Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Picture color is seperated and curved why? - Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
  • Samsung Master
  • 5,138 Answers
Convergence ICs STKs big black ics have number on them replace Both Call Mats 1-800-628-1118
STK394-020
Posted on Oct 04, 2009
Colors seperating and out ends of screen curved
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors pictures shadows or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 27, 2010 | Mitsubishi WS-55809 55" Rear Projection...
The color has seperated into blue, red, green and picture is curved and makes it seem like I' seeing double
Ur tv convergence are dead.U know how to solders?Must replaced 2 STK convergence ICS,some or all it resistors.Tries websites Tv repair world.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 10, 2010 | RCA R52WH73 Projection Television
ALL 3 COLORS ARE SEPERATED AND CONVERGANCE DOES NOT FIX
We fixed this same problem as a dyi project. Check out www.tvrepairkits.com. The kit itself come with the proper chips, fuses, and very detailed instructions which includes pictures. They also have online help if you have questions. If you know how to solder and are a very careful person, this is something that you can fix yourself.
Mar 08, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Pink and green colors seperated images rounded off
If colors are skewed and will not adjust in the customer menu---you have a CONVERGENCE circuit problem.
This model (KP-51WS500) uses two of the STK-392-560 convergence IC chips. I just got home from fixing a similar model with the same problem.
Parts cost on Ebay for the chips and such is going to be less than 30 dollars total. Shops are going to get 300 or more for this kind of repair---and some will not do it in your home---the repair takes about an hour--I have done hundreds of them here in people's homes.
If you have questions or need advice, reply to this posting and I will try to help.
If this told you something that helped you understand, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Sony KP-51WS500 51" Rear Projection...
52'' Projection TV SONY
this is a problem with the convergence chip. you can try to adjust the convergence in the menu settings of the t.v.
pin cushioning will correct the curves, convergence fixes color seperation.
write the number down before changing them, in case you make it worse.
Nov 11, 2009 | Sony Televison & Video
Colors have seperated on tv, and curve
You have a convergence problem.
Maybe need change the IC of convergence, or the power supply of these parts.
Bye.
Apr 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Color seperation on rca 1998 46" rear projection tv
projection tvs have seperate color bulbs that put out the same picture the lenses just need to be adjusted. they probably shifted during the move.
Dec 04, 2008 | Televison & Video
TV picture curves
This is a convergence problem and is usually either bad connections at the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Locate the convergence ICs (large black Ics attached to a heat sink and marked STKxxx). Resolder the pins first. If that fails to resolve the problem replace the ICs.
Keep us posted.
Dan
Nov 07, 2008 | Mitsubishi WS-55807 TV
Toshiba 43H70 HD Projection TV
this is a convergence failure, there are hundreds of posts about it on this website you should be able to find everything you need
May 23, 2007 | Toshiba 43H70 43" Rear Projection...
Arched picture at bottom seperating the green and red
Your tv has a convergance failure. the convergance ic's need to be replaced. Upgraded part # STK392-150 or STK392-160. Both ic's should be replaced to prevent future failure of other colors.
May 20, 2007 | Toshiba 43H70 43" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
179 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
