Question about Lucent Lands Phones
Programming for speed dial the Lucent Business
How do I program for speed dial the Lucent Business phone model 6220A0!A
SOURCE: Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Posted on Nov 29, 2008
  • 63 Answers
SOURCE: Programming speed dial numbers into NEC DTU-32D-1A phone
hit feature key,hit a line key,dial 9 plus the number,hit feature
Posted on Mar 14, 2009
SOURCE: MOTO W755 Speed Dial does not work
SOLUTION: Menu to Setting/Tools to Call Settings to One-Touch Dial: Turn it ON.
Posted on Apr 01, 2009
sanond111
SOURCE: I need help programming a Lucent 6408D+ phone
How to program Avaya 6408D+ phone for intercom? Is anyone knows?
Posted on Jul 30, 2009
SOURCE: How to program 6221 Avaya Lucent Analog 10 button
While the handset is on hook,
1. Press "Program" 2. Press the desired Speed Dial botton 3. Enter your to-be-stored phone number 4. Press "Program" to end the session.
Posted on Nov 14, 2009
How do I set my speed dial numbers?
Which ones? System speed is programmed from station 10 or 11 and goes in the 6xx's, depending on your version of software. The start is FEATURE 00 FEAT 6xx and dial the number You can continue programming more numbers by pressing FEAT 6xx or Feat 00 to exit.
Personal speed dial numbers are programmed similarly, except they are in locations 80-99 on each phone and can be programmed from the phone if it's a system phone.
Auto Dial buttons use blank buttons on your set. Feature 00 pressing the button and dialing the outside number store those. Again, Feature another button will let you program another button, or Feature 00 ends programming.
Carl
Jul 12, 2011 | Lucent PARTNER18 Corded Phone
How do i change the numbers of the already programmed speed dials? The phone is a Lucent Partner 18D
If you entered them in system speed dial then you'll need to enterpgogramming on either extension 10 or 11. Enter programming by pressing feature 00,then press feature and the number of the speed dial bank (600-699), then enter in the number you want to over write. press feature 00 when finished.
If your trying to change one of the one touch buttons on the set itsself then press feature 00, press the button you want to change, then enter in the new telephone number. prsss feature 00 to exit programming.
Oct 25, 2010 | Lands Phones
Lucent Partner phone speed dial
At ext 10 or 11, press feature 00
then feature and 600 or whatever code you want
then enter the number as you would dial it.
when done, enter feature 00 to get out of programming.
May 10, 2010 | Avaya Lucent Partner 616 Phone
How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Apr 16, 2010 | Nortel T7316E 2-Line Corded Phone
I want to program the speed dials on our phones and can not find the manual for our old Lucent Partner 18 phones
(For Speed Dials on you phone buttons)
1 Press Feature 00
2 Press the butoon to be programmed
3 Dial the speed dial #
Repeat 2 and 3 for additional #s
hope this helps
--- TeleFurb ---
Nov 11, 2009 | Lucent PARTNER18 Corded Phone
Lucent Avaya Partner System Lost access to Voicemail
Obviously you lost your programming. Question is whether the unit is operational. Best thing to do is contact your local Avaya Business Partner for a repair.
If you tell me your location, I can recommend one.
Apr 01, 2009 | AT&T Lucent Merlin SP 34 Phone
HELP WITH LUCENT PHONE
Dial into vociemail, ht elady will say "Welcome to ............"
Fill in the blanks.
We need to know that before we can tell you.
Oct 23, 2008 | Lucent PARTNER18 Corded Phone
Programmed numbers
Feature 00
Press button to program
enter intercom+number to dial
Feature 00
Aug 22, 2008 | Lucent PARTNER18 Corded Phone
Programming speed dial!!
ARE YOU PROGRAMMING PERSONAL SPEED DIALS, SYSTEM SPEED DIALS OR BUTTONS ON THE PHONE AS SPEED DIALS.
IF SYSTEM YOU MUST BE ALLOWED IN THE PROGRAMMING BY YOUR INSTALLER TO DO THESE UPGRADES. NORMALLY THE RECEPTION/ FIRST EXTENSION ON THE SYSTEM HAS THIS ABILITY. ADMIN PASSWORD IS 1234 PROGRAM 001 IS WHERE YOU PUT IN THE NUMBER AND 002 IS WHERE YOU PUT IN THE NAME
UNDER MANAGER PROGRAMMING, PAGES APPROX 210-215
Apr 28, 2008 | Panasonic KX-T7730 Corded Phone
Merlin Legend (Lucent) phone--changing vm list of extension
I do not fully understand you message but it sounds like you want to get into administrator programming of your voice mail.
I don't deal with voice mail programming. My only suggestion is to try and determine exactly which voice mail model you have and find the "administrator" or "programming" manual for the voice mail.
All manuals are available free at www.avaya.com
Apr 25, 2008 | Lucent PARTNER18 Corded Phone
Lands Phones Logo
99 people viewed this question
Top Lucent Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
tfelton3
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
