Question about Dell Inspiron 531 Athlon 64 X2 4400+ 2.3GHz 1GB 500GB DVD RW Vista Home Premium PC Desktop
Restore system restore doesn't run properly......is there a way to do a soft restore from the discs where I don't lose all my files?
  • 3,940 Answers
If you are using Windows XP, you can do a Repair install of Windows, which MAY resolve your problems. (Generally I do not recommend them, as normally the results are unsatisfactory.) Another option is a PARALLEL install of Windows. You start an install as normal, then change the install path to a locations other than C:\windows (C:\WinXP for example) use a different user name and an different computer name to avoid overwriting any files in the MY DOCUMENTS folder. Once done and drivers installed you can browse the old Windows install for your data.
http://www.windowsreinstall.com/winxppro/installxpcdparallell/indexfullpage.htm
If denied access then you may need to take file ownership. http://support.microsoft.com/kb/308421
Posted on Oct 04, 2009
  • 85 Answers
No a system restore will erase all your information.
HP Pavilion G7-1227nr storage controllers drivers anywhere?
Since you talked to a service rep I'm guessing they sent you to the website but here is the link just in case.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lang=en&lc=en&product=5199550&
Jul 16, 2013 | HP Computers & Internet
When turn notebook on screen reads error:NTLDR missing and does nothing else except noticed bottom of notebook to get real hot, real fast. what can i do?
Run the Check Disk Utility. You will need a Repair Disc or Operating System Disc.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 24, 2012 | HP Compaq nx6110 Notebook
Cant get past blue hp invent screen
Sounds like you have corrupt or missing boot or system files. First try these steps.
1) Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see the SAFE MODE option. Take the Safe Mode option and see if you machine boots into safe mode. If it does safe mode look different, but that is normal, the icons are bigger and the screen is darker. Once in safe mode click Start/Programs/Accessories/System Tools/System Restore. Once you are in system restore see if you can roll your system back to a date and time before you had the boot up problem. Don't worry, System Restore does not remove any of your documents, music, pics, videos or data. System Recovery removes everything and sets your computer back to when you first purchased it. Once the restore is complete reboot and see if your problem is solved. If not proceed to step 2.
2) You'll need a repair disc or system disc to get around it. If you have one insert it in the cd drive and boot from it. Get to the recovery screen where you can type in the black widow with the white writing the following command: chkdsk /r
Check disk will run well over an hour or more so be patient. You will even see it going from high to low percentage of completion, but that's normal. When it finishes reboot and see if you're ok. If not you'll have to reinstall the operating system. Try doing a repair install whereas it looks to see if there is an already existing operating system on the computer and repairs it without losing any of your data, documents, music, pictures, videos etc. If you do a new install it will lose everything.
Mar 20, 2012 | Computers & Internet
Windows internet explorer not working
was explorer working perfectly on your computer previously? If yes, you can try system restore.
System restore can help to back date your computer to the time when explorer was working.
Start > All programs > Accessories > System tools > System restore.
Read and follow instructions. System will restart during the restore process.....
After that try again and observe if explorer will function/work properly/normally.
Please let me know if this doesn't solve your problem so that I can help you further.
Regards.
Jan 05, 2012 | ASUS Computers & Internet
I want to reset it
@lslchrisorei
Toshiba laptops have a built-in recovery mode on the system wherein you don't need to use a disc to restore it to factory default (if that's what you mean by "I want to reset it". The hotkey for the recovery is the 0 key (don't use the key on the numpad). To activate it, you need to turn the computer off, then you need to hold the 0 key then turn the computer back ON. If you hear a continuous beep, you can let go of the key and It will then say "Windows is loading files" and will proceed with System Recovery. If this doesn't work, that means that this computer doesn't have the hidden partition for you to restore the unit to factory defaults (either it's faulty or it's not there) and you need to order the recovery discs from Toshiba at 1-800-457-7777 (for US) and for Canada, it's 1-800-663-0378.
If you're still under warranty, they'll give it to you for free.
Cheers
Sep 05, 2011 | Toshiba Satellite L305D-S5874 Laptop
How put window vista back to factory setting without a disk
@jamiegard461
Toshiba laptops have a built-in recovery mode on the system wherein you don't need to use a disc to restore it to factory default. The hotkey for the recovery is the 0 key (don't use the key on the numpad if you have one). To activate it, you need to turn the computer off, then you need to hold the 0 key then turn the computer back ON. If you hear a continuous beep, you can let go of the key and It will then say "Windows is loading files". If this doesn't work, that means that this computer doesn't have the hidden partition for you to restore the unit to factory defaults (either it's faulty or it's not there) and you need to order the recovery discs from Toshiba at 1-800-457-7777 if you purchased the computer in the US and for Canada, it's 1-800-663-0378.
Cheers
Sep 04, 2011 | Toshiba Satellite L45-S7423 Notebook
I need to do a system restore on my toshiba but i lost the disk. Can i use another toshibas computers disk?
No, each recovery disc contains an image of the OS and not an individual installer for the OS. Best option is to contact their Tech Support and ask for a Recovery Disc or have them walk you through Restoring to Factory state. Please take note this would lead to your Hard Drive being wiped clean then the OS reinstalled, so you will lose all your files. However if you can still boot to Windows perform the built-in System Restore for Windows. You can do this by clicking on Start > All Programs > Accessories > System Tools > System Restore and it will allow you to pick a date on how far back you want to Restore. And the good part for this method is you will not lose your files.
Jun 10, 2010 | Computers & Internet
When i tried to start windows i get this error message every time ''windows failed to load because the system registry file is missing, or corrupt'' , i have a compaq presario vs210us... Can any tell me...
What OS are you running? For XP and Win2000, get the OS install or upgrade disc for your version of Windows. Boot from the CD. (F12 just after the POST will let you choose the boot location. Try again if you miss the timing.)
Enter the recovery console and try to restore the old registry. See http://support.microsoft.com/kb/307545 for the XP commands involved.
Windows 7 install discs also have some recovery options when you boot from the CD/DVD as a LiveCD. But it is called the System Recovery (you can build your own System Repair disc with a working version) See the following for more information:
http://www.sevenforums.com/tutorials/668-system-recovery-options.html and then System Restore:
http://www.sevenforums.com/tutorials/700-system-restore.html
Vista has something similar but didn't have an option for building a System Repair disc to my knowledge.
You might lose some registry information (depending on how often you had the system backup the critical information). These methods basically roll back to a previous version.
Good luck.
May 04, 2010 | HP Compaq Presario V6210US Notebook
Disc reading problem
Be sure to folleow these instructions to the letter, you could damage your PS32_bing.gif if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don’t make a mistake!! Sorry, I had to say it, I don’t want anyone mad at me if they make a mistake, don’t back up their data and erase it, and then blame me…
The current version of the ps3 firmware has a “recovery console”.
You access it by
1. Start with having the system in standby (redlight is on)
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options
1. Restart System: Restarts the PLAYSTATION®3 System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the PLAYSTATION®3 System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that’s stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
Here is a video of the recovery screen.
www.youtube.com/watch?v=m0SPmkV-jco
If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive. However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash
Mar 13, 2010 | Sony Playstation 3 (PS3) Console
Open Questions:
Dell Inspiron 531 Athlon 64 X2 4400+ 2.3GHz 1GB 500GB DVD RW Vista Home Premium PC Desktop Logo
42 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
