Question about Acer Computers & Internet
It will connect then disconnect all the time
It will connect then about 1 min disconnect
  • 51 Answers
You got some IP conflict Issue. If you have two router or one modem and one router this issue may ocur.
check if you are having IP conflict of diffrent devices
Posted on Oct 04, 2009
Canon ir 3245err 000024-0001 how to solve it
E024 The developing assembly connector is disconnected/Disconnection of Toner sensor.
u can do this steps : Disconnection of the wire used for detecting the connection of the
toner level sensor is found.
When the disconnection of the wire used for detecting the connection
of the toner level sensor has been detected for 7.5 min without
interruption (12.5 min in the manual /envelop cassette feeding).
of the toner level sensor has been detected for 12.5 min without
interruption
if it is problamatic you have to replace sensor.
Apr 04, 2011 | Canon ImageRunner 3245 Black and White...
Recently bought the Belkin Play max router F7D4302 & wireless play adapter F7D4301. I'm having intermitten wireless disconnection. Everytime when the wireless adapter disconnect after every...
You may need to update your adapter drivers> Here is a site for Belkin and your adapter:
http://en-us-support.belkin.com/app/answers/detail/a_id/3748/~/f7d4101-play-wireless-usb-adapter---drivers-%26-software
Mar 18, 2011 | Belkin Play Wireless USB Adapter (F7D4101)
My Linksys WTR 120N evry time is disconnecting from Modem
There are many reasons why router would disconnect from the modem.
First connect only modem to the computer and check if your internet disconnects.If it does then contact your ISP..if it doesn't then follow the following steps..
1)Disconnect the power for both modem and router for one minute and re-connect the power and check if it worked.
2)If not..You might need to update the firmware on the router. Log into the manufacturer's web site and download the latest version of the firmware for your model and update it.
3)Even if that doesn't work..You might need to reset and re-configure your router. Press the reset button for 10 mins and disconnect the power for both modem and router for 1 minute and then re-connect the power and run the configuration disk for the router(PS: you require the disk of the router and ISP settings.)
Hope this helped.
Jan 21, 2011 | Linksys Computers & Internet
We have a Canon iR 2270 and get the the Error message E000024-0001. What might the problem be? How do i solve it?
if e000024-0001 is comming plz clean the toner box in which magnet roll is runing then try you machine is not give this e000024-0001 singnal.
Dec 28, 2010 | Canon IMAGERUNNER 2230 Copier
Ignition timing
make positive of this then because your pressure pully when connected might offset timing marks ,to reset any ecu disconnect battt for 1 min.
Oct 07, 2009 | 1989 Nissan Maxima
2001 Dodge Dakota Extended Cab V-6 radio won't function
the radio is in theft lock, you will need your unique code that came with the truck new to unlock it.
Jun 28, 2009 | 2001 Dodge Dakota
Ir 3570 error e000024-0000
0000 The connection detection signal is absent
continuously for 100 msec. Replace the developing assembly toner sensor. Connect the connector. Replace the DC controller
PCB.
0001 Disconnection of the wire used for detecting the
connection of the toner level sensor is found.
detecting the connection of the toner level sensor
cassette feeding).
interruption.
-iR4570/3570/3530
cassette feeding).
-iR2870/2270/2230
interruption.
Correct the cable. Replace the sensor.
TRY THIS:
Remove toner and check for broken parts on tube, check the connection of toner assy, reconect all connectors on dc controller pcb.
If you removed the toner assy before the error occcured check if all connectors are properly inserted.
Jun 15, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Wirless going down randomly
Hello ajestrella,
If your connection is a DSL, I think you need a "Micro Filter" to be connected to your phone lines. This will eliminate the disconnection or unwanted signals that causes you network to go off or disconnected. You can request this device from your telephone company.
Mar 11, 2009 | NetGear WGR614 Wireless Router
Netgear
There are two things involved in getting disconnected either your comp is getting disconnected or your router.
Instance 1
Computer getting disconnected connect your comp and router with ethernet cable if using wireless. Because at times it's not router but the wireless connectivity that gets loost.
Instance 2
Router getting disconnected...
Reset your router by holding the reset pin at the back of your router for 15 secs and lights will start flashing on router wait for 1 min you'll have router reset to default settings and now check that dsl or internet light on your router is flashing or static if flashing contact your isp issue with the line if static run the disc for router installation again and it'll remain connected after successful installation.
Apr 22, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
276 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
