My camera won't turn on. I put it on the charger and the lights turn on and everything. I push the power button and all three of the lights flash one at a time but it does nothing. Can you help me?
SOURCE: Kodak V603 Digital CAmera
my kodak v 603 suddenly went dead ,i tried to charge the battery but all i saw was 3 red lights flashing i disconnected right away.
i bought a new battery, when i installed it the camera got hot i removed the battery, what is wrong?
SOURCE: samsung L730 camera not charging
try taking it to your local camera or electronics store and see if they can clean the contacts on your charging port and your battery slot and/or run a coninuity test on your charging port.
SOURCE: Kodak EASYSHARE M1063 won't turn on
For this problem try doing the following:
If problem persist call the 18002356325 for technical support for KODAK Digital cameras
Thanks
Hope this will help
SOURCE: When i go to charge my kodak M863 camera (in the
You can used the USB cable to charged the camera, But some of the M863 camera will not take charged usign the USB cable., I strongy suggest used the AC adaptor just make sure the AC adaptor is 5V ac adaptor it will only charged using the 5V adaptor., About the flashing green it indicates camera is charging just wait for the solid green light it means it fully charged
You may purchased also a special charger for your battery(KLIC-7001)- cahrer model is K8600-C. i think the price of this charger is around $29.00
