Question about Cuisinart Supreme Grind CCM-16PC Grinder
I have a coffeemate flat bottom filter and don't know how course to grind
    Problem Solver:
  • 10 Answers
Hi. I started with on a middle setting and noted the taste of the coffee. Grind small amounts at a time. Then change the settings for more or less fine grounds to taste. However, the largest factor in coffee making is the water. Filtered water is best. Then the last factor: the milk/cream/whitener issue. Between taste, cost and calories a bit of decision making is needed to provide the best cup of coffee for your needs. Regards.
Posted on Aug 26, 2010
Water leakage through grounds when lever is raised on my La Pavoni Europiccola.
Hi your grind is to course and or your tamp is to loose. Even with the right grind and tamp water will filter down through the puck eventually.
all the best
Dec 20, 2013 | La Pavoni Europiccola EPC-8 Espresso...
Black line on panasonic plasma
You either have a bad signal module or if you can go into the set and reseat all of the ribbons cables this might fix the set. Of course with the power off! If reseating doesn't fix, if I was going to fix it I would order a signal module first. It plugs up.
Jan 02, 2008 | Televison & Video
How do i level jointer tables to make them co-planer
I assume you mean that the two tables are not in parallel planes. No, I don't think adjusting the gibs is going to buy you anything unless they are so loose that the tables don't seat flat on the ways. If this is a very old jointer, and the ways are worn so they are no longer flat, then might have to regrind them - but that would be difficult. I would measure the amount of "out of parallel" that the tables are at different depth setting after tightening the gibs so that the tables are just a little harder to move. If they are out of paralell by the same amount at different table heights, then I would put the whole jointer (not the base of course) on a surface grinder and grind both table tops. Of course you would need a pretty big surface grinder, depending on the size of your jointer. Good luck!
Jul 20, 2012 | Masonry Tools
Coffee grinder only grinds to course no matter where grind adjuster is set
From what I've read about this grinder, you should be happy that it worked well as long as it did.
I say chuck it & buy a new one!!
Apr 13, 2012 | Coffee Makers & Espresso Machines
Random Short Grinding/Buzzing Noise from my Notebook gets amplified through PA system!!! Don't know where it is coming from or when it will happen next!!!
try and blow out the laptop with compressed air as it could be your fan making noise, make sure to leave the laptop on a flat surface, and don't press too ******* the palm rest. i say this because i have a dell 1545 and the hard drive is located on the left side under the palm rest and if i apply too much pressure i hear a slight grinding noise. let me know if this helps and please tell me if you're near the machine when it does this grinding sound.
Jan 31, 2012 | Computers & Internet
I don't know how to turn it on
It is my pleasure to guide you.
Look along the right side edge, 1 inch or 2 inches back from the screen edge. There should be four or five buttons and the bottom one should be the on/off button. Just press it and the
TV should turn on. Of course I don't have to mention to be sure it is plugged into a live outlet.
Please post back that you are successful or that I can be more helpful.
Jun 05, 2011 | Televison & Video
What isthe proper coffee to water ratio
Most coffee brewing sites say to use 2 tablespoons of ground coffee for 6 ounces of water. Since the grind can vary, they also say to use 10 grams of coffee per 6 ounces of water. Going by weight ensures the proper ratio.
If you're making coffee for yourself, of course, the proper ratio is whatever gives you the taste you most enjoy. Start with the 10g-to-6 ounces ratio and adjust as desired. Not all roasts and beans brew exactly alike.
Don't forget to keep your coffee maker clean, and use filtered water. This can have a great effect on the coffee's taste.
May 09, 2011 | Continental Electric CE23581 4Cup Coffee...
Coffee tastes waterdown
for grounds you need to tamp the ground hard,. Fill the port a filter to the top then tamp it until the little line is showing. Also what may be a problem is the grind is too fine, or too course
Feb 12, 2010 | Coffee Makers & Espresso Machines
Coffeem maker not working
I a similar problem with my machine. I went 3-4 days without making coffee before i went to take it back. However, when i unplugged it, then plugged it back in, it worked. I didn't figure out why, but i've had to do this twice now. (Hasn't happened in a while.)
Good Luck
Sep 14, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Revere Ware old fashioned coffee pot
1) Boil the water you’ll need in another pot.
2) Put 1 tablespoon of ground coffee (drip grind, not percolator grind) in the reduced diameter, perforated bottom of the brewing chamber.
3) Put the grind/water separator (the perforated, flat handled plate with cup markings on the handle) in the Brewing Chamber, over the coffee grounds.
3) Put the Brewing Chamber on top of the Holding Chamber.
4) Pour the appropriate number of cups boiling water into the brewing chamber; put the lid with the black knob on the brewing chamber.
5) Let the water drain through the coffee grinds (5-10 minutes).
6) Remove Brewing Chamber, clean out the coffee grounds, and replace the lid on the holding chamber.
7) Enjoy your coffee! Keep it warm on the stove at LOW heat setting.
for the most information on the Revere cookware lines, go to: http://mysite.verizon.net/vzeoywo4/theshineshop2/id1.html
Charlie
Jun 16, 2008 | Coffee Makers & Espresso Machines
Cuisinart Supreme Grind  CCM-16PC Grinder Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
