getting the olympus master software to recognize my fe 340 connection via USB port. This has suddenly occured , preventing me from uploading and transferring new images. I've never...
Sep 11, 2010 | Olympus FE-340 Digital Camera
File error
It is picture file that stops file transfer function, delete that picture and continue or go to memory card through my computer > mass storage drive and delete that file or copy rest of files and past in computer some where like my documents etc.
That particular picture file DSC03270.jpg is incomplete/ corrupted and causing problem in files transfer operation. Either delete it or bypass it and transfer rest of files from camera.
After transferring files to computer, format memory card to avoid any problem in next time as option would be in camera menu.
Let me know if you have additional question.
Thanks.
May 30, 2010 | Sony Cyber-shot DSC-H2 Digital Camera
Error code #0x80070052 occured while attempting to transfer photos from memory stick back to camera chip
The error message means "The directory or file cannot be created."
Make sure the folder containing photos is having sufficient write permission .
Hope this helps .
Jan 27, 2010 | Fuji FinePix Z1 Digital Camera
Nikon coolpix L11 pics won't transfer onto computer anymore
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Jul 28, 2009 | Nikon Coolpix L11 Digital Camera
File Error now shows in camera for rotated photos from PC.
The camera will not display photos that have been edited by something else. Rotating counts as editing. Just opening a photo and then saving it without doing anything else counts as editing.
Apr 29, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Computer not recognizing my camera when connected
Most of the issues can be solved by either reinstalling the software or by disconnecting and reconnecting the device.
In this case we can close in on three solutions
1) The USB drive in the system is not functioning. Try connecting any other USB devices to the same USB port and check whether it works or not. If the other device works well then it could be a problem with the data cable or with the port in the camera (usually firewire)
2) The data cable used to transfer data might have become faulty.Try using another data cable if possible and still the same issue continues then try connecting another camera to the system and if the other camera gets detected then the problem must be with the camera.
3) Try connecting the same camera to another system and see whether the camera gets detected. If no, then the port in the camera is defective.
After this we can close in on which could be faulty. data cable / Computer / Camera.
Feb 25, 2009 | Canon PowerShot SD1000 Digital Camera
Error message "unknown error has occurred"
how to transfer picturesd from digital camera to pc just watch video
Jan 07, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Casio Exilim Zoom EX-Z700 Digital Camera Logo
Top Casio Cameras Experts
pontelemon
pontelemon
Ron Grant
Level 1 Expert
Are you a Casio Camera Expert? Answer questions, earn points and help others
