Question about Saws
10 amp craftsman reciprocating saw with power issues. brushes fine. power cord fine. cleaned all contacts. could this be a trigger problem? It did start once after everything was cleaned and put back together.
  • David Ford
    David Ford May 11, 2010
    how long did it run and did the brushes arc excessively? If you have a volt ohms meter check the continuity thru to the brush holder. It is possible that it is the switch but do some more checking, look for a loose/broken wire, try to gently pull the wires out of the cord and look for a break in it. Let me know and furnish the model number and I will try and help.
  • 80 Answers
Could be..i would bypass the switch and jump 115v directly to the motor....that would convince me.
good luck
Posted on Oct 07, 2009
Dewalt Model D304-04 reciprocating saw wont run. I plug it in, pull the trigger and it wont start. What am I doing wrong or what could the cause be?
Hi Fred:
Hmmmmm.
- Confirm there is power in the plug.
- use continuity meter to check that there is a complete circuit through the saw.
- broken connection in plug?
- broken wire between plug and switch?
- switch not functioning?
- switch set between forward and reverse?
- Speed control potentiometer contacts dirty?
- Bad brushes?
Aug 25, 2015 | Dewalt Saws
My Dewalt DW938 battery powered reciprocating saw is eratic as to the reciprocating motion. The motor always turns when the trigger is depressed but the reciprocating action either doesn't start o
sounds like you have a gear problem, I suggest going to dewaltservicenet.com and typing in yoru model number so you can download a schematic for this tool. you have a problem in the gearcase area.
Feb 05, 2012 | Saws
Saw seems dead, after 8 - 12 trigger pulls the saws turns on (sometimes) but after you release trigger its dead again???
You should check the brushes and cord first but it sounds like your trigger is shot, not an uncommon failure for this tool. With the cord plugged in, hold the trigger on in one hand and bend the cord around in several placed, especially near the boot and push and pull it in the tool. If it comes on, replace the cord. If the it doesn't react to this, check the brushes. Without knowing which model you have, they should be at least 1/4" long, evenly worn and shiney, not burnt, where they touch the armature. If these check out you need a new switch.
Dec 23, 2010 | Dewalt 10.0 AMP Reciprocating Saw
Saw won't stop
The switch has gone bad and the contacts are welded together...
you will need to replace the switch...
heatman101
May 13, 2010 | Craftsman 8.0 amp Reciprocating Saw
Reciprocating Saw / Stopped Working (No Response)
Many of my power tools that have stopped working, it has always been the "ON-OFF" switch that has been the proplem. Try blowing out the bugger, but watch that you don't loose some of the contacts. Never had brushes actually wear out, but did have one wire break off the brush.
Jun 24, 2009 | Craftsman 8.0 amp Reciprocating Saw
Saw quit
OK there are quite a few things to look for. It seems that you are comfortable with some disassembly so lets go further. I dont know what model you have but it still might have a broken wire or the pins pulled out of the plug end. Look at that first. If you have power thru the switch I would next check the field and while there look at the "flag" terminals that go to the brush tubes, they had a habit of coming loose and stopping the tool. If this is the case you can remove the brushes and after pushing them back solder them to the brass tubes. Lastly roll the armature by hand and look for any serious discoloration or differences on the commutator. Let me know if I can help more.
Jan 12, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
Sawzall quit working
With an ohm meter check the pins where the cord plugs in. Pull the trigger and check for a reading. If that's ok, then do the same with the power cord for a reading from the plug to the terminals on the other end. My guess is that you will need a new cord. Do Not Patch a power cord!! Frankster016
Oct 23, 2008 | Milwaukee Tool 10 Amp Sawzall Plus with...
Cordless or cord saw Comparison
Cordless tools lose power as the battery drains, while corded tools deliver reliable, consistent performance with unlimited run time. Corded reciprocating saws range from less than 5 amps to 15 amps or more, with more than 10 amps providing optimal power for heavy-duty commercial use.
Aug 27, 2008 | Hitachi 11A Motor, Reciprocating Saw,...
Saws Logo
184 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
