Question about Dryers
Moldy smell in dryer
My dryer smells moldy. the vent was plugged and we unplugged it and wash the dryer out with bleach however it is still moldy smell could it be somewhere else in the dryer
    President:
  • 1,922 Answers
Remove the front and top covers and remove drum belt then drum and vacuum and wash out all lint that couldnt get out during your vent being plugged then leave it apart and fan dry it out thoroughly and put it together
Posted on Oct 04, 2009
There is a musty smell in the maytag washer even b4 I fill it with water, I've disconneted the hoses & flushed with bleach that did not take care of it,Iv'e run washes without clothes in it...
When a moldy or musty smell develops in a washing machine, many times the smell is coming from the open areas of the agitator. Water along with soap and/or liquid softener sometimes splashes into an open agitator, and when the lid is closed it does not dry out. Instead, mold begins to form, and a musty smell wafts from inside the machine, even after the lid has been opened for an extended period of time. Until the mold is removed the washing machine will continue to smell bad, even if it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect in the holes, and when it does not dry fast enough it ends up smelling musty and moldy. Even the top of the rim can become moldy and musty, but proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
May 15, 2011 | Maytag Washing Machines
After completing a load of clothing, the laundry sometimes has a moldy smell. If it doesn't smell right away, it smells after wearing the clothing and sweat a bit. This is not a body smell - this is a...
It sounds like your leaving the clothes in the washer long after the cycle is finished. Once your clothes smell from the washer they will smell moldy dry.
Aug 19, 2010 | Dryers
My kenmore front load washer has aquired this rank moldy smell. If don't take the washed load out immediately the nasty smell penetrates into the clothes and smells even after drying. Is there some sort of...
you can run a regular cycle with bleach as instructed in the manual. there may be mold on the rubber where the door closes. wash this with water and bleach. to avoid this problem in the future you can loosen the light bulb then you can leave the door open a little all the time with no light. press the off button when not in use.
Jul 26, 2017 | Kenmore 44921 Front Load Washer
My Maytag Neptune washing machine makes clothes smell moldy
The problem may be standing water in the discharge hose. If this is the case unplug the machine and remove the hose from the back of the machine, and water will poor out. If you smell mold from the hose, this could be the cause. Rinse the hose out thoroughly with bleach, if its a corrugated hose they are prone to standing water inside and you may want to replace it with a non- corrugated hose. I suggest you run the machine when hose is re- attached with only bleach a couple of times and leave the washer door ajar to completely dry the inside of the drum afterwards, too. I hope this helps you! Good luck!
Dec 29, 2009 | Washing Machines
Moldy smell always tried bleach and vinegar. Use
You need to replace the rubber gasket around the front of the door. This gasket holds moisture and over time molds. Give us a call or email us and we;ll be sure to get the correct gasket out to you right away. We hope this helps and we hope to hear back from you real soon.
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smelling washing machine.....
Hi, did you wipe out the inside of the boot with the bleach? This is a big problem with all front load machines. If you call the Whirlpool, I believe they have a product out now to help the odor as well.
Vic
May 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell
try running it throgh a cycle with nothing but hot water and bleach let set for a couple of minutes between cycles with water in it may have to do a couple of times
Mar 29, 2009 | Whirlpool LSB6200KQ Top Load Washer
Mold & Smelly in Washer
Wash on hottest and longest cycle with regular laundry soap and a bottle of vinegar. After cycle, wash again with soap on hottest/longest cycle. This will clean your washer like new.
Nov 21, 2008 | LG WM-2277HW Front Load Washer
Moldy smell in washer
run cycle using bleach only in water after cycle use a bleach/water solution to thoroughly wash door seal be sure to pull seal at bottom of drum opening and clean inside lip in future leave door open as much as possible between cycles just remember YOU ARE NOT ALONE..all front loaders no matter the brand have same issue some just worse than others
Jun 18, 2008 | Kenmore Elite 45986 Front Load Washer
Moldy smell
Turn it off, unplug it. Remove filter and check if filter and/or filter and pump housing are clogged with something "smelly". When you're at it check the drain pipe for too.
May 08, 2008 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
127 people viewed this question
Top Dryers Experts
