Question about Thermador SGS36GS Gas Cooktop
My 1999 Thermadore SGCS304RS XLO burner has a
My 1999 Thermadore 30" gas cooktop SGCS304RS XLO burner has a spark but no gas flow. All other burners are fine.
textonor
  • 130 Answers
SOURCE: Thermadore gas stove top - left 2 burners won't light
Either the potentiors or the simmer control.
Posted on Jan 06, 2008
SOURCE: Thermador 30" gas cooktop SGCS304RB
You have defective potentiometer. The cost for parts is about $125.00 plus labor
Posted on Feb 20, 2008
  • 93 Answers
SOURCE: Thermadore cooktop SGCS365RS
This unit should be equiped with a re-ignition system. This is controled be a gas solinoid just under top main top of the unit. You will have to removethe top to gain access. And if you have no spark to any burner also check the spark modual.
Posted on Jul 21, 2008
  • 338 Answers
SOURCE: old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Posted on Dec 22, 2008
heatman101
  • 43501 Answers
SOURCE: Both extra low burners don't light
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 18, 2010
PC366BS no spark on two burners
Pots for the Thermator XLO gas burner can be repaired for good and you can save $200. I fixed them for two of my friends and my own pair more than year ago. Please email me (primorec@sbcglobal.net) for more info.
Jul 16, 2014 | Thermador Cooktops
SGCS304RS The two left burners work. The two right burners, spark but no gas comes out.
The regulators are clogged and so there is no gas flow due to this. use a good brush to clean the burner tops so as to get the mixture of gas /air correct. Use pressurized air to clean the valve, clean the JETS and reset.
Jun 14, 2011 | Thermador 31 in. SGSX304Z Gas Cooktop
I have a 36" Thermador
Sorry to read about your problem, I hope this helps you out.
you must have a bad control knob
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | Thermador SGS36GS Gas Cooktop
Kenmore Elite 30" gas cooktop installed. Large right front burner
There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
Feb 11, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Extra low burner that won't ignite
Lowly what the potentior does is turn on the burner control system. When you turn on a normal burner you are opening a gas valve and closing a switch to generate a spark. Thus gas flow to the burner and spark. On the extra low simmer burner there is a electric solenoid between the burner head and the gas valve. this has to open as well for gas to flow. What the potentior does is signal the simmer control what level of flame you are requesting and telling the spark module to generate a spark. Once you go to the exlow setting the potentior tells the simmer control what level of heat and will cycle the flame on and off. So when the burner knob was between low and extra low, the flame would cycle on and off. You have to seperate the top section of the cooktop from the burner box to change the potentior for it sits on top of the gas valve for that burner.
Aug 10, 2008 | Thermador SGS36GS Gas Cooktop
if its one of the center burners witch has the auto on off for extra low its the moduel under the handle
Potentiometer
Jul 19, 2008 | Thermador SGS36GS Gas Cooktop
Gas Flow
suspect problem is with the regulator on the gas bottle as it would be unusual for all burners to be faulty at the same time. try substituting a new regulator
May 18, 2007 | GE 30 in. JGP337 Gas Cooktop
Thermador SGS36GS Gas Cooktop Logo
107 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
tom wright
tom wright
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
