Question about Ovens
I Have the whirlpool Oven RBD306PDQ8 - The power went out in our neighborhood, when it came back on the clock display will not appear. We can set the clock, it stays on the panel for about 10-20 seconds then goes off. If we hit the clock button, the correct time appears, but then goes off again in 10-20 sec. What is wrong with it?
    Sniper:
  • 68 Answers
When the power came back on, it sent a power surge to the ERC (clock assembly). Try turning the oven breaker off for 10-15 minutes, this is to reset the ERC. If the display still doesn't work, you will need to replace the ERC-Electronic Range Control.
Posted on Oct 05, 2009
Tip
Related: F2 E6 on Whirlpool RBD305PDS14 double oven - blank display
Equipment is Whirlpool double oven RBD305PDS14 built-in.  After a very stormy summer 2007, I thought a power surge may have zapped the control board.  Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit).  No error & fault code would appear.  Pressing any keypad oven control did not work at all in this condition.  When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
[TURN OVEN POWER OFF AT BREAKER!!!]
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed).  It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet).  The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol.  I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector.  VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power.  So far, so good.  After applying power, the "PF" with clock display always appears.  I am able to set the clock and press "Start".  Over functions normally.  The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however).
on Oct 21, 2007 | Whirlpool RBS245PDS Electric Single Oven
The power went off, when it came back on the oven time displayed. when we tried to turn on the oven the message feature not available came on
First try this: In your Household Circuit Panel, Turn the Circuit Breaker to the off position. Wait 30 Seconds and then turn it back on. Try to turn the oven on if it comes on you are in luck, if not look in your manual for first time set up instructions like setting the clock date and time, and go through the settings. Then try the oven again. If it comes on you are in luck.
Oct 15, 2014 | Whirlpool 24" Double Electric Built-In...
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Whirlpool oven ''feature not available''
That happened to my fairly new Whirlpool double oven. But I remembeedr the power in the neighborhood had flickered earlier in the day. So I went to the circuit breaker and shutoff power to the oven for about 30 seconds and turned back on. Everything normal now. I just assumed the slight flicker in the power affected to programming.
Jan 24, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
After a power blackout in our neighborhood the oven display showed a blinking clock time-still keeps time- which could not be reset. The soft panel does not respond to any setting to turn on the oven in...
Try turning the breaker to that unit off and keep it off for 20 minutes or overnight, if possible, then flip the breaker back on. If it still shows the PF code, call us and we can get the correct part to you. Hope this helps.
Aug 28, 2009 | GE JTP20 Electric Single Oven
Having trouble with the clock display
try holding down clock button.. when you 1st hold it down it will appear.. keep holding til it disappear.. then when it comes back on let go of button.. if clock button don't try another like + or - sign.. good luck.. mike
Jan 22, 2009 | Whirlpool RBD305PD Electric Double Oven
My step Dad's whirlpool, electric, self cleaning oven will not heat up at all. Model # RBS245PD012. The power went out for just a few minutes so he was resetting the clock. An error code E3-F1 is on...
Hey there-
He ended up calling a repair tech.. He came out and ended up replacing the whole control panel.
My step Dad says it works fine now and the clock is a lot brighter on the display than it was before, so maybe it was slowly going out then finally just gave in. ?? Thanks for checking in though.
Oct 06, 2008 | Whirlpool RBS245PD Electric Single Oven
Whirlpool electric oven
hi switch main power off at wall. hold middle clock button in and switch power back on at the wall. Display should show --:-- and oven should work.
Nov 30, 2007 | Ovens
Oven Problem
Check power going to the electronic module in back of the display. If power there you have a blown module. If no power check for a blown thermal fuze.
Apr 08, 2007 | Frigidaire FGB24T3A Gas Single Oven
Ovens Logo
197 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
