Question about Motorola Satellite 9505 Cellular Phone
Signal 67% quality 0% auto scan set up no channels found
    Problem Solver:
  • 14 Answers
When you place a call, does it go from 4 bars of signal to 0. If this is what it happening, then your 9505 satellite phones signalling processor has become out of allignment, and needs serviced. We service all forms of satellite equipment. 877-258-3496
Posted on Jan 18, 2010
Proscan PLEDV 1945A-B will not recognize cable. Auto channel scan results in no channels found
Do you have the converter box to convert the incoming signal from digital to analog, you must have this to receive broadcasts.
Nov 04, 2016 | Proscan Televison & Video
NTD-1356 Auto Channel Scan not finding channels
Cable TV comes from the receiver to the monitor (ntd 1356) thru a cable the ntd 1356 tuner needs the external antenna to be installed to work
Check the inputs for external signals
Oct 29, 2016 | Televison & Video
The tv s autostore will not retune
i think in your TV...... design ..... is such that once channels are autostored it cannot be retuned ..... so you try this ...... it may work ......... disconnect tv antenna cable ( or local tv channels cable ) from your TV & then click autostoring (auto tunning ) ..... definitely it will scans (search for channels ) ..... but since no cable is connected no channels will get stored ...... but previously autostored channels will get removed ...... so now again connect your antenna cable or local tv cable & then click autostore ...... it will scan for channels .... like this you can retune ....... but remember again you may get same quality of picture which you got earlier ..... if you want better quality of picture you have to use signal amplifier (increases cables signal's strength - then picture quality improves ) .....
Nov 05, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
How to scan channels
The TV user guide should provide the procedures of acquiring auto scan. For example, your TV may be acquiring functionality from satellites dishs or cable receiver devices. Performing an auto scan achievable with the remote control device with adjustment to settings on the channel buttons would produce a signal only with available transmitter stations. Performing a channel auto scan would display no signals without available receiver devices often acquired with susbscription from a provder either cable TV, sattelite or disk network, show on demand for example. However, performing an auto scan on a new Tv should simply display a count list of possible available channels on which signals could be display when any is provided. Good luck
Jan 08, 2011 | Toshiba 32AV502U 31.5 in. LCD HDTV
I have a NetGear WNR834M that keeps dropping the signal. Connecting PC directly to the modem I have no problems maintaining signal.0
I too experience a similar issue with the wireless connection dropping. My wireless devices are within a 20-30 foot distance from the router and all of the devices loose conectivity so I know it's not just a specific device.
My WNR834M is running version 1.4.23NA. The logs file doesn't show anything except for one timestamp the last time it was reinitialized (a forced reboot).
The router's WiFi Channel is set for AUTO and is currectly using Channel 1 (found under Maintenance
Sep 08, 2010 | NetGear RANGEMAX WNR834M Router...
I live in Pretoria South Africa using Windows 7 I have installed the drivers for DVB S 100 however I cannot find signal scanning with Media center and my Theater please help
Follow this steps and try
in windows 7
On the start screen, scroll to Tasks, click settings, click TV, and then click Set Up TV Signal.
Follow the steps to connect a TV signal, depending on the type of tuner or tuners that the cable is connected to
else try
The Windows Media Center TV Pack has an "Auto Select" option which removes channels that have a weak signal from the EPG. To run the "Auto Select" option to check the list of available channels and to evaluate the signal strength for each channel, follow these steps:
  1. Start Windows Media Center.
  2. In the Start window, scroll to Tasks, click Settings, and then click TV.
  3. Click Guide.
  4. Click Edit Channels.
  5. Click Auto Select.
The "Auto Select" option tests each channel. Based on whether a strong or a weak signal is found, the "Auto Select" option puts a check mark in the box next to the channel. As soon as the detection process is complete, you have to click the "Save" option to save the newly selected channels to the EPG.
esle if the problem still persists
have a look aon the microsofts support in the following link
http://support.microsoft.com/kb/955485/en-us
Feb 19, 2010 | KWorld DVB-S 100 (DVBS100) Video Capture
No tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Jun 19, 2009 | Syntax Olevia 226T 26 in. LCD Television
TV says "no signal"
my tv says no signal when the cable is plugged in and i have tried scannning it but it says no service found ... what can i do
Feb 16, 2009 | Vizio GV42L 42 in. LCD Television
Channel changer locks up
Make sure you have the tuner set for digital channels only. then redo the channel search.
May 06, 2017 | Hitachi 57F500 57" Rear Projection...
How do i manually add a digital channel to my tv? model: ILO-26HD
do u have the user manual for the TV? if you do the solution will be in there, if not (I suspect you don't) please give the make an model so I can try to look this up, but off the top of head there is no way to "assign channels" to a paticular remote setting.
Jul 28, 2009 | Televison & Video
Motorola Satellite 9505 Cellular Phone Logo
93 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
