HP Pavilion  PC Desktop
Problem for HP Pavilion (PN153AAR) PC Desktop
Why don't the usb ports work on the side of
By fishnish69 on Oct 04, 2009
why don't the usb ports work on the side of monitor
Clarification Request
Posted by pcmatch on Oct 04, 2009
What model of monitor do you have ? Some monitors requires to be connected to the main unit by an USB cable so that its own USB ports to be functional.
Solution #1
posted on Oct 04, 2009
Not Rated)
Dageezer
Rank: Guru  HP Computer Hardware  Expert
Rating: 89%, 963 votes
USB ports on the side of the monitor are a USB HUB. For those ports to work, you must use a USB cable from the monitor (Connection is normally on the bottom USB Type B connection like on a printer) to a USB port on the tower. Once connected, the USB ports on the monitor should be operational.
If the cable is connected and the ports do not work, boot to safe mode (F8 at boot) open device manager, under USB controllers, USB ROOT HUBs, right click and Select PROPERTIES for each root hub (May be up to 7) go to the power management tab, and uncheck the checkbox that allows windows to turn that device off to save power. Once done on all HUBS, reboot in normal mode
Was this helpful?
Yes
No
Solution #2
Not Rated)
dww0642
Rank: Guru  Computer Hardware  Expert
Rating: 90%, 66 votes
is there an extra cable, aside from the Power Cord, and the VGA Cable? if not, look on the back of the monitor, there should be a similar plug in like a USB printer would have, its kinda square. If there is, you just need a USB printer cable to make it work.
Was this helpful?
Yes
No
Popular Solutions for HP Pavilion PC Desktop
Questions and Unsolved Problems for HP Pavilion PC Desktop
Do you recommend HP Pavilion (PN153AAR) PC Desktop?
Answer
Answer
problem connecting to Gnutella network Bearshare 5.2.5
Answer
connecting to the Gnutella network with Bearshare 5.2.5
Answer
Umax 2200 usb scanner & Vistascan 3.55u in Windows XP Scanner installs to the default XP... (More)
Answer
adr=610c Abort program code error 6193
Answer
i have a casio pcr t-2100 and i want to program multiple plu keys in one dept. How do I do that?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Pavilion PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
