Question about Kenmore Dryers
Gas valve coil
How to replace the gas valve coil (part number 279834) on a Kenmore dryer?
    President:
  • 1,304 Answers
Remove the two screws onder the dryer lint cover
slide a putty knife between top and cabinet
should feel a clip on each side,, just push in and pop it up
once the top is up on each side about an inch down where the front lips the sides you will see a 5/16 screw remove those
list the door up off the bottom dogs turn to the right and out of your way, carefull of the wires thats the door switch.
look right in front on the bottom to the right
there is your gas valve and coils
as you can see they are held down by two philips screws remove those and remove the cover
care ful to mark the nodes on the coils on has two one has three
replace one at a time makeing sure the orientation is correct,, two up three down whatever you had
DONT FORGET TO PLUG THEM BACK IN
back your way out of the machine your edaone
Posted on Oct 06, 2009
My whirpool AWD 60 dryer is not hot enough
Yes it is. Clean the exhaust, then replace the gas solenoid coils part # 5303931775 or #279834. Gas Valve Solenoid 279834 ,Gas Valve Solenoid 5303931775 the coils will grow weaker and not heat for the entire cycle....
Jun 19, 2016 | Dryers
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
I HAVE A KENMORE 80 SERIES GAS DRYER. WHEN YOU TURN IT ON IT FIRES UP AND GETS HOT. AFTER A WHILE (5-10 MIN'S) FIRE GOSE OUT AND WILL NOT COME BACK ON.
If what happens is the flame comes on when it first starts,after the flame goes off you see the igniter glows then goes off but no flame,the coils that open the gas valve are working while thier cool but once the dryer gets running,when warm to hot the gas valve coils wont open the gas valve so when the igniter comes on and no flame the coils have failed to open gas valve and need to be replaced, all manufactures use the same coil supplied by one parts supplier, and them not opening the valve when warm is a very common occurence regardless of what brand gas dryer it is.
The part number for the coils is 279834 they could be picked up from your local appliance parts store for under $20 or online at;
repairclinic.com
searspartsdirect.com
assuredparts.com
apdepot.com
appliancepartspros.com
Gene
Aug 20, 2011 | Dryers
Whirlpool LX1550 gas dryer. Not heating. Lights once at beginning and then shuts off. Does not liht again.
Remove the front panel to get to the gas valve. (Sorry, without a valid model number can't tell how to do it)
Remove the metal bracket holding gas valve coils.
Replace both gas valve coils, part number 279834.
Good luck,
Vlad
First Choice Appliance
Aug 21, 2010 | Whirlpool Dryers
Cold dryer
if the dryer runs normal for the first 15 to 30 minutes you have bad gas coils located on the top of the gas valve,take out the 2 phillips screws,remove the top cover and change out the gas coils.when the coils are failing they will work until they heat up then they stop letting the gas come into the dryer,when they cool down then they will work again.change out the gas coils part number 279834
Mar 27, 2010 | Kenmore 73952 Gas Dryer
We need to replace the heating coil and can't find the location to put it inthe part number is 279834 that needs to be replaced
That part is 2 pieces, solenoid coil kit, for the gas valve. it is in the bottom of the case on the gas valve assembly.
Feb 26, 2010 | Whirlpool LGR5636PQ Gas Dryer
Series 80 gas dryer. Turn on and flame only lasts few mins.
Intermittent contact inside one of the gas valve coils. Replace. Part number 279834.
You can order them at AP Wagner. Use coupon "New10" for 10% off
Oct 16, 2009 | Kenmore 75944 Gas Dryer
I have a kenmore #110.72812101 gas dryer. the burner comes on, then goes off after 2-3 min. is there a schematic online? thanks, jim
The 2 coils ( kit ) need to be replaced on the burner valve . One of them gets hot and opens ( shorts internally ) and wont work again , until dryer cools down for a while . Pt # 279834 . You can easily replace . 2 screws hold the coil bracket on . Don't even have to cut off the gas , or pull the dryer out from wall .
Aug 29, 2009 | Kenmore Dryers
Kenmore dryer ( gas )
camaro Most likely the problem is bad gas valve coils located on the top of the gas valve . Unscrew the two screws holding the coil bracket and replace the coils. The part number for the Whirlpool gas valve coils is 279834. Good luck Gendos, post back
Jun 26, 2007 | Kenmore 62882 Electric Dryer
Dryers Logo
181 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
