Question about Cameras
Canon ixus 80 is lens error tried everything no joy
  • lil_qt_lucii Dec 17, 2009
    my digital camera is a canon ixus 80IS and i think the lens are jammed because everytime i turn it on it says lens error and then makes a buzzing noise, what can i do? if i get it repaired would it cost alot?
  • 797 Answers
With digital cameras, it must be noted that lenses are very sensitive, and can be damaged by most any impact when the lens is extended. Keeping the camera in a padded case can prevent most of this kind of damage. This particular lens problem may not have been caused by impact, but most often is. Lenses are not easy to fix, and internal parts can become broken or jammed.
To try to fix this you can try to pull on the lens when you turn it on, and at the same time also do a slight twisting and back ward motion as well. This may reset the lens to the track system. It may not work, and may require repairs.
Canon has a great repair department. Canon Repair and information.
Call the 800 number and see what can be done. Also, Canon has a trade-in or trade-up program and for your broken camera, you may be able at a reasonable price to get something even better than what you have with all the original books and papers which came with the new camera. This may be a good way to go and consider, rather than spending a lot to repair it.
Posted on Oct 04, 2009
  • Dave Lundmark
    Dave Lundmark Oct 04, 2009
    Selling it as a repair, parts and as is on a site such as Ebay, may be another choice to make.
How can i restart my canon ixus 80 (lens error , restart camera)
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 18, 2011 | Canon IXUS 80 IS Digital Camera
When turning on coming up lens error restart camers
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
Sep 06, 2010 | Canon IXUS 80 IS Digital Camera
Lens error. Restart camera
Lens unit is faulty is not zooming or working properly that why you getting lens error.
you can try to open camera and near lens unit you can blow with pump to remove any dust is not causing this problem if work then good other wise you need replace len unit
Jul 03, 2010 | Canon IXUS 80 IS Digital Camera
Canon IXUS 100IS - 'Lens error, restart camera' message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Mar 20, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Lens Error ixus 800 is
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Aug 02, 2009 | Canon IXUS 80 IS Digital Camera
HiI have a Canon IXUS 80 IS digital camera. The
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Jul 15, 2009 | Canon IXUS 80 IS Digital Camera
Len error restart camera canon IXUS 80 IS
Its also known as E18 error and you would be surprised to see how this issue is resolved .. check the fallowing link:
http://www.e18error.com/posts/index.php
Apr 02, 2009 | Canon IXUS 80 IS Digital Camera
Cameras Logo
330 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
