Question about Sony KP-61HS10 61" Rear Projection Television
Looking for a specfic converter for my kp61hs
I also have the sony tv, I am looking for a hd tuner that will take advantage of my tv's capabilties for the high definition video.
can anyone give me a specific brand and model?
5 Suggested Answers
pishta68
  • 579 Answers
SOURCE: QUAM TUNER
Doubt it. We ran HD through our small CATV system using consumer grade modulators but could only get them on the AIR frequencies, as we had very limited bandwidth as we had to carry 64 analog channels plus digital HITS packages for our Motorola DSxxx series boxes. Try plugging the CATV feed into the ANT input and do an autoprogram, or tell the tv to look on the AIR frequencies when it asks if you have CATV or AIR. Worth a shot though.
Posted on Jul 13, 2008
  • 4234 Answers
SOURCE: Sony projection tv with dual tuners; only one tuner appears to be working now.
To verify that the tuner is the problem, move the cable from the second to the first. If you don't get a signal, the tuner is bad. The main tuner is part number 859843000 and is available for $47.38 from tritronicsinc.com
Dan
Posted on Oct 07, 2008
SOURCE: Sony KDF-46E2000 hd picture problems
MY Sony (same model) has OUTstanding picture resolution and quality., I never have blockiness on any of the sports channels. I would say, give Comcast a call and complain about their signal.. they have a tech come over for free diagnostics on your wiring..
Posted on Nov 11, 2008
tlm931
  • 273 Answers
SOURCE: Only HD channels have 3D look - Sony KP-57HW40
have you ran magicfocus on hd channels and if you have and still have problem
it will most likely have to have adjsutments done in the service menu when running on a hd signal
Posted on Oct 24, 2009
I'm looking for 46''-Sony-KDL46HX820--BRAVIA-Full-HD-3D-TV.It supports NTSC,Just would like to know whether it works for PAL after using converteers as i want to use it in India
the TV have tuner :Clear QAM/ATSC/NTSC
You can``t see PAL Tv channel
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | Televison & Video
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Need to hook up Asus Nova P20 to living room television. I have S-Video & component on the TV, the nova has DVI & a DVI - D-Sub cable. What is the best, easiest, cheapest way?
If it is a hd tv, they make a dvi to Hdmi cable, if not that you will have to buy an external tv out card most tv tuner cards have tv out capabilties, Try dazzle
Nov 14, 2009 | ASUS P20 Black, Ms Vista Home Premium,...
Which converter box can you still use the picture in picture function in your tv?
yOUR SET HAS 2 TUNERS WHICH ALLOWS YOU TO USE THE PIP FUNTION. IF TRYNG TO USE A HD CONVERTER BOX YOU WILL NEED 2 BOXES ON FOR THE MAIN TUNER INPUT AND THE OTHER FOR THE PIP INPUT.
Jan 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Is my LG 32lz50 tv hd and digital
Your tv is HDTV ready but unfortunatly it only has a NTSC tuner which is analog, you will need a set top box to recieve OTA over the air digital, if you have cable sattilite or an HD dvd player you can display HD. You only need the set top box if you use an anttenna. Let me know if I can assist further and please rate this solution. lone99star
Jan 11, 2009 | LG RZ32LZ50 32 in. LCD Television
Do I need a HD tuner or converter box?
If you are on cable or satalight you will be fine. If you are still using an antana you will need to get a converter box to watch tv. You can also go here to get more answers. http://www.dtvanswers.com/
Good Luck and Please Rate FixYa!
Dec 31, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Digital boxes
This model only has an analog tuner, so you will require either a converter box or hi-def tuner after the transition.
Dec 07, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Maxent lcd
Your TV is an "HD-Ready" television. What this means is that your TV is ready to accept HD input from an outside source, but doesn't have the ability to produce the content itself. It is a monitor and does not have a digital tuner. Without a digital tuner (or for cable a QAM tuner) you will not receive OTA broadcast HD.
You need to purchase a High Definition capable set-top converter box. The converter box will have HD component out and may have HDMI out, either will feed your HD Ready TV.
Apr 08, 2008 | Sony WEGA KLVS23A10 23 in. HDTV-Ready LCD...
SYLVANIA 6620LG TV - DTV??
The ;quick answer is YES, you will need a converter box to receive digital broadcasts. This set has only an analog tuner built-in. That is why it is HDTV "ready" (ready for you to add a tuner).
As for HDTV vs EDTV it is a matter of resolution. Your set is capable of EDTV resolution, which is better than SDTV (standard definition TV) but not quite as good as HDTV. With a digital tuner you will be able to view all digital programming, even HD, and it will look excellent, though not quite as sharp as a set with higher definition.
Feb 14, 2008 | Sylvania 6620LG 20 in. EDTV-Ready LCD...
Will sony KV35s66 accept a digital tuner?
The Sony "S" series is not HD compatible in any way. To see an HD program you would require an HD down-conversion box. This would make the pictures look like regular TV, but may have some distortions because of the 16:9 scan ratio from the HD programs, unless you model series is 16:9 compatible.
Jerry G.
May 27, 2007 | Sony KV-32S26 32" TV
Sony KP-61HS10 61" Rear Projection Television Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
